Mwahaha.... Vacuum tube thumb drives
Sat Jan 15 2011, 08:02AM
Registered Member #96
just found this ideal gift for all those budding mad scientist wannabees.
sounds a bit impractical, the glass would last about five minutes in "normal" use. You can get some very small USB to microSD adaptors over here from Poundland, they aren't much bigger than the connector. EDIT:- fill it with clear casting resin then place under vacuum while resin is liquid and this would look better..
I might have a dead nixie tube somewhere which is gassy.. -A
[Edit: Topic changed to be clear and concise according to the rules.]
