  • Guests: 66
SSTC/DRSSTC gate resistors
kiat
Sun Oct 17 2010, 09:39AM Print
kiat Registered Member #2115 Joined: Fri May 08 2009, 01:17PM
Hi all
I'm just curious on the differences between primary side and secondary side gate resistors in gate driver circuit. Is there any difference in performance between having a big primary side resistor vs 2 or 4 gate resistors at each of the MOSFET gates? Will performance be the dsame if the primary resistor is sized the same as the parallel value of the secondary resistors?
And how should the value an power rating of the resistors be found? Is it by pure experementation?
Cheers
kiat
Sun Oct 17 2010, 09:53AM
Read from page 30 about "TRANSFORMER COUPLED GATE
DRIVES" in this excellent paper from TI: Link2
Sun Oct 17 2010, 01:37PM
I would always put a small value resistor right next to the gate of a MOSFET. Its important to get this as close as possible, and to also couple both outgoing and return lines (from the MOSFET) to reduce inductance. This will provide for a better gate waveform and reduce an oscillation due to parasitics. The gate resistor provides damping to reduce parasitic oscillations as well as limit the peak charge current into the gate which makes it more prone to parasitic oscillations. A value of 1-10 ohms is typically used.
I almost always us 5.1 resistor for my DRSSTC gates (low frequency), and for my 4MHz coils which use 14A IXYS gate drivers, I use 1.6 ohm gate resistors.
Dan
Goodchild
Sun Oct 17 2010, 04:57PM
Gate resistors also help to slow the rate of turn on so that to add dead time to each switching cycle. This dead time helps to prevent shoot through (shorting of the bus for a short amount of time on each cycle).
