  • Guests: 27
07/09 Avi (41)
07/09 Jannick Hagen (15)
07/10 Sparcz (69)
CSU Chico Tilt Rotor Flying Machine, (Programming and CPU, 3 of 3).
1 2 3 4  last
Thu Mar 29 2012, 01:09AM Print
Related Web Sources:
Servo control using STM32VLDiscovery Link2
I have 2 ESC's and 2 servos, all require the normal servo PWM. the ESC's at 50 Hz PRF, the servos at 300HZ PRF.
code from the above link im trying to figure out:
// STM32 4-channel Servo Demo for 24 MHz VL Discovery - **link**
#include "stm32F10x.h"
#include "STM32vldiscovery.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void TIM3_Configuration(void);
volatile int servo_angle[4] = { 0, 0, 0, 0 }; // +/- 90 degrees, use floats for fractional
void TIM3_IRQHandler(void)
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
// minimum high of 600 us for -90 degrees, with +90 degrees at 2400 us, 10 us per degree
// timer timebase set to us units to simplify the configuration/math
TIM3->CCR1 = 600 + ((servo_angle[0] + 90) * 10); // where angle is an int -90 to +90 degrees, PC.6
TIM3->CCR2 = 600 + ((servo_angle[1] + 90) * 10); // where angle is an int -90 to +90 degrees, PC.7
TIM3->CCR3 = 600 + ((servo_angle[2] + 90) * 10); // where angle is an int -90 to +90 degrees, PC.8
TIM3->CCR4 = 600 + ((servo_angle[3] + 90) * 10); // where angle is an int -90 to +90 degrees, PC.9
int main(void)
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
TIM3_Configuration();
while(1)
// Insert code here to stroke your servos
// clock for GPIO and AFIO (Remap)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
// clock for TIM3
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
NVIC_InitTypeDef NVIC_InitStructure;
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
/* Enable the TIM3 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
GPIO_InitTypeDef GPIO_InitStructure;
// PC.06 TIM3_CH1
// PC.07 TIM3_CH2
// PC.08 TIM3_CH3
// PC.09 TIM3_CH4
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE); // Remap to get signal on PC.06-09
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
// Simplify the math here so TIM_Pulse has 1 us units
// Use (24-1) for VL @ 24 MHz
// Use (72-1) for STM32 @ 72 MHz
TIM_TimeBaseStructure.TIM_Prescaler = 24 - 1; // 24 MHz / 24 = 1 MHz
TIM_TimeBaseStructure.TIM_Period = 20000 - 1; // 1 MHz / 20000 = 50 Hz (20 ms)
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
// Set up 4 channel servo
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 600 + 900; // 1500 us - Servo Top Centre
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM3, &TIM_OCInitStructure); // Channel 1 configuration = PC.06 TIM3_CH1
TIM_OC2Init(TIM3, &TIM_OCInitStructure); // Channel 2 configuration = PC.07 TIM3_CH2
TIM_OC3Init(TIM3, &TIM_OCInitStructure); // Channel 3 configuration = PC.08 TIM3_CH3
TIM_OC4Init(TIM3, &TIM_OCInitStructure); // Channel 4 configuration = PC.09 TIM3_CH4
// turning on TIM3 and PWM outputs
TIM_Cmd(TIM3, ENABLE);
TIM_CtrlPWMOutputs(TIM3, ENABLE);
// TIM IT enable
TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
more code shortly...
Fri Mar 30 2012, 04:23AM
PID loops and Kalman filters...
ok ive found the "PID without a PhD" PDF, and other sources:
Link2 Improving the Beginner’s PID
Link2 "PID Without A PhD" (Pdf)
Link2 feed forward and velocity, acceleration.
Thu Apr 19 2012, 07:16AM
the Discovery boards:
1334819809 2431 FT136317 Sam 1377
Tue Jul 10 2012, 07:38PM
OK heres the list:
-- lets just talk about the pitch axis for simplicity, the other axis' will be parallel and similar anyway.
-- lets define the pitch axis as a "Y" axis, and nose up means positive above zero, while nose down means negative degrees below zero.
-- there are gyros in the kk board, but i dont have access to them or thier code.
-- i want to seperate navigation and stability, focusing only on stability for now. i want it to hover, well do more later
-- Ill keep my gyros 10 times slower than the kk's gyros, to avoid aliasing and or oscillating feedback.
-- ill post a schematic below of the control flow
1341952099 2431 FT1630 Flow
AndrewM
Tue Jul 10 2012, 08:34PM
I'm not going to look up the specs for all these board, why don't you make a simple post regarding your plan?
