  • Guests: 11
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
FFT on the arduino
Adam Munich
Fri Aug 24 2012, 08:29PM Print
Hi all,
It's possible to do an FFT on an arduino with a bit of low-level hacking smile. Nyquist limit is about 10kHz though...
"Bar decay" added intentionally.
-Gren
]new_compressed_zipped_folder.zip[/file]
Fri Aug 24 2012, 08:55PM
Nice, how many frames per second are you getting on the display, and what limits it?
Adam Munich
Fri Aug 24 2012, 11:29PM
Well the "bar decay" was added via an array which decrements.
I've set it to decay once per bar refresh, and it takes about 1 second for a full bar to decay, so I'd say about 16Hz. Keep in mind though, I'm drawing 20 bars, each two parts (40 vfd.write()'s per refresh). The write function has an inherent delay, so that's the bottleneck. An 8 line bus would speed things up a bit.
LCDs refresh much slower than VFDs.
The FFT itself takes about 2.5ms, and returns 128 points. I'm only using the first 20 though, giving my spectrum graph a range from 100Hz-3kHz.
