  • Guests: 21
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Mesh Laptop Auto Reboots Constantly After SP2 Install
Dr. Who
Mon Jun 19 2006, 08:42PM Print
Dr. Who Registered Member #326 Joined: Sat Mar 18 2006, 01:12PM
I'm attempting to get SP2 working on a Mesh 7321 laptop (Athlon M, 384 MB RAM), running XP Home. SP2 failed to install, so I used fixdb.bat, a script which stops and restarts cryptographic services obtained from:
http://www.michna.com/kb/WxSP2.htm#Cannot_install_Service_Pack_2
SP2 installed successfuly, however the PC kept rebooting during the Windows loading procedure. I then ran system restore from safe mode. The result was that it now reboots itself in any boot mode, including safe mode.
All help and ideas gratefully received.
Tue Jun 20 2006, 12:40AM
Generally the remedy for these problems is to bust out the original install cd and try again... So long as you get sp2 on before you install anything else you should not have any problems... You did backup all data before starting, right?
Beyond that... do you think that you can put in a linux livecd and get the log files from the sp2 install...
thom
Wed Jun 21 2006, 08:27AM
thom Registered Member #239 Joined: Thu Feb 23 2006, 03:15AM
http://forums.wugnet.com/windows/constant-rebooting-XP-SP2-install-ftopict237634.html
Dr. Who
Fri Jun 23 2006, 09:55AM
Thanks folks. I tried the stuff on the Michna site, but no joy. I did a repair install of Windows and it works fine now.
