  • Guests: 35
M.O.V.s
radioman
Tue Oct 19 2010, 02:21PM Print
radioman Registered Member #3026 Joined: Fri Jul 23 2010, 02:46PM
Can anyone recommend a specific M.O.V. for the Terry Filter I am trying to build? And where to get it? My NST is 7500 volts 30 ma if that makes a difference.
Thanks!
Herr Zapp
Tue Oct 19 2010, 02:44PM
radioman -
The MOVs are not really necessary in a Terry filter, and have been problematic for some people.
1. If you set your safety gaps correctly, the MOVs are redundant.
2. There is typically a large tolerance on MOV "breakover" voltage, so when you string a number of them together in series, you really don't accurately know what voltage they begin to clamp at.
3. Having a fixed string of MOVs makes it more difficult to use a variac to "boost" NST output, or switch NSTs (like going from your current 7.5kV unit to a 9kV, or 10.5kV NST).
4. MOVs are limited-life devices.
Just set your safety gaps correctly and keep them clean, and build the Terry filter minus the MOVs.
Herr Zapp
