  • Guests: 17
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Using Uzzors2k's Capacitor charger with higher voltages
Adam
Fri Apr 08 2011, 02:50AM Print
Adam Registered Member #3821 Joined: Fri Apr 08 2011, 02:20AM
I have a pretty good understanding of how this flyback capacitor charger works, and I think it has great potential as a compact, cheap and efficient means of charging large banks quickly if one were to increase the voltage to the upper limits of the comparators supply voltage (around 36v if my memory serves me correctly).
Since the zvs driver's flyback output increases dramatically as one increases the voltage (I have one running on a 500w 36v power supply and it goes grrreat!) I think charging a 5kJ in reasonable sort of time is totally viable.
My knowledge of electronics does not extend to figuring what resistor values I'd need to change to get everything running nicely. The LED part of the circuit would need to go.
Has anyone run this successfully at higher voltages? Has anyone pushed it as high as 36v? What did you change to get it running? I'd love to build a self limiting ~400w capacitor charger, and I'm sure i'm not the only one!
James
Tue Apr 12 2011, 05:28PM
Looking at the schematic, you ought to be able to just cut one wire and separate the supply of the ZVS part of the circuit from the control part and feed the higher voltage into the choke that feeds the oscillator. It looks like the control circuit shuts down the oscillator by pulling the mosfet gates both low through the pair of diodes, so there's no reason you can't run the oscillator part from a higher voltage than the control circuit.
Adam
Tue Apr 12 2011, 08:17PM
This is good advice, and the conclusion that I had come to - LM317 regulated 12v supply for the comparator part and straight 36v for the ZVS.
Doing things this way means I could crank the volatge even higher for even more power too!
Tue Apr 12 2011, 09:18PM
Yup, it's that easy. Use 12V for the regulator, and whatever you want for the Mazzilli driver. Be sure to use a common ground!
James
Tue Apr 12 2011, 11:07PM
Probably don't even need the LM317, a 12-15V zener diode and resistor ought to cut it. 7812 would work too and save a couple of resistors over the 317.
Adam
Thu Apr 14 2011, 10:32PM
I'm going to rock on with the LM317 since 7812 has an absolute maximum input voltage of 35v and LM317 would enable the whole thing to work up to 52v!
James
Thu Apr 14 2011, 11:02PM
52V? I thought all of the 78xx series regulators maxed out 30-35V input? There is the LM317HV that's good for a bit more, although high differentials between input and output are not practical with linear regulators unless the load is very small, which in this case it ought to be.
I would just use a resistor and zener diode, total load is probably not more than 20-30mA.
Adam
Fri Apr 15 2011, 02:15AM
Re read my post - you are quite right, the 7812 maxes out at 35v but the LM317 can handle a +40v differential.
James
Fri Apr 15 2011, 03:00AM
I always thought the 317 was essentially the same as the 78xx series aside from the internal reference. *shrug* I never really tried using one at such a high differential, any more than a few tens of mA and you get so much heat, not that it's likely to be much issue in the application at hand.
