  • Guests: 53
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
sstc trouble. (killing mosfet's and more)
Duality
Mon Oct 18 2010, 06:39PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
hi, I have build steve's mini sstc and i worked fine till now.
it's a mosfet killing machine. i don't know what i'm doing wrong.
it run's for a few seconds then die's. frown
also I hear sound coming from the primary. but i can't find any coal or burn marks.
made a vid about the problem.
steve's mini sstc:
Ken M.
Mon Oct 18 2010, 08:26PM
Check your waveform out of the GDT, and check your DC blocking caps. You're getting shoot through and it's frying your fets, by turning them both on at teh same time, I'm pretty sure everyone including myself has had this issue, with Steves design, its not a bad design its just very sensitive.
Mon Oct 18 2010, 08:54PM
I understand from your video that you power this coil up instantly at full power?
If this is the case, it might just be that your secondary/topload setup is not suitable for full voltage, I have tried this before where I changed the topload to a smaller topload, thus raising the Fres, higher stress on the FETs which blew up.
I recommend lowering the Fres and use a variac to power your coil at reduced voltage, raising the voltage slowly gives you a better chance of finding and correcting problems before it goes boom...
Where are your heatsinks on the FETs?
Duality
Mon Oct 18 2010, 08:59PM
Mads Barnkob wrote ...
in the cover of the box, uh never needed it in interrupter mode.
so, i am gonna try a bigger top load, and gonna scope the gdt output.
how am i gonna scope the output, when the coil is running or just the output from the interrupter?
ow and sadly i don't have a variac
Duality
Tue Oct 19 2010, 08:01PM
i got an update:
wave form with and without the scope.
Marko
Tue Oct 19 2010, 08:08PM
R v.d. Tuuk wrote ...
Let me get this straight, you admit your mosfets are just hanging like that without any heatsink on them, and you wonder why they blow up after few seconds of CW operation? confused
Marko
Duality
Tue Oct 19 2010, 08:18PM
Marko wrote ...
Marko
uh they never get warm?
they die cold frown mad
Wolfram
Wed Oct 20 2010, 10:48AM
They probably get warm and die, but because of the low thermal mass and your fan, they get cold again by the time you check their temperature.
Anders M.
Duality
Wed Oct 20 2010, 12:44PM
ok i'll mount em to the heatsink, but the wave forms i scoped borther me... i posted a link to a vid about that.
Duality
Wed Oct 20 2010, 08:40PM
ok. what should i say?
i have no mosfet's left. the heatsink did not help frown
