  • Guests: 20
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
H-Bridge (World's Largest?)
Jrz126
Tue Oct 05 2010, 12:30AM
Jrz126 Registered Member #242 Joined: Thu Feb 23 2006, 11:37PM
Yeah, the OLTC worked ok. I was able to hit about 45" running off 120V. Tried running off 240V once, blew the connection out at the street. It was 15 years old, and underground. The guy from the electric company was surprised it didnt fail sooner. Lost my free time and interest in it after that. (graduating college, getting married.)
The bricks are pretty slow. Like 5uS turn on/off worst case. Should be interesting to see how it does.
Here's the datasheet: Link2
Power source for now will be the OLTC voltage tripler fed from the 240V mains coming in. I have 100A service and I'm atleast 100ft from the pig (probably closer to 150-200ft). That will probably be my limiting factor. During the hot summer days, the florescent lights in my lab would barely run. 95V with both my air conditioners running (one of them on the same circuit as the lights.)
I hope I have enough heatsink for them. If not, I'll stick a crapload of fans on it.
Here's the link to my website with the OLTC build info: Link2
ScotchTapeLord
Tue Oct 05 2010, 01:05AM
5 uS shouldn't be too bad for that big old secondary + streamer loading... do you plan on using phase lead? That'd probably help a lot.
Thu Oct 07 2010, 02:15PM
Wicked! Way to go suprised
Those IGBTs are from a traction inverter on an electric locomotive or something, right? That's the only thing I can think of that needs such big bricks.
Luca
Thu Oct 07 2010, 03:52PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Steve McConner wrote ...
They can also be used in high-power inverter such as for wind or solar power plants...
Luca
Fri Oct 08 2010, 07:58AM
Looking good, this will be one hell of a almost indestructible bridge tongue
rp181
Fri Oct 08 2010, 04:32PM
Check out piercemetals for cheap copper.
Nice bridge.
brtaman
Sun Oct 10 2010, 03:54PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Outstanding!
My suggestion would be to look into having tri-phase hooked up. ;)
Tesla Fan
Sun Oct 24 2010, 12:35AM
Tesla Fan Registered Member #3353 Joined: Sat Oct 23 2010, 11:21PM
Really impressive !
Good luck with your project!
