  • Guests: 14
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Laserjet woes - PJL commands and print density
Billybobjoe
Thu Jul 18 2013, 03:19PM Print
I have an HP LaserJet 6P printer that I'm trying to use for toner transfer PCB making. It has parallel, serial, and Localtalk ports. I have it connected to my PC running 64-bit Windows 7 through a parallel-to-USB cable Link2 Win 7 finds the driver automatically and I am able to print easily.
However I want to adjust the toner density setting to the maximum to achieve better toner transfer. The modern day driver for this printer doesn't appear to have the an option to do so in an preference/settings panes, but I know the printer does, and its default is set to 3 on a 1-5 scale (according to a print test page). The only solutions I've found involve using PJL commands in a DOS editor Link2 This doesn't seem possible in Win 7 64-bit.
I've looked through the driver files under C:\Windows\System32\DriverStore\FileRepository and located the HP LaserJet 6P one, but when opened in Notepad, there is no mention of any default density settings.
Any suggestions to getting this changed? Or suggested places to search for answers? I'm not familiar with print drivers so I'm stuck at the moment.
Wastrel
Thu Jul 18 2013, 07:13PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
Have you tried opening the virtual port with say hyperterminal or putty and feeding it, pasteing from a file or whatever the required sequence?
Supposidly this file contains the escape codes, from a hp forum.
Billybobjoe
Sat Jul 20 2013, 01:41AM
Wastrel wrote ...
I'm not sure how to do that in Putty - it doesn't seem straightforward with the USB adapter in place. That file does include the correct code. I found the same thing on the original driver CD that came with the printer, which contains the drivers that are too old to be installed.
Sat Jul 20 2013, 04:00AM
Billybobjoe
Sun Jul 21 2013, 06:43PM
... wrote ...
Thanks! That worked perfectly. I just sent the entire modified DEFAULTS.PJL (from the original driver CD) file to the printer.
Tue Jul 23 2013, 08:12AM
just out of curiosity, on a related note, has anyone been able to get the "Brother printers" to work? with or without acetone? i apparently have had my HP printer totally crap out, it just prints black pages...
