  • Guests: 34
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
Creating buttons in Dreamweaver MX
Penguin7471
Sun Nov 12 2006, 06:34AM Print
Penguin7471 Registered Member #71 Joined: Thu Feb 09 2006, 08:23AM
Hi all,
My site has alot of plain text hyperlinks, which is kind of boring. I want to create some buttons, similar in appearance to the google search button. In Dreamweaver, I know that it is possible to create a form button to do this. However, I can't seem to be able to adjust the length of the button itself, and the button never aligns perfectly with the text. I also can't modify the button font and text size.
Its obviously something really simple and the even the online manuals dont tell me how to do something like this.
Cheers,
Paul
ragnar
Sun Nov 12 2006, 06:50AM
Open the source code, and add the attribute
style='width:200px;'
etc. to your <input> element.
Penguin7471
Mon Nov 13 2006, 01:09AM
Hi, thanks for that BlackPlasma (or balsamplack mistrust )
I've figured out how to edit the font, and button width. Is there a way to edit the colour of the button.... and also make the inside text bold?
ragnar
Mon Nov 13 2006, 01:21AM
You're welcome -- and to clear things up, you can call me Matt (or Tam) :P
To change the colour, go back into the source and append to your "style:" attribute:
color:#99ccff;
background:#003366;
font-style:bold;
Your tag would then read:
<input style="width:200px;color:#99ccff;background:#003366;font-style:bold;" ... >
etc
You can also use shortened HEX (e.g. color:#9cf;) or names (e.g. color:red;) when defining the colours.
Penguin7471
Mon Nov 13 2006, 07:42AM
Hey,
Cool, thanks for those. But haha.. is there any way to use a picture as the background for the button?
Oh yes, the text bold thing didnt work, so I eventually figured out it was font-weight, and not font-style..
ragnar
Mon Nov 13 2006, 12:19PM
wrote ...
D'oh!! My apologies.
wrote ...
Yep, try:
style="background:url('path/picture.ext') top left no-repeat #003366;"
You may replace "top" "left" with "bottom" "right" "center" or a px, em, or % value, and similarly you can replace "no-repeat" with "repeat-y" or "repeat-x" or remove it altogether for the picture to tile in both directions. If the background has transparent pixels or doesn't tile, then you can define a background colour as well, as you see.
Alex
Mon Nov 13 2006, 09:36PM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
Matt is doing a good job of answering your questions, Penguin, but an even better solution would be to learn HTML and CSS yourself. Dreamweaver creates mangled code and as you get more specific, it becomes more of a hinderance than anything.
Learning HTML and CSS will require a bit of effort, but I encourage you to do so. The results are rewarding, and writing clean code is more fun than battling Dreamweaver. If you're interested, Tizag.com has an HTML and a CSS tutorial, and W3 Schools is a useful reference.
ragnar
Mon Nov 13 2006, 11:43PM
I was getting to that... wink
Penguin7471
Tue Nov 14 2006, 12:50AM
Ah yes you're probably right Alex. I'll have a look through those tutorials.
Cheers for the info guys.
