Mystery Photos from TDU
Tesladownunder, Sat Jun 03 2006, 12:22PM
I seem to have generated a number of photos that are strange out of context.
Any thoughts on this one for starters?
Peter
Re: Mystery Photos from TDU
Bjørn, Sat Jun 03 2006, 12:37PM
My guess is a rotating drillbit and water. It looks quite mystical and I had to twist my brain to come up with that idea.
I see a doughnut shaped light source, is it a macro flash?
Tesladownunder, Sat Jun 03 2006, 12:58PM
No, sorry. It would have to be water with cornstarch like properties with velocity dependent viscosity any way for it to stick to the rotating bit like that.
The central "thing" is stationary and a little out of focus. Standard flash but there was no significant movement anyway.
Peter
Dave Marshall, Sat Jun 03 2006, 01:17PM
I have two theories.
1) A drop of water being drawn up to a charged electrode off of a metal surface.
2) Something epoxied to a metal base
Dave
Plasmaniac, Sat Jun 03 2006, 01:26PM
Does it have to do with high voltages? Maybe you have some kV on that stick. Is it normal water? Or de-ionized stuff?
Bjørn, Sat Jun 03 2006, 01:28PM
The current post is here
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?10694, I am not sure how that got mixed up but I don't really trust the forum software until I have clicked refresh a couple of times.
I have seen water do the stragest things, especially on small scales so I would not be too surprised. What is causing the doughnut reflections, a lamp?
My next guess qould be that it is a 2 mm diameter electrode and there is a current.
Wilson, Sat Jun 03 2006, 01:53PM
Its not just a drip of water falling down the rod into a metal tub, captured *just* after it hit the surface is it? Perhaps a liquid more viscous than water....
Michael W., Sat Jun 03 2006, 02:14PM
Pretty Sure its Peters Strange HV/water effects shown on his page...
"There is no sparking since pure deionised water is an insulator. The mutual attraction of opposite charges creates a spike rising up from the water to meet the electrode. Almost ferrofluid like. The yellow tip is a reflection of the yellow base which is my theme background colour in most of my photos. This spike is stable although there is a moderate water flow around it. Wire width is 0.09 inch (2.2mm). "
Edit:
Never mind I just saw the other post about the strange water effects, I guess I was right anyway....
Tesladownunder, Sat Jun 03 2006, 02:15PM
You are getting the idea
This is from a different angle using deionised water which insulates and is attracted to the upper electrode.
Peter
Now the next photo.
Mystery Photo 2
uzzors2k, Sat Jun 03 2006, 03:09PM
Is it a uranium marble under UV light?
Tesladownunder, Sat Jun 03 2006, 04:38PM
Yeah, too easy.
Pic shows standard lighting of the UV marble and the bubble imperfections.
Next Mystery photo should be easy too. Estimate the altitude it was taken at as well.
Peter
EN, Sat Jun 03 2006, 05:18PM
I would guess that photo was taken from about a meter over your swimming pool after pouring some LN2 into it :)
Tesladownunder, Sun Jun 04 2006, 12:46AM
I suspect the smart punters are looking at my web site (or have Google Earth and can see my pool).
Yes it is LN2 taken from the stated altitude.
Complete pic below.
I have actually put virtually all of my best photos on my site (640 of them) and/or on 4HV.
Next mystery photo.
Electroholic, Sun Jun 04 2006, 02:00AM
Ha, I remember this one. The failed defibrillator cap, right?
Bored Chemist, Sun Jun 04 2006, 08:45AM
"There is no sparking since pure deionised water is an insulator"
No, it's not.
It's a poor conductor but a conductor nevertheless. It would be a real pity if someone were to get electrocuted because they relied on water as an insulator.
Interesting set of pictures though. My guess at the first one would have been a wire electrode sealed through glass like the anode of a rectifier tube (and I'd have been hopelessly wrong).
Dr. Shark, Sun Jun 04 2006, 10:17AM
Bjørn Bæverfjord wrote ...
Nope, thats what photographers call "bad bokeh" and comes from a point-shaped out-of-focus lightsource, that is imaged with overcorrected spherical aberration. The effect is especially pronounced with mirror lenses, but to a lesser extend with any other lens.
Bjørn, Sun Jun 04 2006, 11:19AM
I have several lenses and none of them have a bokeh remotely similar to that.
It seems to me that the picture is taken with a normal AF-S Nikkor 18-70mm lens and I have never been able to get any doughnuts from it. Did you use that lens Peter?
Tesladownunder, Sun Jun 04 2006, 12:19PM
Bored Chemist wrote ...
No, it's not. It's a poor conductor but a conductor nevertheless. ...
It has a higher breakdown than air in the current situation so effectively it is a pretty good insulator. I hope to do more experiments later.
Yes, I use the standard AF-S Nikkor 18-70mm lens. Hoped to get a new one but don't think my accountant would agree.
In fact I hadn't looked closely at the photo until now and didn't notice the circular light reflections which I have not seen before. I wondered if it might have been a reflection of the magnet just below the surface which is just out of view in front. I've not seen it before. The Nikon flash is a short linear lamp.
Electroholic wrote ...
Correct. I thought people would forget. It is actually one of my better shots to capture sparks in a dynamic shot.
OK Next Mystery photo is one is not one of mine but is a remarkable photo.
Peter
the_anomaly, Sun Jun 04 2006, 12:43PM
A giant mutant space ship com to get us!
Was it taken on a microscopic level? Looks like some kind of virus cell.
Bjørn, Sun Jun 04 2006, 12:46PM
My guess is a nuclear detonation, it seems to radiate light. It looks most peculiar.
Alessandro, Sun Jun 04 2006, 12:50PM
Ah, that's easy, an atomic explosion a few milliseconds after detonation. You can clearly see the spikes caused by the support wires on the tower.
ragnar, Sun Jun 04 2006, 01:18PM
I was about to say it's looking down the back of a throat, or an artery, or something... but seriously, if you were looking down my throat, I've been known to 'explode' at various people spontaneously... hehe
c4r0, Sun Jun 04 2006, 01:18PM
Looks like an x-ray photo of sth ...
Electroholic, Sun Jun 04 2006, 03:48PM
is it the first few whatever nanosecond of a nuclear explosion?
Dr. Shark, Sun Jun 04 2006, 03:57PM
Sorry, I didn't know you were into photography. Excuse my baby-talk tone. There is a kind of cross-eyed feel to the whole image, as if it was taken with a mirror lens. Since Peter was messing around with water, could it have been a water drop on the front element, that caused this "mirror-lens" effect?
uzzors2k, Sun Jun 04 2006, 04:13PM
Nuclear explosion.
Tesladownunder, Sun Jun 04 2006, 08:13PM
The shots are from the first 1mS after a fission explosion with a 'shutter speed' of 10nS.
The
Rapatronics camera used a Kerr cell which is an electro-optical device to rotate plane of polarisation a bit similar to the Pockels cell used for Q-switching lasers. The camera was 7 miles away. The wires vaporise and ionise under the intense radiation more readily than air at that stage and distance and form the classical 'rope tricks' (early version of string theory, I suppose).
joe wrote ...
... Excuse my baby-talk tone. ..... Since Peter was messing around with water, could it have been a water drop on the front element, that caused this "mirror-lens" effect?
"..messing around with water.."
No I didn't splash the lens. I regard it as a holey visitation.
Next Mystery photo is one of mine. A little more sedate this time.
Peter
Self Defenestrate, Sun Jun 04 2006, 10:47PM
The shot is reflected off a fragment of a CDROM (Mario teaches typing - see his eyes). This gives a central reflection and first order diffraction with the ultraviolet being closer and the red diode beam being farther from the central reflection .
Wouldn't happen to be a nitrogen laser with a red laser diode angled in, would it?
Alessandro, Sun Jun 04 2006, 11:01PM
Yep,
TDU, give us some new images, we already know the answers to all the others....
Tesladownunder, Sun Jun 04 2006, 11:43PM
New images. Hmmmm
All right then.
Mystery photo. What has this to do with HV? How many times has it happened in my life?
Peter
McFluffin, Sun Jun 04 2006, 11:54PM
Appears to be a bar of soap mashed into some tile.
Tesladownunder, Mon Jun 05 2006, 01:51AM
The answers I wanted were
1: Nothing to do with HV
2: I have only ever dropped a sliver of soap while showering and have it land on it's edge and stay there, twice in my life. It's probably one of those Schrodinger's cat quantum improbability things...
Mystery Photo 11
Nik, Mon Jun 05 2006, 02:08AM
I can read the lettering and it seems to make sence that you would have somthing from that company but I cant find any info on the object itself.
Electroholic, Mon Jun 05 2006, 02:09AM
Tritium? like those for watches or rifle scopes?
Tesladownunder, Mon Jun 05 2006, 03:22AM
It's a
tritium containing keyring. Glows for 10 years. It is radioactive with a count something like twice background if I recall. I've had enough kids, so I can use it as a keyring and keep it in my pocket
Cost AUD$20 on eBay from the UK. Radioactive imports. Hmmmm..
Next is a very quick one. Which is the red laser?
Peter
..., Mon Jun 05 2006, 03:46AM
I would assume it is the one on the right since the radation is pointing to the left...
Electroholic, Mon Jun 05 2006, 05:27AM
I agree with ...
is that dry ice?
Bjørn, Mon Jun 05 2006, 05:58AM
Tesladownunder wrote ...
Just to show that lightning strikes twice, even if it is on the opposite end of the world. I picked up some parts from my desk and this diode was left standing. I will never see anything like it happen again.
Mike, Mon Jun 05 2006, 06:56AM
I would say the right laser since the hole on it is red, while the outside of the case is green.
Tesladownunder, Mon Jun 05 2006, 07:52AM
..but I was naked. Were you
The lasers were obvious once you think about it but I almost labelled it wrongly. It is highlighting some aerogel but it wasn't up to scratch with clarity so wasn't used. Since everything was on my desk in front of me, I took a better shot.
The dirty hands are from taking apart a laser photocopier. After I finished and had discarded the junky bits, I thought "but where was the laser?"
Peter
Bjørn, Mon Jun 05 2006, 08:08AM
No, I have a rule that I never solder in the nude. It is not based on experience but from extrapolating different events.
ragnar, Mon Jun 05 2006, 08:26AM
Hope it's one of those newer "non-carcinogenic tonier" lasers... or you washed your hands soon after =)
Last time I dismantled a laser printer, I found there is an array of laser diodes (one long line of them) along each toner cartridge. SO many TINY gold contacts, SO many TINY bits of glass...
Absolutely tiny, and probably unusable. I had to strain to see the bits with my naked eye. =)
Tesladownunder, Tue Jun 06 2006, 06:43PM
Next Mystery photo is not one of mine.
Bjørn, Tue Jun 06 2006, 06:59PM
A balloon that explodes, differences in density of the air causes refraction. In the lower left corner you see the microphone that triggered the photograph as the sound from the ballon reaches it.
By using a LED and a candle you can see the effect, I did it a couple of days ago.
Steve Conner, Tue Jun 06 2006, 09:48PM
Do I get geek points for knowing that it's called a Schlieren photograph?
Bjørn, Tue Jun 06 2006, 09:54PM
Yes, at least 5 points. I forgot the name a decade ago and google returned nonsense.
Tesladownunder, Wed Jun 07 2006, 12:51AM
Here is the
full article which makes interesting reading with the new techniques of a reflective grid and colour filters which allows large areas and outdoor shots.
My favourite
amateur Schlieren site and one of my all time favourite but little known sites is
Rapp instruments. Site is only in German but he makes beautiful stuff. All my stuff looks like junk compared to his.
Photo is another from that site and shows the muzzle and bullet's shockwave at Mach 2.5
Peter
Tesladownunder, Fri Jun 16 2006, 05:08PM
Time for another Mystery Photo.
Peter
Jim, Fri Jun 16 2006, 06:30PM
maybe a water arc projected onto the wall
Tesladownunder, Sat Jun 17 2006, 01:02AM
Well, 60 people have looked at this and only one reply. Keep guessing and I will keep giving photo hints. They were pics I took last night.
Here is another in the series. Don't be scared now
Peter
Bjørn, Sat Jun 17 2006, 01:46AM
The object at the bottom is an opened Coke can. The light source has ray like structures like it was a point source of some sort, like a laser or two.
Nik, Sat Jun 17 2006, 02:07AM
You beat me too it, I was going to say a laser going beign defracted (i think thats the right word). Like how they make holograms.
