  • Guests: 42
"A Safe Jacob's Ladder"
Avi
Thu Nov 04 2010, 08:22AM Print
I found this, some of you may be interested in the concept.
Thu Nov 04 2010, 10:24AM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
I've sometimes seen requirements for jacobs ladder type effects to be used on stage so that would be a good way of doing it.
Martin.
Adam Munich
Thu Nov 04 2010, 10:51AM
Oh that's not fooling anyone. I came to this thread expecting something along the lines of a GFCI that killed it if it detected a "short". Something like the sawstop but for jacob's ladders.
Killa-X
Thu Nov 04 2010, 02:39PM
Grenadier wrote ...
Then you just get a board install 4 corner pillars, and install some optical sensors. This way when something like a hand passes through, power is cut :P
If you really wanted one for Halloween all you do us just fence the area off :P
Adam Munich
Thu Nov 04 2010, 07:38PM
Jacobs ladder + 445nm 1W laser trip sensor FTW. That would look really cool, and be safe.
Killa-X
Thu Nov 04 2010, 08:01PM
Grenadier wrote ...
And then, the poor kid with the pretty metal bracelet, tries to go at it...The laser turns it off, but oh dear god, it shot into his/her eye! Instantly blinded...This is why we use like a 0.1 or 0.01mW laser...
Adam Munich
Thu Nov 04 2010, 10:32PM
It was just an idea, it's not like anyone would even consider relying on a laser to protect that little kid from 15,000 volts anyway. However, it would make a beast Halloween prop. I mean who wouldn't like a jacob's ladder inside a laser cage?
Also, I'd rather get a diffused* laser blast to the eye than be electrocuted any day, and I'm sure someone else would too.
*bracelet would have convex metal surfaces.
Killa-X
Fri Nov 05 2010, 12:25AM
I can touch a NST and probably live given it was one hand....or I can get instantly blinded by a diffused 1W....you do relies these blue 1W will blind you very very quickly, if not instantly, even if it's diffused to say...10ft wide on your face.
But yeah I get your point...
If you want a safe visible beam, get a little smoke from a smoke machine and use a 1mw red. Then it's ladder in smoke :D
