  • Guests: 58
mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
06/05 jmorlockny (50)
I have problem where no programs will open
colin heath
Sat Jan 15 2011, 03:08PM Print
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
Hello All,
I know this isn't a pc help section but know that you lot really know how to get things done and i can trust the responses;-)
I stupidly downloaded (and paid!) for a file sharing program hoping to get some plc programming software for free. well lets just say I wish I hadn't! It was from unlimited downloads and has filed laptop with viruses and trojans. I have malware program but it removes them then reboots pc upon which the viruses are back. I have installed norton 360 but won't let me open any anti virus programs to fix. also wont let me open IE explorer etc. this applies even if I open from task manager. I have tried holding dowen ctrl when clicking run program in task mng but the dos box opens then closes almost immediately. I have manged to delete program which I dowloaded viruses with but thats it.
ANy help would be much appreciated and if solved promise to go donate to 4HV cheesey
Thanks,
Colin Heath
Sat Jan 15 2011, 03:42PM
Hi Colin
See this thread: Link2
The most powerful tool I found for getting rid of trojans is Process Explorer.
Lethal Shot
Sat Jan 15 2011, 07:24PM
Lethal Shot Registered Member #1623 Joined: Tue Aug 05 2008, 03:31PM
If you know the filenames of the virusses or trojans (these may be found with help from process explorer) download the program moveonboot.
This program is really great. I've used it multiple times to get rid of nasty trojans/virusses which ordinary scanners could not remove.
The program is basically a very small OS that starts before windows starts, thus allowing to remove/rename/move any file you want.
So far no virus I've encountered survived a removal this way.
colin heath
Sat Jan 15 2011, 07:44PM
Thanks for the help people. I am only a PC user so hae no experience with the background processes so some of this may be too advanced for me.
I will try the last one sugested and see how this goes. Funny thing is malwarebytes is picking up no threats now but still same problem with not being able to open AV, add remove programs or IE etc.
Gunboat
Sun Jan 16 2011, 03:16PM
Gunboat Registered Member #338 Joined: Thu Mar 23 2006, 12:28PM
There is another "FREE" program out there that works really great.It is called Super Anti-Spyware,constant updates,I also run zonealarm and adaware,have been for years now,with no problems,even when I DO D/L something that is malisious.
Zack
Fri Jan 21 2011, 03:14AM
Zack Registered Member #3624 Joined: Mon Jan 17 2011, 01:08AM
You might want to use an external drive to back up your data and then wipe your os to its factory setting.