What is a KK board. Its expecting servo PWM input... so this must be some kind of off the shelf gyro?
If that board isn't controlling your stability adequate... why are you using it? I'm not sure I follow the logic of having a micro running a PID controller... feeding into an off the shelf PID controller.
Tue Jul 10 2012, 08:39PM
AndrewM wrote ...
i wasnt expecting anyone to do so.
AndrewM wrote ...
1341029308 2431 FT1630 Blackboard 1
well it doesnt seem to be worth a dam, we can get rid of it. all it does is take in a RC control from the human, pass it to a gyro stability program and spilt up that result to the serovs and fans. Minsoo kim didnt put accelerometers on it so it cant hold it self level. for 240-350$ more i guess i could buy his lame upgrade, the black board which im using know cost me 140$ already.
what id like to do, since he won t answer my emails, is just to release an open source code here at 4hv that anyone could load on an STM32 board for $9-$25 then go fly. then yould need some spark fun orsimilar supplier of the imu, but still its cheaper and better.
AndrewM
Tue Jul 10 2012, 09:31PM
Yeah thats what I thought. I have a similar unit for fixed wing aircraft and it works pretty well... but I'd be pretty wary about dropping it into something like this. From your videos its just not up to snuff so I don't think adding another PID layer upstream is going to be a good solution.
So you basic sensor suite is... 3 axis gyro and 3 axis accel? And all of this is accessible by your STM32?
I think your basic case should be a stable hover... that is, all rates are zero and the angle of the gravity vector equals your user's commanded angle (ie. the stick position). You said in your other thread you want to control Pitch first (indeed I think that will be your toughest axis to control). So lets call pitch "θ"...
Proportional error:
E_p = θ_dot_gyro
Integral error:
E_i = θ_actual - θ_commanded
The derivative term is harder since you don't have a derivative sensor. You'll want to make sure you have nice clean data coming out of your rate sensor, otherwise your derivative terms can go nuts; if you can't clean the data then you'll want to implement a running average or something, depending on your sample rate.
To be honest I'd try PI control first... because I bet that even if you DO implement D control that it will be so noisy you'll need to turn the gain down to uselessness.
Then your loop output would be:
u = Ki * E_i + Kp * E_p
You'll need to write your equations of motion in order to determine how to use the u signal... but almost surely you'll want u to signal the motion of your fan angle servos together (ie. left and right side equally).
Wed Jul 11 2012, 12:11AM
AndrewM wrote ...
yep we'll ditch the KKmulticopter board, and move on.
AndrewM wrote ...
yep, i can access the gyro at 400 or 800 hz, and the accel at 400 to 2000 dps... this imu is fully under my control and coded right to the STM32.
AndrewM wrote ...
Proportional error:
E_p = θ_dot_gyro
Integral error:
ok, my brain is slowing...
AndrewM wrote ...
ok, well we can leave out the D term for now, but i was going to use a complimentary filter as suggested by big5824, to "de-noise" the signal.
big5824's site : Link2
1341966235 2431 FT1630 Rawdata1
raw data
1341966235 2431 FT1630 Filtered Axis2
filtered with complimetary scheme
AndrewM wrote ...
ok i see the above as a simple PI type deal, i can figure out how to code that, but what do you mean by "You'll need to write your equations of motion ..."
AndrewM
Wed Jul 11 2012, 12:40AM
Patrick wrote ...
Write equations for the pitch rate, θ_dot, in terms of the fan state.
For a PI controller it'll be simple, like:
θ_dot = F_fan * distance_to_c.m. / I_pitch
distance_to_c.m. will be a function of the fan servo angle... when you write that equation you should see immediately why steve and I told you to get your fans as far above the center of mass as possible.
When you have that equation you can model the system and simulate how to utilize the output of the loop, u.
Eventually when you implement a more complex controller you can add things to the EOM, like the acceleration of the fan servos; changing the fan angle will jerk the body of your craft around, for example. You can make the EOMs as complex as you like.
Also: keep in mind that you'll need a solution to correct your gyro drift - this is apparently where people have implemented kalman filters and the like. I haven't ever built a control loop like this so I don't know if its a necessity or a "nice-to-have." Seems to me that, as a first order attempt, a simple high pass filter on the gyro output before the controller should be enough to get things working...
Wed Jul 11 2012, 12:56AM
AndrewM wrote ...
Patrick wrote ...
ok i see what youre getting at with the equation now.
are you meaning dot product for theta_dot?
F = newtons
dist = meters
what units are I_pitch? is that an angle?
a projection of one onto the other?
1 2 3 4  last
