  • Guests: 76
Bipolar CW Multiplier - 12Levels
radhoo
Fri Oct 29 2010, 08:17PM Print
Mon Nov 22 2010
I re-created this device using a new design:
- the diodes (rated at 12KV 10mA) where connected in parallel pairs for 12KV 20mA
- the caps (6KV 10nF) where connected in series for 12KV 5nF
- the multiplier has 12 levels now, half is a 6 level negative multiplier and the other half is a 6 level positive multiplier, to reduce the ripple effect.
- a ZVS driver and a Flyback were added to an enclosure containing the multiplier for a ready-to-go 12V to 50KV supply.
Schematics:
150x150
Construction details:
I use it with max 12V input. For 10V in it puts out aprox. 50KV. I tried to power a lifter and worked well. It doesn't heat, and can run for a long time. A short video: Link2
150x150
Fri Oct 29 2010
Hi Guys,
Some time after I had the chance to test a Glassman high voltage multiplier module, I decided to build my own multiplier, to have everything as per my requirements.
So I come up with this 28 stages half wave multiplier.
See the construction details, x-ray tests and how to further connect a TV cascade to this multiplier here:
A few pictures attached:
1288383420 1938 FT0 P1110171
1288383420 1938 FT0 P1110176
1288383420 1938 FT0 P1110181
1288383420 1938 FT0 P1110183
1288383420 1938 FT0 P1110184
1288383420 1938 FT0 P1110189
Fri Oct 29 2010, 10:12PM
Did the Geiger detector pick up anything?
The little black Russian one.
radhoo
Fri Oct 29 2010, 11:23PM
yes . that one was also beeping. I can wrap them in aluminum foil and retest just to be sure it is photons what's causing the high-count. but not before I get some lead for setting up a shield for the tube.
radhoo
Mon Nov 22 2010, 08:44AM
Since I was feeding 10KV into this multiplier, much over the components rating, one of the capacitors failed, resulting in short circuit of the entire multiplier. So I had to dismantle it, clean the oil and do a better design.
I've modified the first post to show the current status.
radhoo
Fri Dec 10 2010, 06:11PM
I'm close to completing my HV voltmeter, so I hope to be able to better estimate the output: Link2
