  • Guests: 38
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
How do i use Parallax Serial Terminal ?
Mon Sept 03 2012, 11:16PM Print
im getting nothing, and ive followed the directions and advice from a tutorial not associated with parallax that has high positive feedback.
i get a pic like this :
1346714211 2431 FT0 Cmu
my cord looks like this:
Laptop -> USB - serial cable -> serial connector -> embedded device PCB.
from the serial to embedded device looks like this:
LAptop: *************************** Device:
Pin2 Comp Recieve ......= blue wire ------- TXO <- Note it could be a D or an O, I cant tell.
Pin3 Comp Transmit ....= White wire ------ RXI <- Note its not labled RXD
Pin4 Comp Ready ........= Yellow wire ----- DTR
Pin5 Ground ...............= Black (GND) ---- GND
* i wonder if pins 2 and 3 are reversed ?
should i also attach the ground to the shield ? both should be close to zero volts, or will that let noise in ?
1346716168 2431 FT1630 Sam 0175cmucable
Someone check the cable to make sure i didnt botch it:
Tue Sept 04 2012, 07:10AM
Split the problem in half. Connect pins 2 and 3 together on the laptop side, check that everything you type is echoed back on the screen.
Shrad
Tue Sept 04 2012, 08:45AM
check if your USB to serial converter is 3.3V or 5V signal level
every basic USB to serial convertre is 3.3V nowadays, which is not suitable for microcontroller use if it is not specifically a 3.3V serial enabled device
you either have to make a level shifter or use a 5V serial converter
Tue Sept 04 2012, 03:43PM
Shrad wrote ...
my serial converter puts out -8, 0 and 8 volts apparently, my parallax device is 3.3 and 5 volt capable on its serial pins.
Shrad
Wed Sept 05 2012, 07:27AM
you can always bridge TXD and RXD on your parallax and send a hex value to see if you have an echo
normally nothing is needed but RXD,TXD and GND
Wed Sept 05 2012, 07:55AM
Ah, there's your problem, you are feeding RS232 levels into a TTL port on a microcontroller. IIRC, the RS232 level shifter chip also inverts the polarity of the signal, so it won't work. You need to either hack into the USB-to-serial dongle and bypass the level shifter, or shift the levels back to TTL using a MAX232 or similar chip.
Wed Sept 05 2012, 04:41PM
Steve Conner wrote ...
i realize now i need this circuit: Link2
Shrad
Wed Sept 05 2012, 07:46PM
get a max232 from maxim for free, they ship samples
