  • Guests: 16
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
i want to learn programing
Dr. Slack
Thu Jun 28 2012, 06:58AM
I'm still not clear about your aims. Do you
a) Want to learn programming (on anything, but perhaps starting with a computer with an OS, perhaps so that you'll have a less steep learning curve when you come to program anything else)
b) Want to use a microcontroller (which happens to needs programming)
The answer will critically affect what advice you're given
Carbon_Rod
Sat Jun 30 2012, 02:45AM
@HighVoltageChick Generally, I recommend this book for undergraduates:
Learning about gcc C will prepare you for just about any language, and to write platform independent code.
Cheers,
Rod