Tesladownunder, Sat Jun 17 2006, 02:38AM
The laser is my argon multi line one accounting for the green and blue mosaic of dots of light when the beam is diffracted with a bit of hazy polyethylene sheet and projected onto a 4 foot diameter polystyrene disc (packing cover for a table).
Here is a couple of photos including the effect of adding a 10mW HeNe red laser similarly set up which gives the irritating effect of those old 3D pictures to be viewed with blue and red cellophane glasses. Any one got one to see if there is a 3D effect?
I am staring into a 40mW laser here. Can you see the smoke coming off my
retinas?
I chose last night as the air was smokey from some recent controlled burning so shows the beams well.
So what was the original mystery photo?
Peter
benbradley, Mon Jun 19 2006, 03:54AM
I've got a mystery photo, and it IS on topic (I'll tell what it is in maybe a week or so). I took this photo myself, the two big things are ordinary standard-size pushpins for the old-fashioned cork style bulletin boards, available at any office supply store.
I'm just posting a link rather than including the pic in the page, as it's a big pic (it sort of has to be, for you to see it):
Two questions: What are they, and how many do I have? I have many times the quantity shown in this pic, and it's possible to answer both questions with info freely available on the Internet (well, at least it is for the second one, once you have the correct answer to the first).
Desmogod, Mon Jun 19 2006, 04:08AM
benbradley wrote ...
Considering the topic is mystery photos from TDU, I highly doubt that.
Bjørn, Mon Jun 19 2006, 05:50AM
Was the original mystery photo a soap bubble?
Bored Chemist, Mon Jun 19 2006, 06:08AM
ferrite core store beads?
Steve Conner, Mon Jun 19 2006, 10:12AM
Yea, I'll vote for ferrite cores too, and it looks like you have about 4096
Richy, Mon Jun 19 2006, 11:49AM
Hi TDU,
In your original pic at the top looks like a bass drum pedal so I'm guessing it was your laser difracted through a bass drum skin?
Richy.
Michael W., Mon Jun 19 2006, 02:09PM
Could those be the raw plastic pellets that the push pins are formed from?
Tesladownunder, Mon Jun 19 2006, 02:51PM
For anyones information, TDU is the popular abbreviation for Tesladownunder. First time I've used it though.
The Mystery photo with the blue green laser background showed a central area which seemed to be enlarged. It was in fact me holding a simple lens at just the area where the enlargement covered the shadow of the rim of the lens. The lens was supported by a plastic tie which I was holding between two fingers.
Peter
Billybobjoe, Fri Jun 23 2006, 04:52PM
My turn - what is this:
Marko, Fri Jun 23 2006, 04:59PM
Nick T. wrote ...
posthumous remains of flat cable?
Electroholic, Fri Jun 23 2006, 10:15PM
looks more like speaker cables
melted together, the whole spool, just fused together.
then you some how cut it in the middle and take the core out?
Billybobjoe, Fri Jun 23 2006, 11:43PM
Can't get much closer than that - its speaker cable I used to rewind a MOT sized transformer with and it shorted itself, melted together, than I cut it off the core. Its actually convienent now because I can pull off the wires that aren't burned (just heated a bit so they stick together) and use them as temporary low voltage leads.
benbradley, Sun Jun 25 2006, 03:06AM
Considering the topic is mystery photos from TDU, I highly doubt that.Maybe you got me, though I was thinking of the topic of the BOARD, that being General Science and Electronics. It could possibly be Computer Science, though certainly not for MODERN computers.
Yea, I'll vote for ferrite cores too, and it looks like you have about 4096 Okay, can't sneak much by you guys, but these are amazingly small and I thought that might fool you. I've never seen cores that are anywhere NEAR as small as these. These are approximately .030 inch outside diameter, much smaller than I expected when I ordered them. There's a date on the package of 1981, so these may be the last (and smallest) ferrites made for computer memory storage. I was hoping to wire up a few but I can hardly even SEE them. I guess I'll keep these, but I'll have to order some larger ones if I can find them.
Quite frankly, I didn't believe I would actually get the quantity the seller stated. I haven't counted them (!) but it looks in the ballpark. I suspect the quantity in my pic is likely in the 10,000 to 50,000 range (remember these are piled up around the pins), and that's no more than ten percent of the pack I poured it from. I have a total of 1.8 million (three packs of 600,000) from this eBay auction:
Could those be the raw plastic pellets that the push pins are formed from?Nope.
..., Sun Jun 25 2006, 04:05AM
kind of amazing... That whole bag of ferrite beads, the whole lot of them after being wired up into a module costing soo much, is like 5% of a floppy disk
and to try to sorta keep this thread somewhat on topic...
We need more pics TDU
Electroholic, Sun Jun 25 2006, 07:07AM
i just gutted a SMPS, and I found some slightly larger ferrite beads (2mm OD) on the leads of some dual diode. see if i can get some pix later...
what are they for?
Tesladownunder, Sun Jun 25 2006, 08:19AM
... wrote ...
We need more pics EVR
Err.. TDU?
Having a rush job doing some stuff on the Uni can crusher but here is a quick one from a few moments ago.
Mystery Photo 21
Peter
Tesladownunder, Thu Jun 29 2006, 03:51PM
So no guesses for the last post (mystery photo 21)
So one more chance. While you think about that I have this one.
Mystery photo 22
Peter
..., Thu Jun 29 2006, 07:56PM
the first one looks like a piece of sch80 pvc pipe with a film of blue pvc solvent weld glue across another piece inside it.
The second is a long exposure of a red HeNe and some blue LEDs... The HeHe is being relected off a speaker onto a moving screen. The leds were dragged throught the exposure.
Tesladownunder, Fri Jun 30 2006, 12:33AM
WRONG (it was schedule 40)
Well OK you were sorta right...
Yes it was a 4 inch TC secondary. The end cap was a little oversized so extra lake of PVC solvent. The irregular outside rim was masking tape to hold the wire end.
Second photo is half right. It is a diode laser (not HeNe) on a long exposure. The blue lights are 4 LCD screens of a power supply. Any other suggestions as to how the pattern was made rather than a speaker?
Peter
..., Fri Jun 30 2006, 12:52AM
No fair adding tape arround the pipe to confuse me on the wall thickness
I thought the red seemed a little too dark to be your hene, you almost had me thinking the blue was your argon, but I decided that that was just too blue.
As to the pattern... It is much to regular to have been moved by hand... And the camera couldn't have been moving that much since the blue is pretty much strait... And I doubt that you found a way to move the background to make that pattern... Were you shining it off a spinning mirror at some weird angle?
benbradley, Fri Jun 30 2006, 04:01AM
... wrote ...
THe same seller now has an auction for 200 milllion cores (!!!), so now you CAN build that floppy disk emulator!
wrote ...
what are they for?
2mm appears to be over twice the diameter of mine, though earlier core memory may have used even larger cores.
But for a SMPS or most applications where a bead goes around a component lead, it's meant as a lossy inductor, to reduce the RF interference generated by the fast switching of the diode. I believe it's a somewhat different kind of material, still magnetic but with different properties than that used for core memory. If you google ferrite core and powdered-iron core you can find descriptions of materials used for various types of inductors and transformers.
Tesladownunder, Fri Jun 30 2006, 10:23AM
... wrote ...
The beam from a 5mW red diode laser is reflected by a mirrror on an instrument recorder amplifier that I found while dumpster diving at the physics Dept. This would normally drive a pen on a moving roll of paper (like a seismograph). It is 1981 vintage and has offset, gain and calibration controls. Full scale deflection seems to be about 0.1V and frequency response seems to go up to about 70Hz. Sadly I didnt pick up the second one.
The unit is fed from my frequency generator at about 70Hz and the result is a horizontal stripe. The circular motion is simply me rotating the camera by hand with a 1 second exposure. This brings out the sine wave character and also shows some additional sine wave superimposed on it.
The next mystery photo is at the bottom.
Peter
Tesladownunder, Sun Jul 02 2006, 03:15AM
Next Mystery photo.
You should all recognise the trees in my back yard by now.
Peter
..., Sun Jul 02 2006, 03:21AM
Eucalyptus
Tesladownunder, Sun Jul 02 2006, 04:23AM
"Ahh.. you have much to learn little grasshopper"
(Mr. Miyagi to Daniel-san in Karate Kid )
Methinks you see not the wood from the trees... (me)
Yes they are eucalyptus and some peppermint. Is that all there is of interest?
Peter
..., Sun Jul 02 2006, 04:58AM
Well there is that red thing in the trees... That is new
Looks like a personal flotation device to me
The bark on that pic and on the one of you in front of the exploding cap bank looks just like the ones in my back yard... Maybe you got some of the American diseased ones?
Tesladownunder, Sat Jul 29 2006, 08:00AM
The mystery red object was a can being shot 15 feet out of my latest can crusher. It was positioned so that the base was level with the center of the work coil so it will fire the coil in the air. The can is shortened however as shown in the photo.
Next mystery photo is a bit easy but a full explanation is needed.
Peter
Nik, Sat Jul 29 2006, 03:09PM
It's 2 rings interacting and a third in the back ground. It looks like a wide thin ring (slow moving) being warped by a fast movign fat ring. Have you gotten them to wobble yet? If you do they will occilate pretty quickly untill they hit something or dissipate.
Tesladownunder, Fri Aug 18 2006, 12:17AM
Here's another.
Peter
Electroholic, Fri Aug 18 2006, 01:42AM
im guessing an argon laser
looks like some kind of cave.
but i guess that the weird shadows are reflections off some trees.
Alessandro, Fri Aug 18 2006, 07:09AM
Laser "tunnel" effect with an agron laser. Looks like it was outdoors because the fog didn't fill the entire picture.
Tesladownunder, Fri Aug 18 2006, 05:32PM
Alessandro wrote ...
Correct and here are a couple of other shots.
This is one of my better displays. The effect is surreal with the swirling smoke patterns that form the tunnel. It takes up your complete field of vision and gives no external point of reference. It is particularly breathtaking when the tunnel slowly closes in on you and you disappear in a quantum singularity. Fortunately I reformed in a parallel universe shortly after.....
Peter
Avalanche, Tue Aug 29 2006, 05:04PM
Here's a mystery photo from the avalanche if no one minds
shouldn't be too hard to get this one.
Marko, Tue Aug 29 2006, 06:26PM
Interwoving a bunch of litz wires together with a drill..?
Avalanche, Tue Aug 29 2006, 10:56PM
You got it
I was making the wire for the secondary of my inverter transformer. There was 13 meters there, attached at the other end to a hook right inside the house
Tesladownunder, Fri Sept 01 2006, 06:44PM
Another photo I took tonight.
Peter
Avalanche, Sat Sept 02 2006, 05:25PM
Driving past street lamps with a long exposure? I dunno
Thomas, Sat Sept 02 2006, 05:40PM
Looks like the camera is on a tripod and a car with ford focus like lights is driving by.
Tesladownunder, Sat Sept 02 2006, 06:05PM
Actually it is a road train with the orange body outline lights up high, red tail lights lower and headlights lower. What I found interesting is the slight sine wave pattern on the lights. May be went over a bump or maybe just bouncing along a bit.
I was trying to get some moon shots but I wasn't quick enough and there was traffic on the highway. Exposure was 15 seconds.
This pic is a car.
Peter
This is the next mystery photo. Not too hard. Is a gas involved and if so, what composition?
Peter
Mystery 25
Avalanche, Sat Sept 02 2006, 07:25PM
A spark between 2 points, and I'll guess that the gas is roughly 78% nitrogen, and 20% oxygen...
Tesladownunder, Sun Sept 10 2006, 06:23PM
Yep, it was just an out of focus end-on spark shot which gave it a hazy plasma ball look. I had to step down the aperture to get all 3 inches in better focus.
And this one?
Peter
Marko, Sun Sept 10 2006, 06:44PM
high speed spark photo usng your rotary mirror
Tesladownunder, Sun Sept 10 2006, 07:19PM
I knew I should have posted this first before the other stuff.
So why is it green?
Why is it smeared and what is the significance ot the dark streak extending down from where the spark touches the top?
Then try this one. (harder)
Peter
Electroholic, Mon Sept 11 2006, 06:01PM
The rotating mirror never captured any photon from the top of the arc. postitioning error?
the light from the arc was dragged downward by the mirror, hence the smear.
Green, humm...from auto white balance? or Fe ions in glass/lenses?
adn the pic with an orange line
im guessing its a car passing by.
Self Defenestrate, Mon Sept 11 2006, 06:11PM
Fiber optic cable with a blue/uv led?
