  • Guests: 59
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Problem with Microsoft ps/2 mouse
dex
Tue Dec 04 2012, 10:41AM Print
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
I have a problem with Microsoft PS/2 mouse .It doesn't work properly any more.For example ,when I open new window it won't resize it or close it by normal clickin to "x" tab.I have first right click it in order to restore window or open and close task manager .Then ,usually,it starts working normaly.With each new window I open I have to repeat the same procedure.I tryed to reinstall the device and after restarting the computer,windows xp recognized the mouse as new hardware and supplied it's own driver.But problem persisted.I think the the file for mouse control is corrupted.Will downloading new driver for the mouse help? Where to find on the internet appropriate driver for Microsoft PS/2 mouse?Thanks for the advice.
Tue Dec 04 2012, 03:37PM
Are you sure the switch in the left button is working properly? It could be worn out. Try another mouse before blaming the software.
The PS/2 mouse driver is provided with the operating system. There are no alternative drivers that I know of.
dex
Tue Dec 04 2012, 10:27PM
yes,buttons work properly.
it must be software problem. i think i found driver windows uses for that mouse on the microsoft page Link2
i think it must be "basic optical mouse" (first under usb & ps/2 listing).
the long name of the file is the same as my os showed it was installed for my mouse.
i downloaded the driver file ,run and installed it.
after restarting computer the problem still persists...
EDIT:
after 3rd or 4th restart and aprox 2 hours after installing the driver mouse started working ok again!i made sure it wasn't virus/malware etc... but what on earth was wrong with it i really don't know...
Andy
Wed Dec 05 2012, 01:43AM
I think you're got a virus, have you got a av you could try malwarebytes, it free and pretty good. CClenear
dex
Wed Dec 05 2012, 08:14AM
thanks for advice.both avast and kaspersky say the computer is clean.and everything else works fine.
