  • Guests: 36
SSTC questions
kiat
Wed Oct 27 2010, 05:50AM Print
kiat Registered Member #2115 Joined: Fri May 08 2009, 01:17PM
I'm currently building a ~3kw sstc, using Steve Conner's PLL driver.
The secondary is a 4.5"*13" PVC pipe, wound with 30AWG magnet wire. its Fo is 285kHz, and with a 1.25"*8" topload it becomes around 185kHz.
Now for the fullbridge ive got some FQA24N50s, (data here: http://www.farnell.com/datasheets/82054.pdf .) Im not sure if they are good, because the switching time looks horrible in comparison to an IRFP460. I can always switch back to IRFP460's
Now for the questions:
-Are the 24N50's too slow or too high on resistance for a 3kw SSTC?
-Is a breakout point on the secondary required?
-Is Steve Ward's or Steve Conner's PLL driver better?
-I don't have access to a proper RF ground. So for this power levels is using the mains ground suitable? will the type of grounding affect a CT feedback if its implemented?
Thanks
kiat
Wed Oct 27 2010, 02:53PM
1. RDS(on) is about the same for the two, at 3kW the power dissipated, very loosely calculated, difference between the two is 6-7W.
You are running at 185kHz which should be low enough for the 24N50s to work well. Try them, blow them, try IRFP460, blow those... etc :)
2. A breakout is required for a SSTC, the times where my breakout point fixed with tape broke off due to the tape melting from the heat resulted in a blown bridge, the stress on the bridge to build up the potential in the smooth topload to make it breakout is simply too large.
3. I have only tried wards drivers, I am satisfied and confident with it.
4. I have used my SSTC running somewhere around 2-4kW in CW mode through normal household ground without problems, didn't unplug computers etc, but they were turned off.
