  • Guests: 26
Alfons (36)
Coronafix (51)
AmonRa (44)
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Free software for recovering deleted files?
Ash Small
Wed Jan 25 2012, 08:56PM Print
I'm after a free download to recover files deleted by accident.
They are NTFS file system.
I've used 'Get Data Back for FAT32' before, when a partition failed (or something), but I had to pay for it (about 8 years ago), and had to put the 'dead' hard drive in a different PC to do it, but I just want to recover some deleted NTFS files this time.
Any suggestions?
BlakFyre
Thu Jan 26 2012, 08:35AM
BlakFyre Registered Member #1563 Joined: Wed Jun 25 2008, 03:55AM
I've used 'File Scavenger' in the past, but if I recall correctly it wasn't free.
Have heard good things about Recuva, which is free and looks as though it works the same. Otherwise if its on a system that you can no longer boot from, or would prefer to work off of RAM to avoid overwriting those files... I think Ultimate Boot CD has recovery tools.
Hon1nbo
Thu Jan 26 2012, 01:42PM
BlakFyre wrote ...
I'd have to second Recuva as a free solution, worked for me somewhat (of course not perfectly, as no recovery solution is perfect). But for a free program fine.
-Jimmy
Fulmen
Thu Jan 26 2012, 02:00PM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
Testdisk has saved my butt on several locations, including the time the whole partition table went MIA.
Ash Small
Thu Jan 26 2012, 10:30PM
Thanks for the tips.
Recuva works pretty well, but I must have already written over the files I was looking for. It did find almost 50,000 deleted image files though. The 'deep search' function recovered a lot more files than the 'quick scan' option. It seems very user friendly.
Testdisk wasn't much use for this particular application, but I can see that it would be useful in the event of a partition failure/faulty drive, etc. I wonder if I could put it on a CD and use it as a 'boot disk', or whatever the correct term is, in the event of a hard drive failure on my laptop?
