flyback->voltage tripler. Does anyone have any experience of building one? I c..." />
  • Guests: 50
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Anyone built the JLN 30kV DC supply?
Steve Hobley
Wed Oct 27 2010, 05:07PM Print
Steve Hobley Registered Member #1731 Joined: Thu Oct 02 2008, 02:22PM
I want to give a demonstration of the "lifter" effect, and so I need to put together a supply.
The JLN site seems to have the "standard" design using a driver->flyback->voltage tripler.
I can see many flyback transformers available online for around $20 (I just threw out an old TV set last month too - could have kicked myself) but is there anything I need to be aware of when selecting one?
The voltage tripler seems to be the NTE521 (about $30) - can someone confirm that this will perform correctly?
Thanks,
Steve
Antonio
Wed Oct 27 2010, 10:27PM
A regular CRT TV/monitor fyback transformer without a tripler is enough. I have something here:
Avi
Sat Oct 30 2010, 03:02AM
I made one, its only for use with AC flybacks, any other type is already 30kv and has internals diodes or an internal voltage tripler in the flyback package
Steve Hobley
Mon Nov 08 2010, 03:05PM
So I stripped an old RCA TV for parts the other day, and managed to extract a flyback labelled PN: 2F25010-503 which after some Googling is equivalent to the HR7280.
I found this schematic for the HR7280:
On Naudin's page he uses the HR7839:
Page: Link2
PSU Schematic : Link2
HR7839 Schematic : Link2
where he connects 1+2 to the supply, 8 to GND and HV is out - it looks like his ratio of turns is going to be higher, because in mine (HR7280) I am supposed to connect between 6 and 9, and that looks like more turns on the primary.
Would connecting between 5+9 in mine, be the same as connecting between 1+2 on his.
I'm not sure how I would go about testing the flyback connections without the correct test equipment - I've done some simple resistance measurements on the coils and got results that I would expect. But I can't test the HV line because of the diodes.
Any thoughts?
Mon Nov 08 2010, 04:15PM
Steve Hobley wrote ...
The primary winding on HR7280 is across pins 6 & 9. The taps are auto-transformer take-outs. LOPT designers compete with eachother to see who can power the most discrete sub-circuits in a TV from the one transformer, which should explain the proliferation of taps and windings on most modern diode-split LOPTs.
You will note from the HR Diemen datasheet that HR7280 is intended to supply 20.7kV, while the HR7839 used by the mad Frenchman in his many strange and unbelievable marvels is an altogether more muscular component with an intended output of 29.5kV.
I say "intended output" to emphasise the figures are given for normal television service, where the LOPT must run 24/7/365.
Steve Hobley
Mon Nov 08 2010, 04:42PM
Thanks for the reply.
So I need to look at a bigger television then...?
I'm also struggling to find a transformer that can supply the 48v AC - can I put two 24v in parallel to accomplish this?
I guess the ferrite cores are not "linked" so you cannot double the voltage output, only the current handling.
Steve Hobley
Thu Nov 11 2010, 04:06AM
So...
I built the basic Naudin driver using parts from the TV set I salvaged, at the moment I'm driving the primary with a 12v lead acid battery. I set the frequency to 15kHz.
When I switch on the S2000N transistor gets warm and I can hear the TV "singing" noise after a couple of seconds (the sound goes away when I replace the primary connection with a simple resistor) - so I think it's working, but I can't seem to draw an arc from the HV terminal.
The design calls for 50V as a drive - I can hook up a variable transformer / rectifier and cap to provide anything from 0 to 100V DC.
So I'm thinking of doing that next - can anyone tell me if there's anything wrong with this approach?
Bjørn
Thu Nov 11 2010, 05:44AM
You can put transformers in series, just make sure you got the phase correctly or the voltages will be subtracted instead of added.
Do you have an oscilloscope? If not you really should invest in one, it will make everything a lot simpler.
If you got a 7812 regulator you need more than 12V for reliable operation since the regulators usually like to drop 2-3V.
Steve Hobley
Thu Nov 11 2010, 01:22PM
Thanks for the response.
Yes I do have a couple of scopes.
The 12V regulator is just to supply the electronics, the batteries are pushing the primary coil.
I think I'm going to go ahead and try around 50V DC and see what happens. The fact that I'm getting the singing noise is encouraging.
I brought up the question of "ganging" transformers on Dutchforce and they confirmed that you can build approx 50v from 2 24v transformers. I have several variacs however, so I don't think I need to go down that path.
Thu Nov 11 2010, 08:50PM
becareful using an o-scope even on the low voltage side, there can be kick-back to beyond 300 volts, iggies, and flybacks can murder instruments quite easily.