Nik, Mon Sept 11 2006, 07:04PM
It looks like a small HF streamer but I can't tell whats its from.
Tesladownunder, Mon Sept 11 2006, 08:30PM
The green colour is the result of autoexposure and I presume, auto white balance from a purple spark on a black background. I can do better manually but it takes longer and consistency is different between pics.
The missing gap in the smear of light where the spark is out of the picture suggests to me that the smear is an artifact from the brightness of the first spark rather than persistent ionisation along the spark path. Perhaps an edge of mirror effect or camera issue.
And the photo with the blue spark like light? Even though it is coming from a breakout point on the toroid, it is actually a blue LED that I taped on for focusing reasons on my spark setup. I already had one set up with a battery and just grabbed that for convenience.
Peter
Tesladownunder, Sat Sept 23 2006, 08:27AM
Next one
Peter
Penguin7471, Sat Sept 23 2006, 09:02AM
Its your rotating mirror and motor setup, and you've taken the shot with flash just when the mirror was facing the cam? Or maybe some kind of bright artificial light behind the cam.
I guess that would also explain the lens flare to the left of the mirror.
Bjørn, Sat Sept 23 2006, 11:22AM
It shows the CCD blooming problem of the Nikon D70 that causes vertical streaks. You usually need the sun or a flash to make it visible like that.
A great way to avoid that is to get an external flash and figure out how to use the wireless control. It the improvement from the internal flash is quite spectacular.
Tesladownunder, Mon Sept 25 2006, 07:41PM
A typical Australian road about 5 minutes from home. Something is not right but you have to enlarge the pic to see. It changes the whole interpretation.
Peter
Mystery 31
Self Defenestrate, Mon Sept 25 2006, 08:25PM
Electrostatic dust storm. You can see a whole bunch of tiny discharges inside the cloud.
Bjørn, Mon Sept 25 2006, 08:57PM
It is one of them roads where cars roll uphill...
There is only one beer can in the whole picture...
No, really it is night because there are star streaks in the sky. It looks interesting, a bit like luminous raindrops.
AndrewM, Mon Sept 25 2006, 10:21PM
I was going to say that there seems to be mains service to a clump of trees on the left...
Tesladownunder, Mon Sept 25 2006, 11:57PM
This photo shows same time, same place but with the car headlights on. Just not a 5 minute exposure.
See, I told you I was going to give you a lot of streaky star photos. It just happened to be (almost) full cloud cover last night.
Peter
Tesladownunder, Mon Oct 02 2006, 05:07AM
Mystery Photo 35
The wonders of eBay.
Guess the power of my DPSS green laser.
Peter
Alex, Mon Oct 02 2006, 06:28AM
I'm guessing it's 5 or 10mW, and you used a long exposure at night, hence the flat lighting and sky, and very thick and defined laser trace.
Tesladownunder, Wed Oct 04 2006, 01:00PM
Correct (5mw). This pic makes it clear. Even with moonlight, there is something not right about long night exposures. Maybe its the moon rocks spectral absorption.....
You can see the star streaks on the bigger photo which I have cropped to exclude on the smaller one. I used my
laser scanner to do that and left it on for about 2 of the 6 minutes of exposure.
The other clue was the shadow of the tripod from the kitchen window light seen near the base of the tree.
Next photo was taken by my camera phone on night mode taken when cycling home from from a fortnightly clinic in a nearby (45km) town. It would have been more dramatic with my good camera and a decent lens. What is going on?
Mystery 36
Peter
Steve Conner, Wed Oct 04 2006, 01:28PM
Err, that's the tree with mains service to it that Andrew mentioned, and it shorted out and caught fire?
Tesladownunder, Wed Oct 04 2006, 06:10PM
It is indeed a burning tree. Burning branches and leaves were falling off with big showers of sparks. Why is it burning? Electrical service along the road is visible in the photo but no branches to the tree (pun intended).
Peter
Electroholic, Wed Oct 04 2006, 08:29PM
Huge A55ed CO2 tube?
Tesladownunder, Sat Oct 07 2006, 05:17AM
When I first read that I thought "I haven't heard of an A55 tube"
The picture is simply a burning tree. Some one was burning off and the flames lit the tree but the original fire died down quickly. Was quite stiking at night.
Full pic shows the context.
Next is a piece of equipment. I didn't know what it was until I read the manual. One component has been removed.
So is it:
1 A Dalek
2 Recently declassified beam weapon
3 Other and if so, what.
Peter
uzzors2k, Sat Oct 07 2006, 03:08PM
Some pretty heavy-looking transformers in it, so I'll guess its a X-ray machine.
Marko, Sat Oct 07 2006, 03:13PM
It's an OMG deadly plasma light cannon. ^ ^
I fugure bunch of transformers and selenium rectifiers on bottom but have no clue for the thing on it. Plasma torch, welder
, some medical thingie..?
Electroholic, Sat Oct 07 2006, 06:32PM
a dalek with the organic matters vaporized!
Tesladownunder, Sat Oct 07 2006, 06:43PM
I was told it was an "ultraviolet coagulator" retired from a local hospital in the ? 80's before being sent to the Physics Dept to see if they could use it. It lay there gathering dust for years before a recent clean out and it passed to me.
It is actually a short arc Xenon source for eye lesion coagulation. A precursor to my YAG
ophthalmic laser as it were. Unfortunately, the Xenon lamp was removed. It is interesting because the output (the black tube) is on a finely balanced gimbal and can be moved 6 inches in all directions to allow it to be brought up to the eye. The whole xenon assembly moves as well.
3 phase power is required. The power meters give an idea of the power draw. Optics are by Carl Zeiss and lots of interesting stuff in there.
Next Mystery photo No 38 is one of those "wow" demos that you call the family out to see.
Peter
Electroholic, Sun Oct 08 2006, 07:11AM
end on spark view, with fog machine, also a red light sorce, leds/laser
Tesladownunder, Sun Oct 08 2006, 02:22PM
No fog.
A clue
Peter
Marko, Sun Oct 08 2006, 02:30PM
Looks like sparks are behind some piese of red plastic, don't know for illumination.
Another electrode seems to be outer circumference, water, or no electrode at all..?
Or is it a high-pressure ''plasma globe''?
Can be a lot of things...
G^3, Sun Oct 08 2006, 04:10PM
It kinda looks like a retina, but with sparks instead of blood vessels. Is it a balloon in front of some spark source?
Marko, Sun Oct 08 2006, 04:30PM
looks too round for a ballon...
Tesladownunder, Wed Oct 11 2006, 01:53AM
The photo was natural colour of sparks from the filament of a 10 inch incandescent globe to the front where I placed a small wire loop. Sparks were from my MO-SIDAC-IC setup which normally makes 4 inch sparks.
It had a reddish colour which came up well on a time exposure. The bright sparks in the middle are direct to filament but many of the other circular ones had surface tracking.
Next one
Mystery Photo 39
..., Wed Oct 11 2006, 02:42AM
holy crap you son looks like me
And where did you get the huge bulb?
No idea what the last spark picture is... From a distance it looks almost like a glowing liquid pouring out of something...
Tesladownunder, Wed Oct 11 2006, 03:58AM
... wrote ...
Most unruly youth look the same from this side of 50
Bulb was from a junk yard like many of my prized possessions. No metal value in a scrap yard so cheap.
Who said it was a spark picture
It certainly looks VERY much like my high speed Tesla spark shots of a streamer though with the multiple ring up sparks. But is it ?
Peter
Coyote Wilde, Wed Oct 11 2006, 03:27PM
If not, my guess would be something like insence/cigarrette smoke in a blacklight
Tesladownunder, Sat Oct 14 2006, 01:10AM
Mystery photo 39 which looked like a spark photo was just spider web on my tee shirt. I accidentally took a handheld exposure shot and there was some lens shake to account for the parallel images.
Photo shows the picture in context.
Next is Mystery photo 40.
Peter
..., Sat Oct 14 2006, 01:45AM
Piece of solder under high mag? I jsut say that becuase I have spent ~10 hours over the last 2 days staring into a u-scope while soldering laser chips down
For the first half of the day I could see crystal clear images of the chips whenever I closed my eyes
Electroholic, Sat Oct 14 2006, 02:51AM
some sort of high speed milk pouring?
Tesladownunder, Sun Oct 15 2006, 03:07AM
Cornflour pours but in a funny way. Because it doesn't tolerate sudden change it breaks rather than strings out in droplets.
Full pic makes it clearer.
More cornstarch pics
here.
Mystery photo 41 follows below.
Electroholic, Sun Oct 15 2006, 04:08AM
plasma+ferro fluid?
CT2, Sun Oct 15 2006, 10:16PM
flyback arc into a toroid magnet, possibly submerged in water?
Tesladownunder, Wed Oct 18 2006, 12:10PM
CT2 wrote ...
Yep. Photo rotated upside down to make it harder but I forgot that you people are looking at things upside down anyway
Photo makes it clearer. Supply is my MOT multiplier that delivers 10kV DC.
Last photo is Mystery photo 42. Natural colour, just cropped.
Steve Conner, Wed Oct 18 2006, 12:17PM
Is it the sun seen through mist?
Tesladownunder, Wed Oct 18 2006, 12:39PM
Thought you might have thought it was too round to be a balloon
It is actually taken through smoke from some preventative bushfire burns. It really accentuates the red colour unlike mist. I can't see any sunspots, presumably blurred out by the smoke.
Pic shows the context.
Next is a UFO caught blasting off. Or perhaps a high voltage clothes iron or you guess. Mystery photo 43.
Nik, Thu Oct 19 2006, 09:53PM
That one is also upside down, I think it is an arc to water.
ragnar, Fri Oct 20 2006, 03:34AM
Arc to water of opposite polarity? ^^
Tesladownunder, Fri Oct 20 2006, 03:17PM
Yep. This was just a funny shaped version of some
pretty photos.
Context is first pic below.
Mystery photo 44 follows.
Coyote Wilde, Fri Oct 20 2006, 08:07PM
cloud-to-cloud lightening?
Marko, Sun Oct 22 2006, 12:40AM
I already saw his lightning pics - the second one on his site is maybe a bit blurred but looks great. I used way shorter exposures - 8 secs for my pics, surely lots of clicks go wasted!
Tesladownunder, Sun Oct 22 2006, 03:50AM
It is lightning and the context is shown below.
I haven't taken lightning photos before and these stikes were so far away that no thunder could be heard perhaps 10-20km so detail is poor. At least it wasn't raining.
The sea shot were taken on the same night from a similar distance.
The best lightning show I have ever seen was from the 49th floor of a hotel in Melbourne. It was quite captivating as it moved across the city with very frequent strikes and the view was very clear.
Tesladownunder, Sat Oct 28 2006, 08:15AM
Mystery photo 45
Tetrafluoroethane, Sat Oct 28 2006, 01:27PM
Looks like a closeup of the rebound after something (probably water) was dropped in a pool of water.
muciek man, Sun Oct 29 2006, 12:35AM
looks like a ball of mercury photographed rollin across a surface
Tesladownunder, Sun Oct 29 2006, 01:54AM
It is a water droplet travelling down in the picture. It was taken as one of about 300 shots I took while doning the
Water drops walk uphill thread.
The drop is distorted as it has only just broken from the dropper tube. The streaky lights below it are the shutter which at 1/60 sec is still open long after the flash has taken the main shot.
Photo shows the context.
Peter
Tesladownunder, Wed Nov 01 2006, 11:02AM
I've scribbled over this in a paint program - right?
Mystery Photo 46
Chris, Wed Nov 01 2006, 12:11PM
I'd say you scribbled over it with a powerful red laser, in real life. Probably a long exposure shot at night.
Alex, Wed Nov 01 2006, 01:14PM
Looks like a night shot of someone waving around an LED.
Bjørn, Wed Nov 01 2006, 02:12PM
I think it is a long exposure night shot and one of those clip on LED flashers you put on bikes and kids.
Tesladownunder, Sun Nov 05 2006, 04:07PM
Yep, it's a bike flasher at night with a several minute exposure. I was hoping to get some nice spirals coming in from a distance at the end of the road but obviously had too much to drink....
I want to try to flash just my face to give a ghostly disconnected look sometime.
Next one is not too hard.
Mystery photo 47
Michael W., Sun Nov 05 2006, 04:27PM
A bee
Bored Chemist, Sun Nov 05 2006, 05:04PM
I'm not an expert, but I thought that end of a bee usually had a pointed sting.
