  • Guests: 61
Michael Witt (36)
AleSeg (15)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
In waaay over my head. (sourcing IGBTs)
sniglet
Thu Oct 21 2010, 02:38AM Print
sniglet Registered Member #3339 Joined: Wed Oct 20 2010, 03:12PM
First, I REALLY appreciate your patience, there are holes in my knowledge, I suspect they're bigger than I'd like)
So I bought aautomation's sstc kit. It states it's NOT a beginner's kit. He's not kidding. I've got some rudimenatry background (automotive electrical, home wiring, wiring up a VFD for the lathe, Burning proms for the Vette, Basic Stamp stuff) I put it together, but it needs an oscilloscope, so I build one of those first ( http://www.sparkfun.com/commerce/product_info.php?products_id=9484 ) In ignoring some of the recommendations, I burn out the IGBT's and a fuse. (after getting three discharges)
Replace them with spares he kindly included, built a signal generator ( this one: http://www.canakit.com/200khz-sine-1mhz-square-function-generator-kit-ck307b-uk307b-ck307-uk307.html ) to send 4 VAC to the AC side (rather than the 12 VAC from the power supply) and learn about current. (Voltage supplied dropped from 4 VAC to .3 VAC when the power was turned on.)
Built a 7 VAC power supply with a radioshack transformer that could drive the circuit. Got about 5 minutes use this time, producing approximately 2 cm long sparks. I was homing in on tuning the primary coil when the sparks went away. So, improvement, but the results are still terminal, and honestly I am I'll equipped to speak about this stuff. sad
The IGBT's are a) out of stock, b) Half a world away, c) $18 a piece, d) and will ship in 4 to six weeks, in e)lots of 1000 pieces. A little research has shown they're pricey as they are out of production.
So can I replace FGL60N100BNTD IGBT's (Collector voltage 1000V, 60 Amp Collector current at 25C, 42 Amp Collector current at 100C) with IGBT's within 20% of those values? There's no shortage of 600V IGBTs ($3.67 60Amp/30 Amp), or 1200V IGBTs ($5.53, 60 Amp at 25 C, 30 Amp at 100C) but for electrical stuff, I'm kind of plug and play and don't understand the theory beyond a really high level.
FWIW, my research here leads me to think part of the problem is heat rejection in the latter attempt, and too much voltage on the initial attempt. At least I'm not making the same problems each time.
brtaman
Thu Oct 21 2010, 06:01AM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
There is nothing special about the IGBT's you want to replace.
However, I am not familiar with the kit you purchased. I would be happy to help with your choice, if you provide more detail.
How does the SSTC function? Is it a DRSSTC with a tuned primary circuit, or a regular SSTC that is interrupted or perhaps CW? What is the Operating Frequency of your secondary coil?
Some pictures of your setup would also be good, if you are blowing IGBT's I would address potential problems in the build first, before blowing up more silicon.
The IGBTs aren't exactly lightning fast and there is quite a few possible replacements out there. If you provide links to the IGBT's you are considering purchasing , a recommendation can be made.
Best Regards,
brtaman
sniglet
Thu Oct 21 2010, 12:11PM
Photos of the build are here: Link2
the schematic is here: Link2
The last three photos of the board are how it exists today. I have to apologize at the condition of it. I used a TON of solder on the first pair of IGBTS, the scorching you see is from trying to use a micro-torch and desoldering braid to remove the solder. (I've since moved to a vacuum bulb with much better results, I've also taken to cutting the dead chip out, then removing the wire and solder as it gave better, quicker, cooler access to the area for removal. It IS electrically sound.
It _IS_ a DRSSTC, but it only lists two IGBT's, not '4 IGBTs in an H-drive configuration. I don't know the operating frequency of the secondary as the kit claims it's 'control circuits handle the part of finding the secondary coil's resonant frequency qutomatically'.
