  • Guests: 41
cap over the secondary coil
alaa
Fri Oct 22 2010, 07:37AM Print
alaa Registered Member #1998 Joined: Wed Feb 25 2009, 08:03PM
hi all
i need answer about simple question
why in all tesla coil projects see cap over the secondary coil
Fri Oct 22 2010, 12:57PM
Its actually called a topload and the particular shape you are referring to is called a toroid.
Basically, it provides additional capacitance to load down the secondary (extra C) as well as provide electrical gradient shaping between the top of secondary and lower portions of secondary / primary to reduce arc-overs.
radioman
Fri Oct 22 2010, 01:08PM
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
Hi Alaa,
The ”cap” as you call it, is an essential part of the coil. It is a “terminal capacitor” which stores energy until enough is built up to “break out” into streamers. It is ideally shaped like a donut or “toroid”. The shape and size affects the resonant frequency of your secondary coil.
Fri Oct 22 2010, 05:44PM
If on the other hand you mean a cap covering the end of the coil former,
it's to help keep arcs from the inside of the coil, insulation.
alaa
Sat Oct 23 2010, 12:37AM
much more thanks for all
