  • Guests: 21
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Choosing Wiki software for internal site
Mattski
Mon Jul 02 2012, 11:47PM Print
I'm going to set up a Wiki page for internal documentation at a university lab I'm working in. The total userbase is around 30 students, and I expect the usage of the Wiki to be pretty light. Right now I'm choosing the Wiki software, and I've pretty much narrowed it down to two choices:
  • Media wiki
    A fully-featured and popular Wiki engine. Popular enough that it supports pretty much anything, but possibly more complicated to administer as a result. Requires an SQL database which requires additional setup and may make backups more difficult.
  • PmWiki
    A simple and hopefully easy to use Wiki engine which should support the features I need and be easier to manage. By default uses flat file to store the Wiki, probably not an issue for limited userbase and easier to set up and back up. Supports MySQL by plugin if higher performance is eventually needed.
Does anybody have any additional insight or suggestions from having set up or administered Wiki sites, such as the HvWiki here at 4HV?
Right now I'm leaning towards PmWiki as it looks simpler to set up.
Tue Jul 03 2012, 11:03AM
I use DokuWiki on my intranet to help with project documentation. I like that it stores everything in text files.
H8erade
Thu Jul 05 2012, 08:05PM
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
Yes, I also suggest DokuWiki. It's easy to set up and maintain.
Mattski
Thu Jul 05 2012, 11:20PM
Thanks guys, Doku was also high on my list as it seems to be kind of similar target user to PmWiki as both are fairly simple and by default store all of the data in text files. There are a couple of pros and cons to each, I decided on PmWiki pretty much arbitrarily.
I moved ahead with PmWiki, it was quite easy to install and setup (once I got PHP installed that is), even integrating with the department LDAP server was surprisingly easy. Now the hard part will be filling it with content wink
