  • Guests: 21
a.gutzeit (63)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
USB 3 transfer speed
Tue Feb 13 2018, 06:09AM Print
Hi, is it normal for USB 3 to be as low as 37.7 MB/sec ?
The same drive in an ancient netbook and my C650 was over 62MB/sec on H2test.
thanks, -Andre
Bjørn
Tue Feb 13 2018, 07:14AM
That is a very good USB 2 transfer rate. Either you are not running USB 3 or the drive is not faster with whatever USB interface you are using.
Thu Feb 15 2018, 08:19AM
Thanks Bjorn.
I will check, as the connector is suspect (cough flaky DIY repair /cough) one or more pins may not be connecting.
Its a very old adaptor so possibly not genuine USB 3 or throttling.
