  • Guests: 30
Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
PIC pin selection
mccoywm72
Thu Jan 13 2011, 09:56PM Print
mccoywm72 Registered Member #2042 Joined: Sat Mar 21 2009, 03:44PM
Hi guys. I am working my way through learning how to use the PIC family of microcontrollers and I have a question.
I understand the concept of initializing pins as inputs or outputs using something like the following
TRISC = 0b00000000;
or
TRISC = 0b11111111;
For this particular application I would like to be able initialize an individual pin something like
Pin.1 = input;
Pin.2 = output;
Now this initialization will all happen only once at the beginning of each program, so I realize I could use some methods of storing the values and putting them in one TRIS statement, and I'd love to get input on that, but I was just wondering if there was a method to directly access a single pin.
Thanks.
Lethal Shot
Fri Jan 14 2011, 08:10PM
Lethal Shot Registered Member #1623 Joined: Tue Aug 05 2008, 03:31PM
If I understand correctly you want to set a pin to input or output on runtime.
Depending on the language your using you could either use:
ASM:
bsf TRISC, RC(0 to 7)
C:
TRISC |= 0b(and then all zero's till you've found the one you wish to set) example 0b00001000
or
TRISC &= ~0b(same as above, but this code is to clear a bit)
mccoywm72
Fri Jan 14 2011, 09:04PM
Thank you for the response, perhaps if I explain the project it will help. Basically I am trying to make a PIC an Arduino (I know, deadly sin that I will be flamed for). This project has no other purpose than to learn more about the PIC and I felt it would be a good way to learn. So basically I am trying to replicate all the functions found in the Arduino software to be used on a PIC. Things such as digitalRead(), digitalWrite(), analogRead(), and pinMode().
pinMode() is the specific method I have a question for. Normally, the user would have something like the following.
void setup()
pinMode(1, INPUT);
pinMode(2, OUTPUT);
pinMode(3, INPUT);
So my method would need to do the following
TRISC = 0b00000101;
But the problem is how to keep up with what has been set. As you can see there are 3 separate calls to the pinMode() function.
Ideally my pinMode() would do something like the following:
pinMode(int pin_Name, int pin_State)
TRISC.pin_Name = pin_State;
This way I would be able to set each pin individually without haveing to keep refreshing the entire TRISC = 0b00000000
If there isn't a way to update a single pin, I realize I could do something with arrays[] storing all of the pin assignments and setting everything once.
Example psuedocode
pinAssignments[0,1,0,0,1,0,1,1]
TRISC = pinAssigments[]
This is just thoughts as the syntax wouldn't work, but hopefully my point is getting across.
Hopefully I haven't rambled and made things even more unclear, but anymore input on either of the two methods described above would be appreciated.
Thanks,
Sat Jan 15 2011, 05:54AM
For this particular application, you could probably get away with the way that arduino does it,
void pinMode(uint8_t pin, uint8_t mode)
	uint8_t bit = digitalPinToBitMask(pin);
	uint8_t port = digitalPinToPort(pin);
	volatile uint8_t *reg;
	if (port == NOT_A_PIN) return;
	// JWS: can I let the optimizer do this?
	reg = portModeRegister(port);
	if (mode == INPUT) {
		uint8_t oldSREG = SREG;
                cli();
		*reg &= ~bit;
		SREG = oldSREG;
	} else {
                cli();
		*reg |= bit;
		SREG = oldSREG;
The method you are using seems like it has roots in Java or other object oriented languages, things are done differently in C. Bitwise operations will be you friend for this job.
Lethal Shot
Sat Jan 15 2011, 07:17PM
In what language are you programming?
The codes I posted will do what you want to do, but if you would like to have more info about them please tell me in which language you program.
mccoywm72
Sat Jan 15 2011, 09:49PM
Haha I see my "TRISC.pin_Name = pin_State;" has given away my object oriented background.
This is my first real jump into the wonderful world that is C, so I have much to learn. Doing a quick search, it looks like a lot of that code uses other functions written by the Arduino team. Am I correct in assuming this? If that is the case, I am a little unclear as to how the code snippet works and would greatly appreciate a quick walk through on how it is working.
@Lethal Shot
I'm programming in C, specifically the MCC18 C compiler in MPLAB
I understand the use of TRISC as you have explained it, but doing it like that would require me to keep track of what pins were already set.
For example if I had a a switch statement within the pinMode() such as
pinMode(int pin, int state)
switch(pin)
case 0:
if(state==1)
TRISC = 0b00000001;
else
TRISC = 0b00000000;
case n:
//same thing just different port
That would allow me to pass a pin number and pin state, but the problem comes in when I do this
pinMode(1, 1);
pinMode(4, 1);
as this would have the final setting of
TRISC = 0b00010000;
Only setting pin 4, instead of the desired pin 1 and pin 4.
So is there a built in way to just update a port with a new value or would I need to create one?
Example
TRISC = 0b0001000;
update to
TRISC = 0b00010100;
thanks for all of the help thus far guys.
Sun Jan 16 2011, 09:13AM
yeah, i use something like this in assembler.
Takes longer to code but gives you total control of the pins in realtime.
regards, -A
#include "Donate_to_4HV_please_kthx.h"
Bjørn
Sun Jan 16 2011, 11:04AM
You can do like Lethal Shot explained (Remember that setting a bit to 1 sets the pin to input):
if (state == 1) {
TRISC |= 1 << pin;
} else {
TRISC &= ~(1 << pin);
But this has a side effect. |= is a read-modify-write operation, a TRIS register is not guaranteed to return the same value as was last written to it (explained in the datasheet that has a diagram of the circuit). So a read-modify-write operation has the possibility of changing more bits than the one you wanted to change.
If it is documented it might be ok, but for a general library the sensible thing would be to use a static variable of some sort to keep a copy of the TRIS value.
mccoywm72
Mon Jan 17 2011, 06:54PM
Thanks guys. I'm having some success using your suggestions.
Apologies to Lethal Shot, you quickly gave me the answer but I overlooked it.
As it is now, I have implemented a delay(), pinMode(), and digitalWrite(). Next will be digitalRead(), analogRead(), and analogWrite().
Right now, I am writing all of these methods in a header file (Arduino.h) and #include Arduino.h is in another file called program.c
So program.c looks something like
void main()
pinMode(1, OUTPUT);
pinMode(4, OUTPUT);
while(1)
digitalWrite(1, HIGH);
delay(250);
digitalWrite(1, LOW);
delay(250);
Is this the accepted way to pull something like this off? Specifically putting all of the functions in a header file should give me the ability to include it in any future projects correct?
Thanks
Lethal Shot
Wed Jan 19 2011, 08:03PM
Many code is written like this.
It is not uncommon that functions or blocks of code that are used often are gathered in a header file.
This speeds up programming and improves readability of code.
However this has 1 drawback. Usually code like this has some extra checks in to make it multi-functional (a delay that is variable for instance).
So for very time critical software or software that is just able to run on the processor, the macros will kill you code effiency.
But as long as you create programs that are well within the limits of the PIC your using, this way of coding is just fine.
1 question though, I understand the functions 'digitalRead()' and 'analogRead()', but how are you going to pull 'analogWrite()' of without any external circuitry?
The only way I can think of that a PIC can do that is with a R2R ladder, a filter with PWM output or an external DAC.
