  • Guests: 15
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
PIC Noobie
Sun Jul 30 2006, 03:59PM
What is wrong with a normal pic? As long as you get the flash ones you should be able to reprogram as many times as you want... The compiler from microchip uses C (the student version is free)...
Part Scavenger
Sun Jul 30 2006, 04:29PM
Oh. neutral
Ok, I guess I didn't PIC up that bit of information. cheesey Thanks
Bjørn
Sun Jul 30 2006, 06:34PM
It is hard to destroy a PIC, I have never managed it. Once the PIC melted the protoboard under it and the PIC still worked.
Part Scavenger
Tue Aug 01 2006, 06:44PM
Hey, thanks for all the help guys. It's my day off, and after a few hours I've got some elaborite LED flashin' going on. Soon to voltmeters and displays!!! cheesey
If anyone reads this later, I highly recommend this tutorial: Link2 You guys have probably seen it already.
I thought I was going to kill myself there for a while, I didn't have any of the exact chips in any tutorials and they had different port names and stuff. Now it looks like it was worth it.
Thanks again!
Wed Aug 02 2006, 10:23AM
O___O Bjoern
The company I work for uses PICs in many of our products. (and I'm the po' sucka' who writes all the firmware.) We've never managed to destroy one on purpose either, though about 1 in every 200 just mysteriously never works. We don't know why, but at the moment it's not cost-effective to spend time figuring it out. I once dremel'd all the legs off a 44-pin surface mount PIC and replaced it with a fresh one, only to discover the damn board still didn't work :(
We recently had some products returned where the customer had plugged them into 12V instead of the 5V they're designed for. I expected the PICs to be fried, but the flash memory was just blanked, and after reprogramming they worked fine again.
I must admit that I've been seriously impressed by the Philips ARM7 based chips since Bjoern wrote about them here. I'd probably choose them over the AVRs or 18-core PICs if I wanted a more powerful micro that could run code written in C happily. But the 16-core PICs programmed in assembler are great for getting cheap'n'nasty jobs done.