(I'm guessing the yellow thing is compositae of some sort)
Marko, Sun Nov 05 2006, 05:18PM
Bee's sting is subtracted most of time.
The pic seems to be a honeybee deducing by color pattern.
Tesladownunder, Mon Nov 06 2006, 12:29AM
Bee is correct. Pic shows the full shot with a bit of wing visible.
Next is Mystery photo 48
Michael W., Mon Nov 06 2006, 12:47AM
An oddly shaped broach or some metal slag?
..., Mon Nov 06 2006, 01:44AM
A type of mineral, the pic is upside down.
Not sure what the stuff us called, I think it is made of some type of copper (but it could have been iron or something completely different)
Bored Chemist, Mon Nov 06 2006, 06:44AM
Bismuth?
Michael W., Mon Nov 06 2006, 03:07PM
Its Definatly Bismuth...
Tesladownunder, Mon Nov 06 2006, 06:24PM
It's Bismuth. That's how it crystallises with a pink/green sheen. It was not taken upside down, just lit from an angle that showed the colours the best.
Mystery photo 50
Electroholic, Mon Nov 06 2006, 07:25PM
project for 2nd year civil engineering?
Tesladownunder, Tue Nov 07 2006, 12:23AM
This was a school project (year 8) for my 13 year old. They each had to construct a "bridge" to span 80cm to support a weight using 100 kebab skewers, wood glue and cotton.
Picture shows it supporting 2 bricks (10kg) In the competition it supported 17kg with more distributed weights but the record was 23kg for the class.
Mystery photo 52 follows. The correct answer may need to give some figures for physical properties and some calcuations.
Peter
ragnar, Tue Nov 07 2006, 01:27AM
Wee, bridges. A while ago when I was in year11 doing engineering studies, for a class assessment we had to construct a bridge and model a truss analysis. Mine was made from quarter-inch cross-section balsa wood, and weighed 24 grams. It spanned 40cm and, when tested to destruction (add weights, wait 1 minute, add more, etc) held 39kg. = ~1600x its own weight.
Yay for K-trusses and more cheap thrills. =)
Nik, Tue Nov 07 2006, 01:49AM
The photo is of a tuneign fork that should resonate at 256hz but you dipped it in liquid nitrogen making it resonate at 260.6 hz. Also the coil it is vibrating over looks like it came from a small motor (posibly a microwave turn table).
Tesladownunder, Tue Nov 07 2006, 02:21AM
Correct, but can anyone work out how much stainless steel shortens with temperature and how much the bendy-ness (there is a better term for this) changes with temperatue to get an estimate of current temperature from the increase of resonant frequency?
Peter
Electroholic, Tue Nov 07 2006, 03:14PM
i think it highly depends on what kind of steel you have, although it is likely to be tempered high carbon steel.
Bored Chemist, Tue Nov 07 2006, 06:07PM
Well, if anyone who really likes maths is interested, this site
gives the physics for a single cantilever. A tuning fork is just 2 stuck together and then you need to convert the expression for the static load into the expression for the motion and get the resonance (I bet it's density dependent too) then see what effect the temperature has on the length, density, and Young's modulus of the steel.
(Of course all that requires you to register with the site's operators (It's free), so I bet nobody bothers to get the explicit equation for the frequency of a tuning fork.)
Alternatively, you could just say "forget it- even dropping the temperature bu 200 degrees barely affects the resonant frequency".
If anyone is still reading at this point they might want to google "quartz crystal microbalances".
Tesladownunder, Tue Nov 07 2006, 06:26PM
Looks like I'll have to work it out myself.....
Simple coefficient of expansion of steel would account for shortening of 0.000012/K for steel. Given room temp 24C and LN2 of -196C this gives a 220K range. Hence thermal expansion is .00264. This would on its own change frequency from 256 Hz to 256.67Hz. Clearly not the full explanation. Perhaps not even any explanation as shortening will be acompanied by increased density which may compensate ? fully.
So looking at the bendy-ness of steel. I guess this is Young's modulus and I suspect that this is the parameter that determines the vibration for a given force. The exact value is not important but the change with temperature is. This
site gives the modulus for low carbon steel as being 29.5 at 70F increasing to 31.4 at -325F (=-198K). This is a change of 6.4% which would give a frequency rise to 272.4Hz.
Since the observed frequency rise is only to 260.6 from 256.2 (1.7%) and interpolating, this suggests that the temperature of the fork at the time has risen to -34C.
There are many assumptions, particularly about the steel type. Perhaps my logic is way off.
Nevertheless the results are plausible. Using Google to look up tuning fork and liquid nitrogen reveals many poorly documented brief physics demonstrations. The only one that gave figures was my own site!
Comments welcome from real engineers or people who know stuff.
(Edit looks like Bored Chemist just beat me to post about this)
Next Mystery photo - also an easy one.
Peter
Wolfram, Tue Nov 07 2006, 09:29PM
Mercury switch frozen with (presumably) liquid nitrogen.
Tesladownunder, Wed Nov 08 2006, 12:30AM
Correct.
Next is Mystery photo 54. This is harder and I may need to give a clue.
Tesladownunder, Sat Nov 18 2006, 10:59PM
Seems like you need a clue.
If you could spectroscopically analyse that light you should see lines characteristic of sodium and mercury.
Here is a wider view.
More hints. Where else do you see red and green lights? I can't post again until someone else has a go.
Peter
atomicthumbs, Fri Nov 24 2006, 03:45AM
I'm guessing a long-exposure shot of two neon tubes, mercury vapor lamps, and sodium lamps. Maybe they're on a carnival ride of some sort, or somehow moving, or maybe you're shaking he camera.
Steve Conner, Fri Nov 24 2006, 12:22PM
It's street lights and traffic lights at night. A time exposure from a moving car, or more likely a bike, knowing TDU
Tesladownunder, Fri Jan 26 2007, 03:43PM
This thread is a sleeper that is about to rise like a Phoenix from the ....whatever.
Yep the last one was traffic lights and sodium street lights from a camera on the dashboard. Well I was bored...
Photo shows the full shot. Kinda interesting.
Next photo Mystery 56. What do you expect, I am a true blue Aussie. (hint)
Peter
Chris, Fri Jan 26 2007, 10:24PM
Next photo looks like a grinding wheel showing sparks of metal whizzing by. Very brief exposure. If the color is anything like that in real life it's probably titanium.
Tesladownunder, Fri Jan 26 2007, 11:32PM
Not grinding sparks.
Type in Aussie and the date of the post into Google. (a hint about the hint)
Photo shows Tungsten grinding sparks.
Peter
Chris, Sat Jan 27 2007, 01:18AM
It must be some kind of fireworks then, but the background looks like it's going by real fast.
Electroholic, Sat Jan 27 2007, 03:10AM
this is fireworks.
Very close, but I dont think thats it.
Tesladownunder, Sat Jan 27 2007, 03:57AM
It was fire works for Australia day.
Photo 1 shows detail of a similar firework.
Photo 2 shows the full pic. The horizontal displacement is due to camera shake. I did a few manual shutter shots rather than my usual IR remote trigger. It was only 1/30 sec and the displacement is down not across.
Photo 3 Shows the wind effect.
Photo 4 Mystery photo 57
Peter
ragnar, Sat Jan 27 2007, 04:18AM
Hehe, #4 would be a comet on a stick
Tesladownunder, Sat Jan 27 2007, 06:28AM
You wouldn't have guessed that last year
But I suppose I wouldn't have had the picture then. It is in fact a street light that was missing the light.
Here is a street light with the light. Taking a very dim object next to a bright one came out better than expected.
Peter
Tesladownunder, Sun Mar 04 2007, 10:23PM
This one had me fooled for a minute or two.
Mystery photo 59
Andrew L., Sun Mar 04 2007, 11:31PM
In the back I can see the "Eye of Sauron" rig. I assume it is a long exposure picture due to the fact that there is a faded figure of a man or something like that in the bottom left corner.
Myke, Sun Mar 04 2007, 11:55PM
a projection of yourself?
GreySoul, Mon Mar 05 2007, 12:19AM
heh.... I missed the boat
Tesladownunder, Mon Mar 05 2007, 02:02AM
Andrew L. wrote ...
Closer. This is the much larger "Expanding Eye of Sauron" setup with an 11 foot rotating rod. (I don't put these pics on 4HV any more but they are on my site). It is indeed a long exposure shot for 30 seconds. And yes it is me in the bottom left
wearing yellow cycling gear (had to dash home for 2-3hours to take this shot and there was no-one else home).
How high in the air would I be?
What are the corona like spots?
Myke, Mon Mar 05 2007, 01:53PM
Maybe particals that went thru time and ionized the air?
Or maybe they are nothing and were photoshoped in?
Otherwise donno.
Nik, Tue Mar 06 2007, 12:05AM
Since your coil isnt running I'm going to guess that it is your candybox HV sparker being waved around in a long exposure.
Marko, Tue Mar 06 2007, 08:56AM
The greenish thing in front is a wraith just arraived from hell trough a portal, and purple dots are remants of it (tesla coil must have been used to open the portal).
Truly, I have no idea how he created the 'ghost' effect. For purple dots, I guess he waved a blinking UV LED around.
Electroholic, Tue Mar 06 2007, 10:07PM
static discharge from brushing your hair, lol
Tesladownunder, Wed Mar 07 2007, 11:05AM
I think the answers should be there. It's just an effect I hadn't seen before, or realised what it was.
Think what I am doing and how.
Thats a cruel taunt to someone who is losing his hair
Actually I get the best and most reliable static show from taking off that very same yellow cycling shirt at night regardless of the weather. That combined with my tritium glow keyring in the pocket makes it quite a show if I take it off in the dark.
TDU
Electroholic, Wed Mar 07 2007, 12:13PM
I am sorry TDU, please accept my apology.
That "lol" was not the sarcastic kind, it was short for "f* if I know".
As for a second guess, since you are not holding the camera, you have to be using timer/a remote.
Could it be from your IR remote?
Tesladownunder, Wed Mar 07 2007, 02:21PM
I was only joking about being sensitive - my wig seems to hide it well....
But you are right about the IR remote. I had to climb up the ladder to get close enough to trigger it by waving it in front of the camera. What you see is the camera picking up the infrared which it does quite well. See the results with an IR filter on a normal shot
here.
Being a digital device you see the datastream as on an off dots when it is moved.
TDU
Tesladownunder, Sun Mar 18 2007, 03:27AM
How did I do this?
TDU
Myke, Sun Mar 18 2007, 04:11AM
Glue
. The can could be whighted so the center of gravity would be in between the bottom rim and the ridge.
Sam, Sun Mar 18 2007, 04:51AM
almost empty the can, and balance it on the rim. Do it all the time at school.
[edit] I dont read to good at 1 in the morning, yeah, a bit slow...
..., Sun Mar 18 2007, 05:10AM
yup, just drink most of the sugar free contents, then balance it on the convenient lip at the bottom of the can.
If you are asking how you managed to drink the 5% lemon, 45% splenda (or 2% aspartame?), 50% water solution held within the can, well I am stumped. Unless you were stranded out in the bush and didn't realise that the soda you brought wasn't real soda :p
Tesladownunder, Sun Mar 18 2007, 06:19AM
I must admit I normally only drink from cans if I am running out for my can crusher. I figured that out of billions of cans consumed around the world that this would be common knowledge.
Actually, I posted the wrong photo.
TDU
..., Sun Mar 18 2007, 06:45AM
hmm, this is a little more interesting :p
I am torn 50/50 between a piece of steel in the can, and a thin magnet on top of the wood (since the camera angle hides the wood above the can) or a big AC coil under the can that is providing a bit of lift. Although if it is the latter I am quite impressed at how far up you managed to get it to levitate
uzzors2k, Sun Mar 18 2007, 11:43AM
Is it glued this time? Perhaps your magnetic levitator is levitating the can, with a piece of magnetic metal or ferrofluid inside to keep it on edge?
AndrewM, Sun Mar 18 2007, 01:01PM
obviously a HALBACH ARRAY in the can....
Myke, Sun Mar 18 2007, 03:00PM
It dosn't look like it is glued but you could have put a magnet in it like ... said.
Electroholic, Sun Mar 18 2007, 04:38PM
ferrofluid inside the can?
Tesladownunder, Sun Mar 18 2007, 05:22PM
Just a simple magnet on top of the yellow sheet just out of view and a large ball bearing inside the can.
I was just wondering whether I could do something with a full can?
TDU
Tesladownunder, Fri Mar 30 2007, 02:44PM
Here's another one.
