  • Guests: 27
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
ADSP JTAG
Linas
Sat Jun 01 2013, 09:09PM Print
Hello,
i am working on PID loop, with lot of complex f32 math ( 256 point DFT ). So far i was using STM32F4 overclocked to 250MHz, and i get around 16MBps processing speed (it could process data from 8MSps adc in real time)
my new detector almost tripled data rate, and i can't do real time calculation anymore (but i must). I can join two processors, and get performance i need, but that just stupid...
I have SHARK DSP laying around, so i guess i have to give it a try (ADSP-21488 could run 400MHz)
But i don't have any JTAG, any ideas how to program it ?
( or i have to use same STM32F4 to boot dsp ? )
Sat Jun 01 2013, 09:32PM
Do you have an evaluation board or just the chip itself?
The SHARC DSPs don't have any onboard flash memory, so you have to boot them from an external PROM anyway. You could just program this PROM.
Your main problem will be that Analog's VisualDSP++ development software is only available as a 30 day free trial, and the full version costs about $10k. We chose the TI C6700 series DSPs instead.
Linas
Sun Jun 02 2013, 02:53PM
Steve Conner wrote ...
No, i have just chip.
How fast TI DSP can run in LQFP or similar package ? i only find to 170MHz, and higher is BGA only, so no good for home use.
Sun Jun 02 2013, 08:28PM
Dunno. We use the TMS320C6713 in a BGA package running at 300MHz, mounted on a board that we designed in-house.
Edit: I checked the datasheet. The QFP version goes to 225MHz. The C6713 is an oldish chip, but it's floating point. Our PCB contractor likes it because the BGA is coarse pitch and easy to solder. I like it because the optimizing C compiler does most of the hard work for me. smile
The OMAP-L137 and L138 are more modern chips that combine a C6713-type floating point DSP core with an ARM application processor. I believe you can buy one as the Hawkboard.
Linas
Fri Jun 21 2013, 02:38PM
One more question:
Can i hold ADSP in reset while programming FLASH ? or i should disconnect flash with DIP switch and program it ?
Keeping ADSPin reset will be cheaper
Fri Jun 21 2013, 03:14PM
The DSP datasheet should specify the states of the pins that the flash is connected to, while it is in reset. Probably they will both be Hi-Z, in which case it is OK to program the flash from an external source.
Linas
Thu Jun 27 2013, 12:05PM
but should i apply power to DSP itself ?
since i need to program only flash ,idea is supply power from DSP to SPI flash power through schottky diode, and just connect parallel to flash connector for programming. When i disconnect DSP from power supply and connect flash programmer, it will power only flash (because of diode) and just for safety measures connecting programmer will short RESET pin to ground.
My worries are internal diodes in DSP pins, so applying voltage to MISO MOSI CLK and CS could charge capacitors, and that would be stressful for diodes and programmer itself, since i don't use any buffer for SPI , but should i be worried ?
Thu Jun 27 2013, 02:13PM
All of the DSP pins will have ESD protection diodes. If you don't power the DSP, the diodes will clamp your data lines and the programmer won't be able to drive them high without charging up the DSP's power rail. This is a recipe for intermittent errors, sometimes it may work but other times it won't. You should either power the DSP, or add series resistors to the data lines.
Thu Jun 27 2013, 02:37PM
how and why would series resistors help?
Wastrel
Fri Jun 28 2013, 10:39PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
To what extent did you optimise the code on the ARM?
