  • Guests: 67
Ian (37)
Lucas (40)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
Useful PIC code thread
AndrewM
Tue Jan 24 2012, 06:42AM Print
Anyone up for a thread of useful PIC code, or the code you find yourself writing over and over?
I'll start.
This .asm file is one I use often for projects that need hobby servo (PWM) output. If you're running a 20MHz clock on a pic the 20ms timing for a servo is a bit awkward since its larger than the maximum PIC interrupt timer interval.
This code solves that by resetting the interrupts automatically as required to give the proper PWM spacing. Simply move a value from 0 to 255 into the Thtl1 and Thtl2 registers and PORTB 0 and 1 will have proper PWM output.
Your code can be inserted into the main loop and will run in between pulses (i.e. around 20ms of every 22ms).
LIST P=16F777    ; Use the PIC16F628 and decimal system
        #include "P16F777.INC"  ; Include header file
;memory addresses start with 20h/32 (dec)
T1		equ 0x22
T2		equ 0x23
Int_Flag	equ	0x2E
PWM1	equ	0x2F
PWM2	equ	0x30
PWM3	equ	0x31
Thtl1	equ	0x32
Thtl2	equ	0x33
W_TEMP	equ	0x7E
STATUS_TEMP	equ	0x7F
		ORG	 0x000
		goto	Main_Start
		ORG	0x004
		goto	Interrupt_Start
Main_Start
;Initialization
;*** Configure PORTB
		BSF		STATUS, RP0
		bcf		PORTB,	0		;Throttle 1 output
		bcf		PORTB,	1		;Throttle 2 output
		bcf		STATUS, RP0
;*** Enable TMR0
		clrf	TMR0
		bsf		STATUS, RP0
		movlw	b'11000111'
		movwf	OPTION_REG
		bcf		STATUS, RP0
		clrf	INTCON
		bsf		INTCON, GIE
		bsf		INTCON, TMR0IE
		movlw	D'2'
		movwf	Int_Flag
;Main Program
;*** Main loop
mainloop
			;YOUR CODE HERE!!
        goto 	mainloop
;Utility Functions
;*** Adjustable delay
Pause	movwf 	T2
Pstart 	movlw 	d'255'
  		movwf 	T1
Ploop 	decf 	T1
  		btfss 	STATUS, Z
  		goto 	Ploop
  		decf 	T2
  		btfss 	STATUS, Z
  		goto 	Pstart
  		return
;*** TMR 0 Interrupt
Interrupt_Start
		MOVWF 	W_TEMP 				;Copy W to TEMP register
		SWAPF 	STATUS,	W 			;Swap status to be saved into W
		CLRF 	STATUS 				;bank 0, regardless of current bank, Clears IRP,RP1,RP0
		MOVWF 	STATUS_TEMP 		;Save status to bank zero STATUS_TEMP register
		bcf 	INTCON, TMR0IF		;clear interrupt
		decf	Int_Flag			;dec flag
		btfsc	STATUS, Z
		goto	Flag0
Flag1	bsf		STATUS, RP0			;Change Prescaler
		movlw	b'11000110'			;128
		movwf	OPTION_REG
		bcf		STATUS, RP0
		clrf	INTCON
		bsf		INTCON, GIE
		bsf		INTCON, TMR0IE
		goto 	ExitInt
Flag0	movlw	D'2'
		movwf	Int_Flag
		movlw	b'11000111'			;256
		movwf	OPTION_REG
		bcf		STATUS, RP0
		clrf	INTCON
		bsf		INTCON, GIE
		bsf		INTCON, TMR0IE
		;do high pulse loop (5000inst/ms)
		movlw	D'255'
		movwf	PWM1
		movlw	D'6'
		movwf	PWM2
		bsf		PORTB,	0
		bsf		PORTB,	1
Pulse0	decfsz	PWM1		;1   ---  3 * 255 = 765	* 6 = .916ms
		goto 	Pulse0		;2
		decfsz	PWM2
		goto	Pulse0
		;remainder loops (6000 inst/255 thtl)
		movfw	Thtl1
		movwf	PWM1
		movfw	Thtl2
		movwf	PWM2
Pulse1	decf	PWM1		;1
		btfsc 	STATUS, Z	;2
		bcf 	PORTB,	0
		decf	PWM2		;1
		btfsc	STATUS, Z	;2
		bcf		PORTB,	1
		movlw	D'6'
		movwf	PWM3
Pulse2	decfsz	PWM3		;1
		goto	Pulse2		;2
		btfsc	PORTB,	0
		goto	Pulse1
		btfsc	PORTB,	1
		goto	Pulse1
ExitInt
		SWAPF 	STATUS_TEMP, W 		;Swap STATUS_TEMP register into W
									;(sets bank to original state)
		MOVWF 	STATUS 				;Move W into STATUS register
		SWAPF 	W_TEMP, F 			;Swap W_TEMP
		SWAPF 	W_TEMP, W 			;Swap W_TEMP into W
		RETFIE
		END