Mystery 62
Electroholic, Fri Mar 30 2007, 07:51PM
TC behind a piece of cloth
Tesladownunder, Sat Mar 31 2007, 01:11AM
That would explain the wavy background but not the apparent magnification in parts. And why don't the sparks connect? Try again.
TDU
Bjørn, Sat Mar 31 2007, 01:21AM
It is a reflection in water.
Tesladownunder, Sat Mar 31 2007, 01:27AM
Yep, just me havin' a swim.
ragnar, Sat Mar 31 2007, 05:12AM
Take care, Peter.
Tesladownunder, Sat Mar 31 2007, 06:15AM
Care was taken but as expected the salt water pool will have an extremely low E field in it and is just like a big ground. The chain mail glove also has a separate copper braid extending down towards my feet just in case I brought my hand out too far. There was no sensation at all at any time.
People do have negative connotations about electricity and water some of which was taught to us by our mother's. So we have this uneasiness about the two together.
Nevertheless the circuit paths are clear and dont involve me.
TDU
Tom540, Sat Mar 31 2007, 05:18PM
You didn't put salt in your swimming pool did you?
Hazmatt_(The Underdog), Sat Mar 31 2007, 08:11PM
Woah! That is a pretty fat arc!
I hope some kid with mots doesn't try to duplicate what you're doing here.
Tesladownunder, Sun Apr 01 2007, 12:29AM
I have a 4 MOT supply running this under oil but it was not pushed at all. No, kiddies, don't do this at home (like much of the stuff on 4HV). No-one seems to have been interested in replicating any of this stuff anyway.
And the salt in the pool? Salt water is used for two reasons. It is closer to isotonic with human extracellular tissue fluid (not sure how close) so it doesn't sting your eyes. Sea water is about 5 times isotonic if I recall. Chlorination is achieved by simple electrolysis with a titanium cell.
TDU
Ken M., Sun Apr 01 2007, 04:15AM
I realize this is TDU's mystery thread but I couldn't pass up the oppertunity when it happened.
HVAC's mystery photo 1:
Myke, Sun Apr 01 2007, 04:26AM
A light bulb used as a plasma globe?
an AC flyback, ignition coil, or a plasma globe driver.
Ken M., Sun Apr 01 2007, 04:43AM
Correct on the subject of the picture, as for the power...It was my very weak SSTC running at 12v.
Tesladownunder, Thu Apr 05 2007, 11:25AM
For those who celebrate Easter and those that don't...
What happens next to this chocolate Easter bunny (a highly commercialised Australian custom).
TDU
Steve Conner, Thu Apr 05 2007, 11:41AM
Ohhhhh, I'd never guess. Near instantaneous destruction by pulsed discharge followed by combustion of aluminium foil and steel wool? Or maybe it will get Z-pinched and form a chocolate black hole. Can I have an ear if I can find one intact?
Tesladownunder, Thu Apr 05 2007, 12:07PM
Here's the business end. So what happens to the Rabbit? To Zee or not to Zee (pinch).
Marko, Thu Apr 05 2007, 12:50PM
The bunny is completely obliterated and few blobs of aluminium and iron (and chocolate) oxides are all that is left.
I think this explosion looks especially beautiful, I guess that is because of combination of aluminium and steel wool...
uzzors2k, Thu Apr 05 2007, 12:55PM
The aluminum foil is vaporized, leaving the chocolate bunny nearly intact.
Myke, Thu Apr 05 2007, 01:42PM
it went through a worm hole and appeared on your roof?
it vaporized?
..., Thu Apr 05 2007, 02:24PM
I would say that the Al wrapper vaporised, leaving the bunny inside more or less unharmed, however with however with that much energy going in I have a feeling it melted just a little.
Ronnie, Thu Apr 05 2007, 11:00PM
All the metal is vaporised, the chocolate cracks, and is singed.
Ken M., Thu Apr 05 2007, 11:59PM
Minimal Damage....Bunny becomes big blob of chocolate, Most likely scenario....the metal or metals become nothing more a bright flash and some metalic vapor, as for bugs...mostlikely the same fate nothingness.
Tesladownunder, Fri Apr 06 2007, 01:40AM
It was just blown in at the ends but the mid section of the foil and the chocolate was intact. The really interesting thing was that the paint on the foil was almost all blown or burnt off leaving silver foil with only traces of the red.
Voltage was 5800 volts, power was 3500 joules and current (based on other experiments) was about 50,000 A in about 30 microseconds with a subsequent ringdown. The steel wool was added for the sparkler effect since aluminium will only give a big flash. Only had one shot at this (only one suitable size bunny on hand). Video will come later this weekend.
TDU
Tesladownunder, Sun Apr 15 2007, 12:59PM
What is this?
Hint. I am working on my 18 inch TC and I am doing something to show off but it was really dumb and something had to be fixed later.
Mystery photo 62 (Numbering is pretty random)
Electroholic, Sun Apr 15 2007, 01:44PM
inner tube
Ken M., Sun Apr 15 2007, 02:40PM
Using the ring launcher you have and attempting to shoot a ring of smoke at the coil hoping that it would make a ring arcs in the air, but instead it arced to the secondary windings?
Tesladownunder, Sun Apr 15 2007, 10:31PM
Inner tube was right. Well done. My new double toroid covered with chicken wire seemed indestructible, at least from a fall at toroid height. Unfortunately when it hit the ground the central disc pinched the tube giving 2 cuts in it over an inch long. My repair job didn't hold as I only had small patches.
Shouldn't be too hard to repair though with a new tube and the mesh holds its shape if deflated. The mesh covers both toroids at once. The electrical connection is solid and it should take a high power. All it took was an aluminium disc cut from a square (old one from child crossing sign), a free car tube and a $15 1000x20 truck tube. I will post details in a separate thread.
TDU
Tesladownunder, Fri Jul 06 2007, 02:50PM
No, I haven't forgotten this thread
Mystery photo is taken with natural colour, cropped and resized only.
If no corrrect guesses, I will show a progression that eventually makes things clear.
TDU
thedatastream, Fri Jul 06 2007, 03:12PM
A heater inside a valve but viewed from the top so that it distorts. Perhaps something like an 833?
GreySoul, Fri Jul 06 2007, 03:34PM
edit Ok on secondary review.... it also looks a bit like ferro fluid in weird lighting. Or maybe just oil dripping.... in weird light.
Is it from the inside of you fog machines reservoir?
first guess pre-edit before really looking at it....
It's the eye of a reptile of some fancy pieces. Probably a frog - could be a newt, salamander, or maybe a gecko.
Tesladownunder, Fri Jul 06 2007, 04:10PM
Damn, I am making these too easy.
It is a single ferrofluid spike under Neon tube lighting.
The rest of the series are here. I am making a Ferrofluid public display and have been trying lighting ideas. Probably will use a back neon to get the direct reflection like here plus two side fluoros to pick up the spikes only.
I originally wanted to have grid lighting but it was a bit difficult and I have to have it ready next week.
I have taken video aas well but not yet edited. Will probably put that on YouTube when I get it done.
TDU
Marko, Fri Jul 06 2007, 06:33PM
One mistery pic from me?
What is this:
..., Fri Jul 06 2007, 08:37PM
A very poorly desinged firewire cable?
kv, Fri Jul 06 2007, 11:41PM
not to take over the thread, but i just got this pic. what is it??
oh, and for firkragg's pic, i'd say a fibre optic cable?
Marko, Sat Jul 07 2007, 12:15AM
Both of you.. nope.
kv: laser beam going trough a bottle of flourescent...stuff?
kv, Sat Jul 07 2007, 12:37AM
yes sort of, it's one of those goo timer things. is the end of the cable melted into a blob?
Myke, Sat Jul 07 2007, 01:36AM
Is it a thermal switch/fuse?
Ken M., Sat Jul 07 2007, 03:33AM
I'll lean towards a thermal couple.
Marko, Sat Jul 07 2007, 02:53PM
1: the end is soldered; 2:no, 3: no...
Dalus, Sat Jul 07 2007, 03:17PM
A speaker cable?
EEYORE, Sat Jul 07 2007, 05:56PM
Some sorta computer cable?Like a firewire or whatever its called?
Matt
Marko, Sat Jul 07 2007, 06:27PM
No, it has nothing with computers.
And I thought it should be easy guess for some of you guys..
ragnar, Sat Jul 07 2007, 10:54PM
Firkragg's pic does honestly look like some tinned braid soldered to an inline fuse... (actually, not sure about the fuse), maybe used as a ground connection for stuff?
Myke, Sat Jul 07 2007, 11:25PM
some shielded cable or coaxial cable with the outer plastic removed?
CT2, Sun Jul 08 2007, 06:39PM
To Firkraggs picture, I forget what its called but it has to do with heat transfer I think? maybe... maybe not
Re: Mystery Photos from TDU
Steve Conner, Mon Jul 09 2007, 09:00AM
Is it some kind of antenna? :P
Nik, Mon Jul 09 2007, 11:39PM
It looks like the thermocouple from the multimeters at work.
Billybobjoe, Tue Jul 10 2007, 12:37AM
Some sort of o'scope probe/cable?
Tesladownunder, Wed Jul 11 2007, 04:38PM
14 unsuccessful replies saying much the same thing does not make an interesting thread. Time for the answer. Don't forget the title of the thread.
TDU
Dalus, Wed Jul 11 2007, 05:31PM
I'll give it one more trie is it somekind of high pressure tubing?
Marko, Wed Jul 11 2007, 05:35PM
Sure, just post your pic TDU, any time you like it...
It was a electric guitar piezo pickup, shielded with braid at the end of coax cable.
I picked this up for repair from guy at school.
It is made of flexible polymer instead crystal, and produces faint low-frequency output when flexed. I's output is very low in amplitude compared to 'normal' piezo speakers but it does work nicely with included preamplifier.
kv, Wed Jul 11 2007, 10:12PM
piezo in a string?????i never would have guessed that. any more mystery photo's?
Steve Conner, Wed Jul 11 2007, 11:21PM
Haha, that's ironic. I've installed one of those piezo guitar pickups before, and I didn't recognise it. :S
Anyway better let TDU have his thread back
Tesladownunder, Sun Aug 12 2007, 02:37AM
Happened to be doing stuff today (or tonight) and saw this.
TDU
Bjørn, Sun Aug 12 2007, 04:00AM
You hiding inside a rusty metal drum while 2 kg of steel wool combusts around you after being ignited by a 16kJ capacitor.
Myke, Sun Aug 12 2007, 04:41AM
Stars with beams of visible light coming out of them and they all happen to be pointing out way. There was a undiscovered nebula passing by that scattered the light so we could see the beams. The rusty bin look is actually noise.
I'm thinking a old barn with a metal roof.
Tesladownunder, Sun Aug 12 2007, 05:06AM
Rusty metal drum yes. Otherwise no. Any ideas about the context? What about the green?
A nearby copper rich nova is a thought but not really close.
Bjorn,
I have just started taking RAW pics on my D70S as I can manipulate them on my ACDSee software. I will be taking some big Tesla effects pics soon and will need to maximise the clarity and colour depth on my new wide angle lens.
(I know you told me to do this over a year ago..)
For the non-photographers, a RAW file compresses the original 48bit colour depth 6 Mega pixel file that is 50MB down to 5 MB. JPEG will bring it down to 300K in "fine" resolution. Or something like that.
This pic started life as a RAW file (Nikon NEF). Of course, no advantage here and mainly of use if going to be printed in magazines or books.
TDU
..., Sun Aug 12 2007, 05:06AM
Looks to be a large drainage pipe that has a few leaks on a sunny day... Although the stuff at the end almost seems to green to plants...
Electroholic, Sun Aug 12 2007, 06:27AM
the inside of the vortex ring shooter?
Tesladownunder, Sun Aug 12 2007, 07:55AM
The smoke was a give away since I only use this for lasers, and the Vortex generator. Ohh, and to simulate a burning car thief
The drum has been in our yard quietly rusting for years. As there is a 2 foot hole in the front, a few pin holes are of no consequence, but look interesting from the right angle in sunlight. The green is my new fibre backed green cloth of the diaphragm.
TDU
Tesladownunder, Sun Aug 26 2007, 03:06PM
Triple 7 sparks. How did this happen?
Mystery 71
Steve Conner, Sun Aug 26 2007, 10:02PM
Err, you managed to summon Satan but he had gone up by 16.7% due to inflation?
ragnar, Mon Aug 27 2007, 02:28AM
Hmmm, perhaps the spinning electrode has a nonconductive section in the middle that arcs over?
