  • Guests: 44
My MiniBrute and my first coil
Sat Aug 14 2010, 01:32AM Print
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Primary wound, took 4 hours!, just need to cut off the excess copper :-
4889138997 E98a9034da Z
Squaring up and marking the corner pillars to drill them for the inserts :-
4889151223 7f3ca3d3cd Z
The wood (utile) is going to need a bit more work, sanding, varnishing etc. later but the base is taking shape :-
4889151765 F8758f97a4 Z
Test piece for the primary cable gland, I haven't done much work with PVC before so wanted to check I could tap it OK before attacking the actual base. :-
4889733252 694ef293c1 Z
Looks OK but lucky I did a test, look at the state of the other two holes smile
4889733750 74938742c6 Z
Couldn't do much to it today but it's getting there. Unfortunately the tube for the secondary was supposed to turn up last week but didn't frown Hopefully I'll get it next week.
4891069101 A646175790 Z
Seems UPS have lost the secondary tube frown As I haven't ordered up any of the electronics bits yet the project has stalled a bit. Today I made up a nice Brass thumbscrew out of a surplus belt idler from an old bank note reader and an M6 screw :-
4898926568 100d3f404a B
Solder idler wheel to screw (or is it screw to idler wheel)
4898335369 A00665d127 Z
A bit of cleaning up.
4898929338 5cf3642061 Z
And a bit OTT but rather nice ground lead attachment for the strike rail (I also made a small grub screw to secure the strike rail tube out of the same screw)
4898338531 1aae427f04 Z
In the absence of the tube looks like I'll be getting onto the topload sooner than expected I've never done any spinning but luckily there is a spinners near me and they've been quite helpful with advice. first is a cad drawing of the two forms needed. The stepped outline is because I'll be glueing sheets together and I'll pre-cut them into rings to reduce the amount of wood I have to remove when turning the forms :-
4898332351 F5f0a838de Z
24/10/1010
Finally got started on the secondary.
Is this overkill? (actually the hoists were already there from when I installed the lathe smile )
5113467339 Bbf3d11de7 Z
5114065256 1df6c15ef7
5114065258 49a7bc04a4 Z
Modified pedometer as turns counter, secured with cable ties and gaffer tape (of course!)
5114065250 A78e604e91
5114065260 E99bbbc78c
5114065290 62c432b007 Z
The lathe has been geared as low as it can go and I'm using a 3 phase inverter drive to control the motor speed. I started around 8Hz but have got it up to about 12 Hz now. It's taking around 15 minutes to do 100 turns I stop for a while every 100 turns as I'm worried about the motor overheating if run slowly for long periods. For winding I control the motor and tension the wire with my left hand and use the back of my right thumbnail to guide the wire and keep the coil tight on the former. I tried to upload some video's but I'm having issues with You tube at the moment.
5113467335 118f32d123 Z
5113467337 81be3b305b Z
Finished winding
5115923942 1b04bb0fa8
5115323711 E0971f369d
and finally managed to get the vids uploaded to Youtube
Higher res. photos at my flickr group Link2
[Edit: Image size]
Sat Aug 14 2010, 09:47AM
Looks nice, hope to see it completed soon =D
Mon Aug 16 2010, 10:29PM
Thanks, project post has been updated due to upcoming work there may be gaps of several weeks in updates depending on how busy I am.
Martin.
Mon Oct 25 2010, 11:49AM
Main post has been updated with pictures of winding the secondary.
Martin.
dingo27
Mon Oct 25 2010, 12:14PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
I love the way you used that rotary machine to wind secondary! cheesey
Mon Oct 25 2010, 10:51PM
Thanks, finally managed to get the vids uploaded. I upped the motor speed as I felt more confident so only took an hour to finish it tonight. Still deciding on varnish vs. epoxy although I guess I could varnish it and then epoxy it later.
