  • Guests: 40
MMC Under oil
Alchemist
Thu Oct 21 2010, 04:35AM Print
Alchemist Registered Member #3326 Joined: Sun Oct 17 2010, 09:49PM
I'm putting together an MMC for my coil, and am wondering if there is any benefit/drawback to putting it under oil? The caps I'm using are the square type made for PCB mount, but I'm just wiring them in strings with bleed off resistor leads joining them. The end result is I have a bunch of cap lead pointing straight up out of the solder joints. I'm a bit worried about corona discharge from the points, and I have a gallon of mineral oil left over from building my MOT 4-pack so should I immerse the MMC?
Goodchild
Sat Oct 23 2010, 07:04AM
I don't think it would hurt to put them in oil. As long as your caps are rated at the voltage you plan to run them at, there should be no problem running them in open air.
Herr Zapp
Sat Oct 23 2010, 03:46PM
Alchemist -
I'd recommend against it. If you've built your MMC with reasonble attention to separation distance, there should be no problem with cap-to-cap arcing. Remember that the voltage will divide (more or less) evenly across all the caps in a single string, so voltage between adjacent caps should not be extreme. To reduce corona from the ends of the cap leads, just use a needle-nose pliers to form the protruding lead into a small circle.
Submerging the caps in oil will inevitably cause a mess, no matter how thoroughly you try to seal the caps in some kind of oil-proof enclosure, as well as complicating things if you ever need to replace a cap.
Herr Zapp
