  • Guests: 40
Do all 2 transistor / 24V SSTC's have to use flyback transformers?
Steve Hobley
Thu Oct 21 2010, 02:40PM Print
Steve Hobley Registered Member #1731 Joined: Thu Oct 02 2008, 02:22PM
I've been reading up on simple 2 transistor Tesla coils - like the one here:
What is the reason for using a Flyback transformer for the primary/secondary? Is it not possible to push enough current through the transistors to run a more traditional air cored design (albeit very small).
Steve
Thu Oct 21 2010, 02:58PM
Google the "Skori tesla coil", an air-cored design that runs entirely off 24V. Unfortunately the planz are all in Hungarian.
Planz Link2
dingo27
Thu Oct 21 2010, 03:35PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
I think that what you posted is not sstc schematic, but flyback driver.
Sam Barros on powerlabs.org has a useful circuit with just one 2n3055
Ken M.
Thu Oct 21 2010, 06:11PM
It is a SSTC schematic I have made one and it worked until I realized I made some bad design choices especially the ground wire for the secondary being a jumper wire. Managed to get it to run for about 10mins then spark length decreased dramatically and something started to burn, noticed the ground wire s insulation was discolored and slightly bubbling, pulled off the insulation and ran the coil, about 30sec I saw the ground wire glow red hot.
Steve Hobley
Thu Oct 21 2010, 06:39PM
I checked out the Skori design - a little more complex, but the parts look quite easy to get:
Does anyone know what the function of C4/L4 in version 3? They are missing from his assembly photo - it looks like a simple LC network 50mH + 3.3nF - but I'm unclear as to its function.
Thanks,
Steve
Fri Oct 22 2010, 01:45AM
Steve Hobley wrote ...
Thanks,
Steve
I don't understand that schematic :P. I mean, what is with all the series diodes? I guess it is to clamp the bridge rectifier to ground when the diodes are forward biased, using the forward voltage drop to allow bias? And the GDT goes to the gates then through a bridge rectifier O_O. I guess those two things have something to do with some very off interrupt scheme. And how about this transistor on the primary. What purpose does it serve? And apparently the L-C you are talking about has to resonate at the freq of the secondary... WHAT?!
BTW, this is the schematic i am going by: Link2 From this page: Link2
Update:
About the transistor on the primary: Tranyót PNP used to protect the surge re-changed, so the collector to GND is therefore not be subject to isolation, the hütöfelületet connect the grounding (of course you can combine with another is not already installed)
As for the L-C circuit: C4 L4 and only later to be incorporated in the previous versions have already put it as a way to more stable the frequency (the Tesla coil can have more resonance) and much less prone to sparking the primary to the secondary (ie, it may be closer - closer to the coupling ).
MOAR UPDATE: This is what he stated about the string of diodes.
The voltage capacitor C4 D8 ... D12 -3 ...- limit at around 4V (a 3.6 V zener is more powerful it would be nice here, but it seemed like a better solution)
D1, D2, D4, D5 diódáknak fontos szerepe van abban is, hogy a fetek megfelelö munkapontban müködjenek. A fetek gate feszültségét kb. D1, D2, D4, D5 diodes have an important role also in the corresponding point-fets work. Fets the gate voltage of approx. +15V és -4V értékek között tartják. R1 és R2 csak addig határozza meg a munkapontot amíg a (TR1-en) visszacsatolt feszülség alacsonyabb a diódák nyitásához szükséges feszültségnél. +15 V and-4V values are held. R1 and R2 only be determined by the set point until the (en-TR1) feszülség feedback diodes are required to open the lower voltage. Ezzel elérhetö hogy a 2 fet lényegében felválva fog kinyitni, illetve lezárni. This way that the 2 fet felválva will essentially open or closed
This is giving me a raging brainor.
Ken M.
Fri Oct 22 2010, 05:06AM
Him using various parts which could be implemented with better parts is probably due to him being in Hungarian, and having a limited budget.
ManiaC
Fri Oct 22 2010, 05:57AM
ManiaC Registered Member #2763 Joined: Sat Mar 27 2010, 11:48AM
it is possible to do one transistor (NPN) Tesla coil
below the pictures of my Tesla
schematic & PCB
Fri Oct 22 2010, 10:06AM
Alas, had he only been in English so better parts were available. tongue
Steve explains how the circuit functions further up in the thread Ken linked to.
Steve Hobley
Fri Oct 22 2010, 02:42PM
Yeah it's confusing me too...
Regarding the SF18 diodes, the key attribute seems to be the 35ns switching time - I don't seem to be able to find much info in datasheetland regarding timing. Is 35ns something special, how fast does a "regular" diode switch?
