  • Guests: 56
Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
02/05 teslaguy (36)
Half Bridge and Full Bridge Mosfet Drivers
ZkerHV
Tue Nov 02 2010, 09:45PM Print
ZkerHV Registered Member #3387 Joined: Tue Nov 02 2010, 09:40PM
Hello, I am pretty experienced with the art of electronics, high voltage, etc, but I need someone to explain to me exactly what a H-Bridge and F-bridge is. I know it acts just like a mosfet, but how are they driven? Could someone please post an explanation/schematic so that i can understand this better?
Cheers,
Zak
ScotchTapeLord
Tue Nov 02 2010, 10:07PM
Half bridges and full bridges are both classified as H-Bridges. The H isn't an abbreviation, but rather, a reference to the way the circuit looks when put together.
An H bridge arranges four switches (usually mosfets or igbts) so that a dc supply voltage can be applied across a load in either direction. If you're interested in using it with high voltage, then you probably want to use it as an inverter to drive something that requires HF AC.
Each switch must be driven in proper phase so as to pass current through the load, yet each drive supply has to be isolated from everything else. We most often use Gate Drive Transformers.
Perhaps if you had a specific question regarding a specific schematic that you may have found from Link2 we could address your query more fully.
EDIT: *A full bridge uses 4 switches, a half bridge uses 2 in a similar fashion
