  • Guests: 15
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
SKKT50014E SCR question
vk2fro
Tue Jun 28 2011, 06:49PM Print
vk2fro Registered Member #3930 Joined: Sun Jun 05 2011, 07:27PM
Hi guys
The above scr has a nice peak current handling of some 17,000 amps. Way overkill for my cap bank, but I like to overrate my components.
I've been reading up on triggering these things, and this one wants to see a minimum of 3v @ 200ma to trigger.
Thats all fine and easily done, but I noted that this guy is actually two SCR's in series, two seperate gate connections, with the anode of one connected to the kathode of the second.
Looking at the pin out I can treat this device as two SCR's in the one package, as it can be connected such that either SCR can be used independantly.
Is this how you guys wire them for coil guns / disc launchers?
Cheers
Ben
Saz43
Fri Jul 01 2011, 08:25AM
vk2fro wrote ...
I'm a little confused by what you're referring to, but if you're asking if hobbyists use 2 SCRs in series for coilguns, the answer is no- you only need 1 SCR.
People do however often put multiple SCRs in parallel to split up the current. You can also use 2-SCRs in a "V" sort of configuration if you're building a V-switch coilgun.
vk2fro
Fri Jul 01 2011, 09:41AM
No, this SCR is two SCR's in the one package - so I guess I just use "one side" of it (aka one SCR), leaving the other as a spare :)
Forty
Fri Jul 01 2011, 08:13PM
use the second scr for a second stage :)
vk2fro
Fri Jul 01 2011, 09:02PM
Its pretty hard to add a second stage to a wire exploder / hard drive platter launcher. ;)
Forty
Sat Jul 02 2011, 06:39AM
oh well your first post said coilgun/disc launcher, sorry.
vk2fro
Sat Jul 02 2011, 07:12AM
Thats ok Forty - thanks for helping out - anyways this topic is now a moot point as I ended up scoring a big hockey puck scr for cheap :)