Firnagzen, Mon Aug 27 2007, 05:49AM
Long exposure, spinning breakout point, pointy metal bits on the floor?
I see some corona in mid air, and a strange orange spark.
Tesladownunder, Mon Aug 27 2007, 06:33AM
Long exposure? Yes - sort of. About 0.5 - 1 second. I will look it up when I get home.
Spinning breakout point? Yes
Floor is a stone composite tiled in a
Penrose pattern but pointy bits? No
Corona in mid air? Yes - coming from other parts of the spinning breakout point.
Strange yellow spark? Easy enough if you have seen my other recent stuff.
Still no-one has the answer. I wouldn't have predicted it either but I think I understand it now.
TDU
Firnagzen, Mon Aug 27 2007, 09:09AM
The orange spark is burning iron or something from the breakout, I guess.
Eh. The arc struck on the metal reinforcement grid under the floor?
Tesladownunder, Mon Aug 27 2007, 11:37AM
Smooth orange arc is indeed a sparkle from burning steel wool.
There is no metal reinforcement grid. The tiles are perhaps 2 inches thick, laid on concrete. Perhaps that is reinforced but not with a grid pattern that is 2 feet apart.
Time for a clue. This is a power arc not some feeble streamer. Where does it start?
TDU
Spedy, Mon Aug 27 2007, 02:49PM
I see a little tine "blue" corona-ish looking arc in the backgroud near the TC. hmmm.. Why the arcs are making 7's I don;t have a clue.
Myke, Mon Aug 27 2007, 03:07PM
They start out arcing directly to the ground but since the rod moves it gets drawn out and when it gets too far then it extinguishes and another starts.
Tesladownunder, Mon Aug 27 2007, 06:40PM
Correct. The arc goes directly to ground in a heavy power arc. But the spinning electrode is moving horizontally at 7 ft/sec. The ground arc is well formed it pulls an arc out from the top until it is nearly the same length again before it extinguishes and starts the process again. The power arcs are only 2-3 feet but the TC is running at 5-6 feet power.
So why is the angle of the 7 so sharp? There are three competing forces. The main one is to stay in the hot ionized channel. Second is for the magnetic field effect to enlarge the angle outwards (think rail gun forces to push the arc out). This is counteracted by the electric fields encouraging the spark to take the shortest path.
It really is quite dramatic in action zap-stretch, zap-stretch.
Here is a full rotation which takes place in 7 seconds, perhaps 12 foot radius. It gives a whole march of about 40 "sevens"
TDU
Firnagzen, Tue Aug 28 2007, 05:43AM
Whoo! If I didn't know that that took place over time, I'd duplicate the system and sell it as the ultimate anti-intruder system! (I mean seriously. What would your sectetary think? [i])
Any videos?
Tesladownunder, Tue Aug 28 2007, 09:54AM
Yep, videos and lots of photos of things like the "Eye of Sauron" and "Tesla car thief protection". About 1/2 million have seen these on the net. Check out my site if you are interested.
TDU
Firnagzen, Wed Aug 29 2007, 05:15AM
No, I meant a video specifically of this. Is it up yet? (Looking now)
Tesladownunder, Wed Aug 29 2007, 12:49PM
Sadly, no video of this effect. There were two video crew with pro gear, one for me and the other for the Discovery Channel but they had to finish just before I did this. Sadly my home vid was left on and was flat. As my other son had to go, it was just me and my wife.
I get a bit nervous in that situation as no phone contact out there if there were problems.
I will put up a separate thread about the night.
TDU
Tesladownunder, Thu Aug 30 2007, 02:53PM
Well what about this one? Taken of 4 inch sparks from my ignition coil setup. I have a string of ceramic caps across it to brighten the sparks.
No Photoshopping of course.
What gases are involved?
Tdu
Spedy, Thu Aug 30 2007, 02:59PM
Would the red be neon? I'm not shure, but I've alwaus seen real neon tube glow red..
Dalus, Thu Aug 30 2007, 03:01PM
Helium, Neon, Argon and Krypton I think.
Tesladownunder, Thu Aug 30 2007, 04:04PM
Alright, how about this one?
Are you running out of gases?
TDU
Dalus, Thu Aug 30 2007, 07:26PM
I think you used Xenon for the white, Radon for yellow, which gas you used for the green I don't know. Maybe some kind of mixture or a solid chemical on the electrodes.
Marko, Thu Aug 30 2007, 08:07PM
I would really hate to use radon for these things.
Electroholic, Thu Aug 30 2007, 09:42PM
that looks too even to be done with gas.
you didn't use filters, did you?
anyways, sick pictures.
Tesladownunder, Thu Aug 30 2007, 11:09PM
Yep, I used filters.
The gases were Nitrogen 74%, Oxygen 21%, Argon 1% etc In other words - air.
So how did I use them and what effect am I trying to recreate from fiction?
TDU
Bored Chemist, Fri Aug 31 2007, 05:52AM
74+21+1=?
Tesladownunder, Fri Aug 31 2007, 11:59PM
Perhaps it is 78% + 21% + 0.9% + etc, where you are but "downunder" the air has a certain extra percentage of freshness. (Or perhaps I am generating too much ozone).
TDU
OZZY, Sat Sept 01 2007, 10:18AM
The pictures were taken through a rotating colour filter from a disco light. As to what you are trying to re-produce, I have no idea.
Tesladownunder, Sat Sept 01 2007, 08:30PM
I just held up two different filters in front of the camera at different times. I did not have a color wheel then, but I have made one up since and have used it on Tesla sparks.
Jump to the thread here in Tesla coils.
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?30760.lastTDU
Coronafix, Sun Sept 02 2007, 04:01AM
Yeh, but what effect are you trying to recreate from fiction?
Tesladownunder, Sun Sept 02 2007, 04:29AM
At this stage I am jealously guarding that secret.
It will take some weeks to get the effects and props arranged. It should be one of the most popular things I have done. I hope to do some further work towards it tonight.
TDU
Tesladownunder, Wed Sept 05 2007, 12:43PM
How about this?
Mystery 75
Ken M., Thu Sept 06 2007, 06:54AM
Looks like an arc discharge from from your X ray xformer, as for the arc I think its arcing to a spinning ground perhaps.
Tesladownunder, Thu Sept 06 2007, 01:24PM
The HV setup is my twin ignition coil one (driven by a MOT and Sidacs at several kV). One side is used to get 2 inch sparks.
A rotating ground is a reasonable idea but not correct.
Does this help?
Mystery 76
Munkey, Thu Sept 06 2007, 04:47PM
Umm... I'm gonna have a go at this. Is it moving a sparking HV (red) wire with the camera with a long exposure?
Tesladownunder, Thu Sept 06 2007, 05:33PM
The red wire is in the background and is unrelated. But you are essentially right, the series of sparks are due to a wire being fed off the spool from the HV source. The wire has a 2 inch gap made from nylon fishing line which feeds out about 2 feet to an earthed wire. All this happens within a long exposure (10 seconds here).
Now imagine everything scaled up 20 times with a much more rapid spark rate. See where I am going?
TDU
Munkey, Thu Sept 06 2007, 07:57PM
Hmm, I see the spool of fishing wire on top of the wooden blocks with some vacuum tube poking their heads out of the driver I would assume. My only guess left is that you are retracting the fishing line whilst it is sparking? But thats awfully close to my other guess...
Ill have a long look and try to figure out more.
OZZY, Fri Sept 07 2007, 07:44AM
The heat ray from War of the worlds?
Tesladownunder, Fri Sept 07 2007, 08:54AM
Bacon wrote ...
You were right before essentially. I feed out the magnet wire from the spool and it has a 2 inch gap in it joined by nylon line.
Can you see the potential for one with dimensions 20 times as big?
TDU
Munkey, Fri Sept 07 2007, 04:39PM
Tesladownunder wrote ...
Unfortunately no, I have no imagination...
Tesladownunder, Sun Oct 28 2007, 11:28AM
Here's a new one.
Is it moving or stationary?
TDU
Ken M., Sun Oct 28 2007, 12:10PM
MY guess is its mercury ontop a dense gas or mercury under a contact lens, or both.....
ragnar, Sun Oct 28 2007, 03:11PM
Hmm, a spinning dish with steam, or cold CO2 or N2 fuming out an orifice?
Tesladownunder, Sun Oct 28 2007, 05:18PM
Matt Bingham wrote ...
... or cold CO2 or N2 fuming out an orifice?
Closer.
TDU
Dalus, Sun Oct 28 2007, 05:39PM
A drop of water on a peltier cooler
Tesladownunder, Sun Oct 28 2007, 10:17PM
A hint.
TDU
Zee, Mon Oct 29 2007, 12:44AM
Neodymium floating on N2
Tesladownunder, Mon Oct 29 2007, 03:05AM
Zee wrote ...
Yes that is a NIB (Neodymium-iron-boron) magnet which is probably about 5mm diam. No it wasn't LN2 (and it wouldn't float anyway).
Getting closer though.
TDU
Electroholic, Mon Oct 29 2007, 03:22AM
Paramagnetic LOX?
Nik, Mon Oct 29 2007, 03:32AM
It looks like its stitting on top of a frozen pillar of ???. Maybe dry ice or just regular ice.
Myke, Mon Oct 29 2007, 06:45AM
Is there a superconductor in liquid nitrogen? If there is then the magnet is floating in air and the white fog is small water droplets suspended in air.
Tesladownunder, Mon Oct 29 2007, 11:18AM
Electroholic wrote ...
Paramagnetic LOX?
Correct, We have a winner.
I made about 50ml of liquid oxygen by passing medical grade O2 through a condensor in a dewar of LN2. I made it out of copper tubing which then dripped and sputtered into the container with a flow rate of about 1-3 l/min. The LOX container is kept in the bath of LN2 to stop it bubbling away.
I have been able to confirm that LOX is blue tinged and will adhere to a magnet due to the paramagnetic properties. The close up photo shows a small NIB magnet with a crown of LOX over the top giving the muffin like appearance to the NIB. There is a blanket of cold air above it from the boiling LOX which in still air was very clearly defined. The setup was on an upside down styrofoam cup as a very shallow insulating dish.
TDU
Spedy, Mon Oct 29 2007, 03:09PM
Wow, liquid O2. That's pretty cool. Do you have any pictures of the blue-ish o2? Anyway, very cool.
Tesladownunder, Mon Oct 29 2007, 03:15PM
The third picture up shows the blueish tint against white paper.
Now on my site too under
Liquid Oxygen.
TDU
ConKbot of Doom, Mon Oct 29 2007, 10:38PM
We had a professor give a demonstration with LN2, and he condesned O2 from a cylinder in a test tube. He then put it in a beaker, got a piece of steel wool smoldering with a lighter, and dropped it in the O2...
It cracked off/burned though the bottom of the beaker and scorched the table top.
Tesladownunder, Sat Nov 10 2007, 12:13PM
Mystery Photo 81
TDU
Ken M., Sat Nov 10 2007, 01:38PM
Some more cool long exposure laser light photos?
ragnar, Sat Nov 10 2007, 02:35PM
Mystery Photo 81
Burning flying insect, spiralling after ignition by tesla coil?
Dr. Dark Current, Sat Nov 10 2007, 02:40PM
yes it looks like a fly (or flies) illuminated by yellow light flying against a black background (night sky?.
Tesladownunder, Sat Nov 10 2007, 03:32PM
Correct.
It's spring and the bugs are out. Earlier in the day I took a pic of flying ants on a background of a bloodred sun from bush fires (but it didn't show the ants).
The small flying things are small flies, and the larger ones are moths, and flying beetles including water beetles.
Other pics show the details.
Last pic with the Green stuff is the next mystery object.
TDU
Simon, Sat Nov 10 2007, 10:50PM
Closeup of something like a banksia.
Tesladownunder, Sat Nov 10 2007, 11:11PM
Correct.
I suppose being from Oz helps.
Just I snap I took of a Banksia while bushwalking about 50 m from our house .
Pic shows the original.
I'll have to get something harder - like only showing one pixel
TDU
Andrew L., Sat Nov 10 2007, 11:15PM
A closeup shot of a sunflower that hasn't bloomed yet or some other flower.
[edit]: I was a little bit too late
Nik, Sun Dec 16 2007, 03:09AM
Mystery photo (shouldn't be too hard).
..., Sun Dec 16 2007, 03:23AM
cornstarch/water in a big subwoofer
Nik, Sun Dec 16 2007, 04:09AM
Close enough, its not a big woofer but you got it.
