  • Guests: 15
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Urgent: Controlling the AR.drone via laptop...
Mon Oct 31 2011, 02:07AM Print
I usually dont post in the computer section but i need help finding a program that will run on a win7 HP Mini type laptop, what ive used so far doesnt work or is too buggy, need help quickly please. I have alot of tests and homework comin g up so i gotta get basic flight control up int the next 10-14 days... alot off peeps are able to do so but i cant
BRB ... in a few minutes
Back
1320028935 2431 FT1630 Sam 0393
on the ground.
1320028935 2431 FT1630 Sam 0399
In flight, hover.
Carbon_Rod
Mon Oct 31 2011, 06:24AM
Perhaps something like this project will work:
If your school is part of MSAA than the compilers should be available from the CS department.
Windows OS & MacOS can be "problematic" for control systems as they were not designed for this purpose.
In order to gain simple direct hardware access permissions it is usually better to go with Debian/Ubuntu linux, an RTLinux patched uClinux, freeRTOS, or VXworks (not free).
Unfortunately, 14 days is likely too short a time to build and test a flight control system.
Mon Oct 31 2011, 07:07AM
Carbon_Rod wrote ...
I dont need a whole lot, just a simple replacement for the iphone, ipad, droid controller as the AR.Drone has no conventional or native controller like every other flying RC device ive ever used. others claim to have the ability to access all the basic functionality through their laptops.
Ive already tried the version carbon rod you suggest but it wont connect or do anything else once i open it.
Windows.AR doesnt do anything either totally craps out on this computer, yet no one else has any on the problems i describe like the "connection time out" messsage, so i think the failure is in my laptop. I dont have any other comps that use win7 and i guess the SDK's so far are only for win7.
i dont own an iThing either...
Carbon_Rod
Mon Oct 31 2011, 07:56AM
Things to try:
* Setup Windows 7 pro to emulate an XP mode wrapper
* Run the compiled program from outside the IDE (VS debug mode will break some DLL wrappers for hardware access.)
* copy missing DLL into the same directory as the compiled program and execute in host OS
* Setup a wireless router to relay command terminal packets (IPv4 only )
* Check that firewalls like McAfee Antivirus are not quietly interfering
* Use Wireshark to check packet traffic
* Ask local technical people in your school for assistance setting up the networking
Cheers,
Rod
Mon Oct 31 2011, 04:26PM
Things to try:
Cheers,
Rod
Ok ill get my chief programmer on these suggestions... TY carbon rod. (alot of this is over my head)
Mon Oct 31 2011, 05:10PM
Patrick wrote ...
Ive got a parrot now!
But im trying to fly it via laptop, however using this program ( here -> Link2 ) i get some time out error not sure if my laptop wifi is configured right?
let me post a screen cap...
1319515905 2431 FT1630 Ar
Was i supposed to do something with those .dll's?
Link2 i like this crazyFlie too...
here is a quote from a previous thread.
