  • Guests: 18
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Odd PSU readings.
Inducktion
Thu Mar 17 2011, 12:26AM Print
Hello all, I built my computer about a year or so ago, and I've noticed ever since I built it the power supply has some funky voltage readings coming out of it using Speedfan.
+12 volts is fine, 3.33 is fine, and +5 volts are fine,
But the -12 volts reads -16.8 volts, and the -5 volts reads 1.68 volts.
Is that safe? or Okay? My computer runs fine, obviously but it's always been in the back of my mind ever since I built it.
It's a 600 watt OCZ Stealthxstream psu...
Phenom II x4 3.2 GHZ cpu.
Radeon HD 4870 Graphics,
Gigabyte Mobo, don't specifically remember the name but it's socket AM2+
Hitachi 500 GB Hard drive, 7200 RPM
and a SuperWritemaster Lightscribe DVD drive...
Ni idea if this is okay.
James
Fri Apr 08 2011, 06:38PM
I've seen Speedfan report some weird voltages before, I think it's more an issue with the motherboard than the software. Anyway if in doubt just measure the voltage directly with a multimeter. You can find the ATX connector pinout online and poke probes in the back while it's operating.
ConKbot of Doom
Tue Apr 12 2011, 01:54PM
-5v, thats cute. ATX standard removed the -5v line from the ATX connector in version 1.3, so I'd take any readings there with a large grain of salt.
the product specs dont list a -5v current rating either.