Tesladownunder, Sun Jan 13 2008, 05:41AM
This one is not too hard but does demonstrate something I was not aware of.
Mystery 82
TDU
Mates, Sun Jan 13 2008, 08:36AM
Mystery 82
I think, it is a plastic foil (most likely PP transparency for printers) placed between two HV electrode (small Marx or stun gun)... In fact we could call it a Lichtenberg figure.
Myke, Sun Jan 13 2008, 09:43AM
Your MOT in a MO surface tracking around a sheet of plastic. I don't know what type of plastic it is though.
Tesladownunder, Sun Jan 13 2008, 11:32AM
Its an x-ray film - CT scan with an unused blank area. It is my MOT multiplier driving ignition coils via SIDACs capable of an easy 4 inch spark. The electrodes are 1 inch apart with the film in the middle and the spark extends out about 2 1/2 inches to go around the plastic.
The interesting thing was that the spark tracked back so accurately along the same path. Due to electric field effects I guess. They blur out closer to the electrodes as they are off the surface.
TDU
Mates, Sun Jan 13 2008, 12:23PM
TDU
I think the sparks took the same track because the path was burned into it after the first spark occured. So it menas that the heat (and maybe the UV) made a tiny carbonized area which became to be better conductor than the rest of the sheet. You can check the tracks if put the sheet into the fridge for a while and than you breath on it...
Tesladownunder, Sun Jan 13 2008, 05:03PM
You didn't understand what I meant. The spark travels on one side of the film then on the opposite side of the film, it very closely follows the path, so you have two nearly overlapping sparks seen through the film.
Subsequent sparks follow diffferent paths and are not burnt in to the film.
The developed vs non developed side doesn't seem to make much difference although the silver layer would be expected to be potentially more conductive.
You can see this on one with a single spark here.
TDU
Sulaiman, Sun Jan 13 2008, 06:07PM
I'd guess that the arcs grew on both sides simultaneously until they reach the edge of the film and 'join-up'
Mates, Sun Jan 13 2008, 10:41PM
Ok, any idea what it is and how it was done?
Tesladownunder, Sun Jan 13 2008, 11:15PM
Sulaiman wrote ...
I have a different take.
At time 0 prior to spark formation, there is a sort of uniform electric field that exists around the film.
A spark leader begins to form guided in part by cosmic ray ionisation trails. (look at a cloud chamber to see these - they are everywhere)
As it does so, any localised current flow will distort that field locally. A flow of charge will result in an opposite charge on the other side of the dielectric film just like a capacitor.
So if there is a flow of electrons with negative charge, then there will be a localised track of positive charge on the other side which will attract the flow of electrons when they get around there.
Mates wrote ...
Kirlian photography. Corona on a photographic film. Nice. I've not seen anyone do that here if that is what it is.
TDU
ps Bear in mind the title of the thread.
Mates, Sun Jan 13 2008, 11:29PM
TDU
Sorry TDU I know it is your thread; I could not help myself because those pictures are so close to what you’ve just posted. It is also an X-ray film which was placed between two high voltage electrodes (200KV) and single discharge was performed through it. Than the film was developed and shined through with a very strong light source (otherwise is completely black). Thus I would rather call it Lichtenberg figure than a Kirlian...
BTW: No more intruding pictures - I promise
Tesladownunder, Fri Feb 29 2008, 03:48PM
Time to wake this thread again.
Mystery 83
CT2, Fri Feb 29 2008, 05:32PM
LED's at night, look like the ones u can attach to your waist/arm for safety when biking?
Ken M., Fri Feb 29 2008, 05:41PM
I agree with CT2, also with I'm gonna say an 4sec exposure time, maybe less.
Tesladownunder, Fri Feb 29 2008, 11:21PM
A good thought but no. LED's are usually of constant brightness and the tails in this 2 second exposure should be of the same colour and brightness.
But here the bright white lights are of a different colour than the tails which also seem to vary in colour. In addition the bright white lights are more widely spaced than the tails, so again don't fit.
It's a bit of a mystery, isn't it. And no there aren't any clues from my site yet.
Here is another related photo. I will give progressive clues with more guesses.
TDU
Tesladownunder, Thu Mar 06 2008, 04:33PM
Hmmmm... Too hard
My son gave me a bubble generator for Xmas.
The unusual reflections are due to a combinaton of the oblique lighting, long exposure and flash as well.
The last pic is a nice little scene in a bubble of me and my son with some trees in a bubble. Note the loss of reflection at the top as the film thins (to ?less then 1 wavelength of light thick)
A few pics.
rp181, Thu Mar 06 2008, 10:32PM
Very cool.
Why cant you see camera reflection?
i bet you could sell some of your photos..
Tesladownunder, Tue Mar 25 2008, 04:12PM
rp181 wrote ...
The camera in the bottom photo did not have light behind it to form a silhouette.
I did try sending some of my best photos off to ShutterStock. All 10 were rejected. Mostly they look for a pretty girl in a lab coat looking at a flask of blue liquid to represent science. Hundreds of these. Go figure. Even Scientific American had one of those cheesy shots.
Here's another Mystery photo, fairly easy.
uzzors2k, Tue Mar 25 2008, 05:17PM
Long exposure of a scorpion in your hand being lased with your blu-ray laser pen!
Tesladownunder, Tue Mar 25 2008, 11:48PM
Yes it was too easy. I should have only showed one pixel. It shows the fluorescence of scorpions to violet/ultraviolet in a 3 second exposure with the Blu-ray pointer. I found this one in our kitchen.
Not easy to take though. Consider. One hand is perfectly still holding a live scorpion and the other triggers the camera AND moves the laser - in complete darkness.
TDU
Ken M., Wed Mar 26 2008, 06:52AM
So then is that one of those worlds most dangerous scorpions or just your average rush to the hospital antivenom scorpion?
Tesladownunder, Wed Mar 26 2008, 08:01AM
Just one of those "I'll take it straight back to its mother" type scorpions.
Actually that is the only size we see here so I guess full grown or maybe that's as big as will fit under the door. ...is that someone knocking?....
TDU
Nik, Wed Apr 02 2008, 05:45PM
Heres a mystery photo for you.
Dr. Dark Current, Wed Apr 02 2008, 06:07PM
Is it a fulgurite created with (MOT) arcs?
Nik, Wed Apr 02 2008, 09:30PM
Yes it is. :s too easy.
nrhoades, Wed Apr 02 2008, 11:06PM
Here's two.
Ken M., Wed Apr 02 2008, 11:59PM
A) Fresh lava
B) Long exposure with a green laser
Tesladownunder, Thu Apr 03 2008, 12:52AM
Just a friendly reminder about the topic of the thread...
TDU
Nik, Thu Apr 03 2008, 01:10AM
I thought I'd fill in while you were off being a TV star for discovery
Tesladownunder, Thu Apr 03 2008, 01:55AM
LOL . I must admit, I have been a bit light on for mystery pics lately. Sometime I do mysterious things and sometimes just ordinary stuff.
Sadly for HV, I have been spent about 50 hours playing Dungeon Seige 2 recently into the wee hours, when I should have been "working" hard at playing
I think the US Discovery stuff has fallen through. I've had 3 print media requests in the last week though.
TDU
Arcstarter, Thu Apr 03 2008, 03:32AM
That is a darned shame...You,Steve Ward and Steve Connor are my favorite tesla coilers....
nrhoades, Thu Apr 03 2008, 02:09PM
I under-estimated the power of picture-guessing. I stand corrected. I have some tougher ones...
uzzors2k, Thu Apr 03 2008, 03:05PM
Nik wrote ...
How do you make those, just arc through wet sand? Are they very stable or do they just crumble?
Nik, Thu Apr 03 2008, 06:56PM
The sand is damp and lets the arc start. The thin ones are very brittle but the longer I let it arc the thicker they get. The thickest one I have is about 1cm thick and a lot stronger.
Tesladownunder, Tue Apr 15 2008, 12:28PM
Now this is really beautiful. Shame I couldn't keep my hands off it. I call it the "virtual toroid".
Any guesses as to how it is done?
TDU
Nik, Wed Apr 16 2008, 02:16AM
The motion behind it seems fairly simple, an LED spinning around a point and that point is spinning around some other point. But I can't imagine how you achieved that motion with a simple rig.
Tesladownunder, Wed Apr 16 2008, 10:42AM
Close. Does this help?
TDU
Myke, Wed Apr 16 2008, 09:37PM
A spinning disk/ring with LEDs placed on the edge that are equally spaced away from each other?
Tesladownunder, Thu Apr 17 2008, 12:20AM
Correct. My wife had a battery operated LED light that she got to provide a light over the BBQ. It has 24 LED's in a circle.
I simply suspended it with a bit of fishing line from the rafters (not really a complicated rig!). Give it a spin then set it rotating in a circle or ellipse and take a time exposure. The exposure needs to be set for just over one period of swing and I used 2 seconds. It's very bright so the f stop was set back as far as possible (f/22).
It all took about 10 mins from conception to get the first shot .
In the photo below I have covered one of the lights with blue cellophane and you can see the course of the individual LED. Add a bit of tilt causing gyroscopic precession and the pattern becomes complex.
TDU
Tesladownunder, Sat Apr 19 2008, 06:59AM
6 hours ago I would have had no idea what this was.
This is my second attempt and I will do a proper post on it once I get it all tidy.
The output spark is 5mm.
What do you think this is?
TDU
Mates, Sat Apr 19 2008, 07:44AM
Very tightly coupled air transformer…?
Myke, Sat Apr 19 2008, 07:45AM
Cool thing like a tesla coil?
I don't know why the arc is between a wire and a a trip of copper though.
Electroholic, Sat Apr 19 2008, 07:46AM
2 in 1, rolled-up cap and tesla coil.
c4r0, Sat Apr 19 2008, 08:16AM
Looks like a spiral line voltage pulse generator. I don't know much about it, but it is (or was) used in pulsed x-ray machines.
(it is two from ten scans i got, i can post it all if you want)
Tesladownunder, Sat Apr 19 2008, 09:48AM
Well done, that is exactly the picture on my computer at the moment.
It is a spiral line impulse generator. Just two copper strips like a rolled capacitor and it raises 2kV to 5kV.
I have started an article
here in the HV section or check it out on
my site.
TDU
Dr. Shark, Sat Apr 19 2008, 02:49PM
Whatever it is, it looks pretty awesome! I wonder why it is sparking at two different places at once?
I am with Electroholic, in fact it could be constructed like a "violet wand" (and early electrotherapy device), which is also a Tesla coil with the capacitor wound around the coil.
Tesladownunder, Mon Mar 09 2009, 11:44AM
Thought I would rejuvenate this thread. For those of you that haven't seen it before it might be interesting to go through it from the beginning. It has about 80 photos that represent some aspect of my stuff but aren't immediately obvious.
Here is one that struck me from yesterday. It forms the basis of an advertising logo I am working on. I call it the "HV spider".
The actual spider is a Huntsman spider, common in homes around here. Yes that is my hand.
Any idea how it is done?
Tom540, Mon Mar 09 2009, 05:11PM
that's a pretty big spider. I'm assuming its pretty harmless.
Coronafix, Mon Mar 09 2009, 09:44PM
Yeah, they're harmless. They don't make webs so it's ok to let them roam around the house. Most people have a pet huntsman in their toilet in Australia.
hotcrazyfruit, Mon Mar 09 2009, 11:04PM
i think, it is a stick or rod, and it is just touching the water, causing the surface tension to grab up the sides of it and make a little bit of a curve,then frozen. and the shot is very close up by my guess, perhaps with a macro setting, thus causing it look look bigger and more mysterious. looks very cool though. xD
Tesladownunder, Mon Mar 09 2009, 11:44PM
Tom540 wrote ...
This one was a geriatric and pretty slow. They have pretty big fangs but I've never been bitten.
hotcrazyfruit wrote ...
i think, it is a stick or rod, and it is just touching the water, causing the surface tension to grab up the sides of it ....
That was the number one mystery photo on page one and was of deionised water being attracted to a HV electrode. All the answers follow on and this is now page 17.
So anyone work out how that spark picture was made?
Next pic shows another couple of views.
El_Roberto, Tue Mar 10 2009, 12:34AM
Is it an aluminium plate that has somehow been insulated and where the legs and body are, are where the insulation has been taken off?
Tesladownunder, Sat Mar 28 2009, 12:48AM
Here is a similar setup but better controlled and high res. Pic is 1.7M. I kinda like it for its uniformity.
