  • Guests: 35
09/19 raff (48)
09/20 PYLEMET-mk2 (36)
09/21 Bill G (65)
Complex math inside Altera Cyclone FPGA
Adrenaline
Tue Jul 30 2013, 10:20PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
You really didn't answer my questions. If you have a 16bit ADC, it should/can be integer. Why not just perform all your calculations in integer or fixed point? Floating point seems like an unrequired complexity especially in FPGA as already noted.
Linas
Wed Jul 31 2013, 07:04AM
Steve Conner wrote ...
So you got the ADSP to boot? smile
Yes, spend some time reading and found mistake in booting, also i writed data MSBF format, but adsp need LSBF.
Adrenaline wrote ...
I really don't know what will be, if i use long signed integers to do the math. What i do is single point DFT, when i have real and imag part of frequency, i can calculate phase with atan2 function. Maybe it is possible to make it by using signed integers, i will try to model this and see if that will not degrade performance and accuracy, but from DSP point of view, native variable is f32,
If some one knows theory of information, what bit depth coefficients (in bits, like do i can only use 12b and have same resolution in phase calculation, or i need 32 or even 64 ?) will not degrade performance ?
Or better question, if i have 128 point of signal, lats say 4 periods of sinus, and it's 16b depth, what is the phase resolution of this system ?
Wed Jul 31 2013, 08:58AM
Well done! I hate troubleshooting these types of issues. tongue
To a first approximation, the phase resolution would be 4/128 of 360 degrees, or 11.25 degrees. It is dominated by the small number of points, because you can only figure out the phase to the nearest sample.
You can use interpolation to get a more accurate result. This amounts to converting the excess amplitude resolution into phase resolution. This implies that the result will only be as good as the SNR of the input signal, because amplitude noise gets converted into phase noise.
Running the algorithm several times and averaging the result will help with SNR, at the cost of lowering the control loop bandwidth.
In a related project, we use an 8192 point FFT feeding a frequency estimation algorithm which provides the frequency for an 8192 sample "single point DFT". We can measure the phase of a 50Hz signal, sampled at 5kS/s and 12 bits, to within 0.01 degree.
To do this on a FPGA, my first thought would be a large lookup table of the sine and inverse tan functions, but that could cause problems with division by zero. And indeed division itself, which you want to avoid in a FPGA.
If processing time permitted I would use the "lock-in" method where I run the correlation over and over again, using a successive approximation algorithm to vary the phase until I find the phase that makes the imaginary component of the output zero. This gets rid of the inverse tan lookup table and the division issues, by getting the correlation to solve itself. Only a sin/cos lookup table and MACs are required.
This technique worked nicely for me (in fixed-point arithmetic with a 16x16 multiply and 40-bit accumulator) in a lock-in detector algorithm that I wrote for a gas analyser. If the phase doesn't vary too much between runs, you can speed it up by using the solution from last time as an initial guess. If you take this to its logical conclusion you have a digital PLL that "solves" the phase by locking to it. I've also used this method.
Maybe in a FPGA you could run the correlation in parallel for several different test phase values, and then interpolate the actual value from the outputs of this "phase filter bank". This technique could be mixed with successive approximation to achieve the best trade-off between speed and amount of FPGA fabric used. At the next iteration, the phase filter bank would be reloaded with test phase values spaced more closely around the answer from the previous one.
The Spartan 3A-DSP has about 100 hardware MAC blocks that can clock at 250MHz, so you could maybe calculate 20 or 50 test phase values at once.
Linas
Wed Jul 31 2013, 09:56AM
I like DFT, because it is bruteforced way to get phase at the same time i finish read detector. i don't have any problems with division by zero because of simple trick to at very very small value to imaginary part, and division by zero should be rare anyway.
About ADC resolution, i don't find any point of go lower that 16b, since it's same bus width , and noise in LSB will give same effect as no noise in 12b conversion.
Also will fractional table will give me better phase precision ? because i can calculate 6.5 (i usually go for 6 or 7 point in frequency domain) frequency coefficients for phase measurements.
Running phase matching algorithm will not work, because phase can be pretty random, so it will add complexity with no speed benefit in my mind.
Altera cyclone 4 have 30x 9bit multiplier blocks and they can run on same speed +-
Also FPGA can do between 2 to 4 readout averaging (ADC running 2x or even 4x speed of detector) that could give from 1.414 to 2x better readout SNR.
Just wondering, knowing situation what you would do differently ? (sine i am no good in electronics, my approach is bruteforce)
Also is it possible ( i think not ) to get not 2pi tracking ability, but more that that like 6pi or more ?
Dr. Slack
Mon Aug 12 2013, 07:13AM
Single point DFT, yes, fixed point math, yes, but anything involving division to get the phase, no.
Look up COORDIC. It's a very flexible algorithm designed for doing conversion either way between cartesian and polar, and is suited to running in fixed point with no multipliers, only adds and subtracts. If you need performance, it can run pipelined and bang out one conversion per clock cycle. If you want chip area, it can compute one bit of the answer per clock cycle with three adders, or one bit per three cycles with one adder.
It's a nice tool to have in your FPGA DSP tool-box, because running theta -> XY, it can replace the trig lookup table in an NCO, and a demodulation mixer for free, and with a tiny bit of modification it can find reciprocals or square roots as well.
As far as interpolation goes, doing an FFT gives you bit growth. Half of that bit growth is true noise-reducing extra resolution. Think of it as spreading the total noise power over the nyquist bandwidth, and suffering only the noise in one bin. So if you have (say) a 10 bit ENOB ADC, and do a 256 point DFT, the resulting phase estimate will have a 14 bit ENOB, which gives you a noise-limited resolution of the order of 2^-14 radians.