The original IGBTS are Fairchild FGL60N100BNTD ( Link2 )
Possible, but not exact replacements:
International Rectifier IRG4PC60UPBF link ( 600v, 40 A @ 100C, 75 A @ 25C, $4.83)
Fairchild FGA20N120FTD link (1200V 80 A @ 25C, 40A @ 100C, $8.26)
I've verified the TTL Side is producing the proper waveforms. I did NOT replace the electrolytics as they appear to be operating, at least partially, in the last test with the 2 cm sparks.
I had hoped to have it running for Halloween (it's supposed to be the focalpoint of Frankenstein's lab, last year that was a Jacob's Ladder) But i suspect it's just going to be static window dressing.
Maurizio Valvo
Fri Oct 22 2010, 10:49PM
Maurizio Valvo Registered Member #3219 Joined: Mon Sept 20 2010, 09:06PM
I have used for my full bridge DRSSTC (running from 230Vac rectified mains) IXGR 60N60C2D1, 600V, 75A, 300A pulsed (IXYS HiPerFAST series).
Ken M.
Sat Oct 23 2010, 12:01AM
I may have a missunderstanding about DRSSTC but I'm pretty sure thats an interrupted SSTC.
I this because if you look at most of the DRSSTC's built on this forum most have CT's on the primary side to monitor primary current and voltage since a DRSSTC has both the primary and secondary coils resonating, creating high current pulses as well as high voltage spikes...
Try putting some ZVS diodes (think thats what they're called) across the C and E of the igbt's the internal anti parallel diode in most fets and IGBts recover too slowly and receive huge current spikes causing the igbt or fet to die.
dmg
Sat Oct 23 2010, 12:21AM
They are called TVS diodes (transient voltage suppression), the 1.5KE series are quite good for these.
also, be sure to get the bidirectional ones (suffix of part # is CA for bi), instead of the unidirectional TVS
mounting the TVS as close to the IGBT as possible is needed for them to actually be of any use for stoping those transients.
Sat Oct 23 2010, 06:23AM
What are you feeding the "Logic Input" with?
It should be short (maybe 50 to 250 us) pulses, you need an 'interrupter'
if the logic input is active for too long it will blow your transistors,
start with a low repetition frequency, 1 to 10 Hz with a short ON time, 50 us
and slowly increase the ON time for more spark power,
too much and you'll need new transistors!
Maybe sparkfun have an Interrupter kit?
Personally I'd connect the center-tap of T2 secondary to the junction of C1 & C2 to protect the eletrolytics from over-volting.
Goodchild
Sat Oct 23 2010, 06:45AM
Ken M. wrote ...
Were the feedback comes from has nothing to do with what type of coil it is. What defines a DRSSTC is it having a resonant tank circuit.
Ken M.
Sat Oct 23 2010, 10:10AM
That's sort of what I figured Goodchild, originally I thought I would say "ALL DRSSTC's on this forum" but I had shot myself in the foot saying things like that too many times, so I looked at some of the DRSSTC's and sure enough STeve ward has a secondary Base feedback DRSSTC, albeit it was his .5 DRSSTC, but none the less.
So I guess that means one could make a DRSSTC that gets the frequency off of the secondary but still implements a OCD on the primary.
Back to the original topic, Looking at the schematic again and Noticed that it has a 120:12V step down that then feeds into a 110,110:12V,12V wired as a step up, and the schematic says 400v, unless I've totally lost base with my basic AC knowledge wouldn't that only produce 220v?
Lethal Shot
Sat Oct 23 2010, 01:13PM
Lethal Shot Registered Member #1623 Joined: Tue Aug 05 2008, 03:31PM
Don't forget that the AC waveform is rectified meaning the DC voltage is sqrt(2) * VAC = 310V.
Where the figure 400VDC comes from is a mistery to myself too, it is probably chosen this way to be on the safe side when selecting components.
The thing that strikes me as odd is the low voltage of the MMC (only 2kV), isn't the impendance of the capacitor going to drive the voltage across it much higher in high current DRSSTC operation?