Tesladownunder, Tue Mar 31 2009, 07:43PM
This is the sliding spark gap that I take on long exposure to give the previous photo.
Now, what about the next one. It looks to me like I caught a lightning bolt. How is it done?
rp181, Tue Mar 31 2009, 11:06PM
Is it some kind of film, and someone shone a light on it, with a long exposure? What leads me to believe this is that the light is in front of you at the bottom, and then goes behind. I can't explain your arm though....
hotcrazyfruit, Tue Mar 31 2009, 11:22PM
[/quote1238541710]
its a nuke isnt it? lol
Hon1nbo, Tue Mar 31 2009, 11:29PM
appears that there is some kind of fog at the bottom... did you use some kind of smoking source and channel that through a plastic guide, like a thin film (as per the suggestion of rp181)?
obviously, the exposure was relatively long, OR it was a double exposure, as after zooming in on the leg there appears to be a small ghost, indicated that either A) this is a merging, but I doubt that as that would ruin the fun, or B) you switched the light source on and off and back on, or said light source is Pulsing...
then again, after closer review, your ENTIRE body is ghosted, bending over which leads me to believe that you physically held the light source and moved it, but since it is a long exposure, you can make your other arm not show up until you stop it where you want it, and put enough light on it (in this case, a shadow)...
so my final thought is that you had some kind of smoking light source, possible magnesium but I don't know for sure, that from bending over, you rose up keeping your left hand out of the way until you were upright, then placing your hand into position (which would explain why you had noticable lesser exposure below your hand than above, as to keep ghosting of the hand minimized, then the little smoke that comes off of magnesium was illuminated after stopping it near the top of the image
again, this is just what I can deduce at first glance...
Tesladownunder, Wed Apr 01 2009, 12:19AM
Not magnesium and not a Nuke.
rp181 wrote ...
No, it's not some kind of film. I always have trouble explaining my arms too.....
Answer is a LED torch with a fibreoptic spray used to light paint an area in a long exposure. I could have done it without me moving if someone else was doing the painting. You can get some really surreal effects with the diffuse light source. I put my arm and leg in front to make it clear that it is not simply an effect added on.
rp181, Wed Apr 01 2009, 12:42AM
You should try putting the camera perpendicular to the light, and spiral it while walking, to give a 3D sideways cone effect.
How did you reach so high in the above picture?
Tesladownunder, Wed Apr 01 2009, 03:15AM
rp181 wrote ...
There are lots of possibilities with painting with light. Mostly just child like fun. I did try a cone by suspending it from a basketball hoop and pulling it up but there were some problems and I was in a hurry to get back to work so I did the other stuff.
And reaching so high? I can't explain my arm as you know....
Tesladownunder, Fri Apr 03 2009, 12:12AM
Now this is tricky. Any guesses. ( I have altered the exposure and contrast to an extreme amount)
rp181, Fri Apr 03 2009, 01:54AM
I will go ahead and take the obvious guess:
Blue LED's behind a keypad.
That picture looks like it could be done in paint.
From the last picture, It seems really high, compared to the basketball hoop.
..., Fri Apr 03 2009, 02:57AM
Looks to me like a bootprint on a piece of plexiglass
Tesladownunder, Fri Apr 03 2009, 03:10AM
does this help?
Steve Conner, Fri Apr 03 2009, 07:36AM
Is it your uber LED array focused by a lens?
Tesladownunder, Fri Apr 03 2009, 12:16PM
Yep. It's the LED shining through a 180mm camera lens which projects a very clear image onto the corrugated shed wall. You can see great detail with the 30 times magnification including the bonding wires and chip details. It so happens that the chip light is in a "3" shape brought out with contrast adjustment. One of the individual LEDs is marginally brighter or in better focus and stands out unusually.
More details on the "
Mother of all LED's" thread.
Tesladownunder, Sat Jun 13 2009, 02:01PM
How about this?
lhl_henrylui, Sat Jun 13 2009, 02:16PM
The sky in the night taken by long exposure?
Proud Mary, Sat Jun 13 2009, 02:53PM
Raindrops or dew on a window-screen?
Dr. Dark Current, Sat Jun 13 2009, 04:51PM
To me it looks like raindrops in the night, illuminated by something bright from behind the camera...
Tesladownunder, Sat Jun 13 2009, 06:39PM
lhl_henrylui wrote ...
Reasons for: I've done it before with a big lens.
Reasons against: it just doesn't look like Hubble Deep Field. This amount of exposure would leave star trails unless I have a proper tracking mount.
Harry wrote ...
Reasons for: they are spots against a background.
Reasons against: dew forms uniformly on a screen as a mist obscuring vision then coalesces and with rain it seems too non uniform (perhaps).
No screen is involved.
Anyone else?
Edit: Oops this post crossed Dr Kilovolts
Dr. Kilovolt wrote ...
Correct. That bright light is called a camera flash.....
It is only our persistence of vision and our understanding of the trajectory that makes us "see" rain as streaks. Freeze it with a flash and you just get to see dots.
More interesting info and the original photo when I get home.
Yes that is a tree silhouette on the left side.
Edit again.
The original photo of my back yard with the city lights giving a glow in the sky. Interestingly, not all or the raindrops are white. Some are red yellow orange green or blue and on one occasion I got a tiny full spectrum. I presume that these are due to prismatic effects due to distorted or colliding drops. The blobs are just out of focus drops.
Renesis, Sat Jun 13 2009, 07:44PM
Have you ever seen night rain lit by a powerful strobe lamp? It looks awesome, like the rain has stopped.
Dr. Dark Current, Sun Jun 14 2009, 01:37PM
Was that a 100% crop? The colors might be because of the CCD, if it sees a single pixel it cannot know which color it is as CCD pixels are only either red, green or blue.
Tesladownunder, Sun Nov 01 2009, 03:35AM
What happens next?
Arcstarter, Sun Nov 01 2009, 03:47AM
What happens next?
I cannot quite tell what that is. Is it a balloon or a hot dog :P
rp181, Sun Nov 01 2009, 03:57AM
Absolutely nothing O.O
klugesmith, Sun Nov 01 2009, 04:15AM
Looks like time for an exploding wire, er, wiener.
Killa-X, Sun Nov 01 2009, 04:31AM
"What happens next" Well, if it's a hot dog, and it gets cooked on HV / high current, then "what happens next" is you enjoy a tasty meal as long as you don't overcook it :)
Tesladownunder, Sun Nov 01 2009, 05:40AM
Arcstarter wrote ...
Hot dog. Its hard to get a wire through a balloon.
rp181 wrote ...
Not like me really...
Killa-X wrote ...
Even if the thin wire was red hot it would not cook impressively.
Klugesmith wrote ...
Now thats more like it. What sort of energy and what sort of result?
Electroholic, Sun Nov 01 2009, 06:06AM
well, with high enough energy, i would expect the wiener to just vaporize. and you probably want some sort of result. So, i would say <1kj, multiple firings, and a cooked wiener at the end.
Tesladownunder, Sun Nov 01 2009, 06:33AM
At 1kj (=3kV on my cap bank) the wire explodes to the edge of the hot dog and it drops to the ground unharmed.
At 2.6kJ (=5kV) this is the result. The hot dog just disappeared. It was just gone. I thought it must have just fallen out of sight but on a closer look this is what I found.
There were tiny pieces up to 30 feet away sprayed over my shed and driveway. Largest bit was thin and 3cm.
OK now for the prize. What happens if you put the hot dog directly on the electrodes and blast it with the same energy?
Dalus, Sun Nov 01 2009, 10:31AM
My vote, it will shoot away like a railgun projectile
..., Sun Nov 01 2009, 05:17PM
I suspect not much, the 2kj would be let loose over a long time (I suspect low ms), ad 2kj of energy isn't a whole lot of heat when absorbed by a whole hotdog...
But I would love to be proved wrong
Myke, Sun Nov 01 2009, 05:25PM
I think nothing because it will act as a large resistor. Maybe the hot dog exploded because when the wire broke, it created an arc that ate away at the hot dog?
Didn't you already put a hot dog on the rails of the cap bank before and it did nothing?
Tesladownunder, Sun Nov 01 2009, 06:08PM
Myke wrote ...
Correct both times. It jumps up a bit but is otherwise unscathed. No char marks or anything. But explode a wire inside and it ends up in many pieces. The resistance of a hotdog is about 2 Mohms or more so the discharge rate is slow. The exploding wire occurs along the whole of the wire which vaporises.
A previous experiment on this is
here.
klugesmith, Sun Nov 01 2009, 06:11PM
Like ... and Myke said: if the connections are good, the hot dog will just be slightly warmed in a fraction of a second. Not unlike the result when I discharge my HV cap into this copper sulfate resistor.
wicked alex, Thu Nov 05 2009, 10:26PM
Wath is this?
My new toy:-p
Tesladownunder, Fri Nov 06 2009, 12:48AM
I suspect it is an infrared camera with IR light source or laser.
But don't forget the title of this thread .....
Z28Fistergod, Fri Nov 06 2009, 02:37AM
wicked alex wrote ...
Wath is this?
My new toy:-p
Something really cool!
All hail wicked alex!
Electroholic, Fri Nov 06 2009, 06:41AM
is that a fused deposition cap on the right?
wicked alex, Fri Nov 06 2009, 03:52PM
Sorry did not see the TDU. :/
No, its not a camera, it has no laser or led.
Scott Fusare, Fri Nov 06 2009, 05:01PM
Looks like a 1st generation IR viewer. The cylinder on the left containing the battery for the HV supply?
Electroholic, Fri Nov 06 2009, 05:38PM
some sort of prototype image intensifier, I.E. night vision gogs?
wicked alex, Fri Nov 06 2009, 06:45PM
YES!! 1+
It is a home made Gen 3 Omni V Night Vision Monocular.
I payd 3000€ for it :P
Video:
Z28Fistergod, Fri Nov 06 2009, 07:35PM
Cool, get another and you'll have depth perception.
Tesladownunder, Sun Jan 02 2011, 07:29PM
Ha! Old threads never die, they just hibernate for a year.
I doubt anyone will get this although it will be plain with the explanation. I have never seen this common object viewed this way and was quite surprised how it turned out. Look at the colours in the enlargement - they have a name that we all recognise from a young age.
Any guesses?
william L, Sun Jan 02 2011, 08:27PM
some kind of tinsel?
Myke, Sun Jan 02 2011, 10:12PM
A hair diffracting sunlight? A bubble formed between two closely spaced wires?
Tesladownunder, Mon Jan 03 2011, 01:25AM
Nup.
This pic may help.
Wolfram, Mon Jan 03 2011, 01:56AM
Stars?
Myke, Mon Jan 03 2011, 03:29AM
Strands of nylon?
Tesladownunder, Mon Jan 03 2011, 03:44AM
Anders M. wrote ...
Stars?
Correct but you need to explain the first photo and the word we learnt when we were young that explains it.
Ash Small, Mon Jan 03 2011, 04:53AM
Well, it's some kind of refraction creating a rainbow like effect. Can't be ice on the lens because it's summer where you are.
Tesladownunder, Mon Jan 03 2011, 05:08AM
Ash Small wrote ...
Correct. But what causes refraction in a star image if it's not the lens?
..., Mon Jan 03 2011, 06:01AM
Is it just the normal 'twinkling' of the star?
I don't normally notice color variations in twinkling stars, but some old satellites have a very distinct color twinkling which I believe is due to diffraction in the solar cells (just like an oil slick).
Coronafix, Mon Jan 03 2011, 06:12AM
Orion?
Tesladownunder, Mon Jan 03 2011, 08:29AM
... wrote ...
Correct. You win.
From the nursery rhyme "twinkle, twinkle little star..."
It is simple twinkling of Alpha Centari, the 3rd brightest star. So what is "twinkling"?
This photo suggests it is colour and intensity changes on a tens of millisecond scale. The Star was fairly low in the sky hence presumably greater atmospheric effect.
It was taken with a 180mm lens and the camera was moved manually in an arc on the tripod during a 5 second exposure. What you see here is perhaps 1-2 seconds of transit. So perhaps 1 pixel per millisecond on this 1000 pixel wide reduced image.
I took it with a view to seeing what the International Space Station might see for a light on earth as bright as a bright star with a camera swept across rather than tracked.
This is for my project hoping to get the ISS to receive a morse code message from my world's brightest flashlight. My web site discussion and pics on it are
here .
Best to have further discussion on the "seen from space" topic here
World's brightest flashlight thread though.
Has anyone else taken a pic of this effect? If so start a new thread and leave a link to it here.
