  • Guests: 58
Mini SGTC
Michalis.Biochem
Sun Oct 24 2010, 01:30PM Print
Michalis.Biochem Registered Member #3340 Joined: Wed Oct 20 2010, 07:28PM
Can this transformer be of a use for a small battery powered tesla coil?
It was taken from a CFL electronic ballast circuit. I can also see that there is something written on it. It says 4,2MM thought i dont know what this might mean.
Thanks in advance!
P.S sorry for the blurry images.
1287927051 3340 FT0 053
1287927051 3340 FT0 054
1287927051 3340 FT0 055
1287927051 3340 FT0 051
radioman
Sun Oct 24 2010, 02:10PM
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
Biochem,
Judging by the size if it, the answer is “no”. You need to use an auto ignition coil for your transformer in a battery powered tesla coil (it will give you at least 20,000 volts). I built a small tesla from an article in a 1961 Experimenter’s Handbook. It will do a nice one inch spark, and was a good place for me to start this hobby. Look on line for similar plans. Good luck!
Radioman
Michalis.Biochem
Sun Oct 24 2010, 02:30PM
I found a thread that the poster claimed that his SGTC was assembled with 2 camera circuit board transformers
So i suppose that a CFL transformer would work
william L
Sun Oct 24 2010, 05:16PM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
Well, The first tesla coil I ever successfully built was a spark gap coil about 2 inches high, and it was powered by a cold cathode fluorescent lamp driver from a scanner. I would build a small 555 driver for this thing, an see what it's output voltage is.
Michalis.Biochem
Sun Oct 24 2010, 09:28PM
william L wrote ...
So do you think that a normal CFL would do as a driver?
Sun Oct 24 2010, 10:31PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
perhaps, but not well. It would be better if you used those giant based cfls, they are around 40-60 watts and weigh 1/2 of a pound
PAul
Michalis.Biochem
Mon Oct 25 2010, 07:48AM
803 wrote ...
PAul
But in that way i would need to power my TC from the mains and not from batteries. Am i right?
