  • Guests: 41
Kolas (18)
Dillon4DynamicHarmonics (41)
12/25 Kolas (18)
12/26 buxtronix (50)
8-Bit PIC Code Memory
wpk5008
Wed Jan 05 2011, 03:23AM Print
wpk5008 Registered Member #3546 Joined: Tue Dec 28 2010, 08:24AM
I have this terrible tendency to try to make things not suitable for 8-bit PICs. I also only program PICs in assembly; I know what you're going to say.....
Anyways I have a small problem. When I write my programs I have a tendency to go over 256 lines of code. This is fine because from my understanding the PIC16F8xx family that I typically use has four times this code memory. Unfortunately if your code goes into one of the later program code banks and you attempt to adjust the code line for something such as a look up table it throws me into that location in the first bank. How do I ensure that I stay in the second or third or four memory bank without having to leave all my look up tables at the top of my code. Honestly I asked my professor that question and he didn't know how, hopefully one of you guys has figured this problem out in the past.
Bjørn
Wed Jan 05 2011, 03:54AM
Look up the ORG control directive, it will set the program origin and any code after that will follow the address defined by the org statement.
Wed Jan 05 2011, 09:42AM
Lookup tables that cross page boundaries are a classic PIC f***-up. Using the ORG statement helps, but you also have to set the high bits of the program counter appropriately.
Once you've started playing with PCLATH, you also have to save it and restore it in your ISR, if you're using interrupts. (Took me a long time to figure that one out.)
Here's part of a lookup table routine I wrote earlier, for a keyboard scanner implemented on a PIC16F870. It shows most of the techniques you need for a reliable LUT, even a simple bounds check with the "andlw 0x3f". (the table is 64 entries long)
To clarify, you can place this code in any bank and call it from any other bank using "call kblut". The call instruction pushes the full program counter on the stack, not just the low 8 bits, so the page you were in gets remembered. The "retlw" instruction in the table will send you back to the one after the "call".
This one doesn't take account of page boundaries within the table itself. So it's limited to about 250 entries, assuming you position it at the beginning of a page with the org directive. Microchip have an app note somewhere that shows how to do longer ones.
kblut	org	0x300
	movlw	HIGH(kblst)
	movwf	PCLATH
	movf	ksbuff,W
	andlw	0x3f
	addwf	PCL,f
kblst	retlw	0	; padding
; table proper
	retlw	0
	retlw	0
	retlw	0
	retlw	0
	retlw	0
	retlw	0
	retlw	0
	retlw	0x5f
etc
wpk5008
Wed Jan 05 2011, 06:30PM
I didn't realize that you could simply add org statements into the code like that, or at least I have never seen that done before? I figured it had something to do with the PCLATH register too but I just wasn't sure how to use it. Thank you for that example McConner.
