  • Guests: 29
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Post Pics of Odd/Old Parts and/or Fancy Glowing Tubes.
first  5 6 7 8
mikeselectricstuff
Tue Jan 04 2011, 11:41PM
Grenadier wrote ...
I don't even know what that is, but I want one!
Mercury vapour rectifier. Not as cool as a mercury arc rectifier though Bpmar
Adam Munich
Wed Jan 05 2011, 12:01AM
I'd give anything to get one of those. ^^
Wyatt
Wed Jan 05 2011, 01:34AM
Wyatt Registered Member #3490 Joined: Wed Dec 08 2010, 11:55PM
Please ignore my previous post,I dont know what happened. Anyone know of any practical use for these? Also does anyone know where I might be able to get a data sheet?I've seriously looked everywhere.
1294191163 3490 FT98422 Securedownload
testtest
Wed Jan 05 2011, 02:00AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
Note that it may contain a fair amout of mercury according to the description.
Reference 2 may be of help.
Wed Jan 05 2011, 06:15AM
Grenadier wrote ...
I'll give mine away. ^^
Great, ill take 2 pweez.
I had some cool pictures of a normal vacuum rectifier being destroyed with 500ma across it,with 1ma being it's peak... But i guess they are gone. It was neat, it glowed blue like normal at first, which changed colors as the filament was annihilated smile It even made some new colors that where so beautiful, i dropped to my knees and cried.
Good times, good times...
Shrad
Sat Jan 08 2011, 04:44PM
this is one of several Helium-Cadmium laser tubes I have in my junk collection...
All I need to get is some 2kV 100mA current regulated power supply to get it to lase, and 30kV to trigger the tube once the cadmium in each cathodes reservoir has melted and cadmium vapor makes its route along the tube in order to maintain the plasma channel
1294505039 3215 FT98422 Tube Details
1294505039 3215 FT98422 Sticker
thyratron
Sat Jan 08 2011, 06:22PM
thyratron Registered Member #3539 Joined: Sun Dec 26 2010, 11:53AM
Nothing so far is as cool as this:-
4687
Shrad
Sun Jan 09 2011, 05:41PM
the tube has one center anode and two cathodes
heated anode melt the cadmium to form vapor to get a plasma channel, and a special reservoir with a heater is used to provide helium to get energy transfer to cadmium ions and reach population inversion of energy levels
you have to heat the helium reservoir (it has a special permeable glass membrane which lets pass helium atoms when heated to a certain temperature) to get helium in the mix, but one second of time you heat the reservoir, you have enough helium for tens of hours of cadmium usage
when cadmium flows through plasma, it gets in some traps at the extremities of the cathodes and is thus lost...
what I intend to do with those is restore the anode reservoir by reversing polarity and heat the cathode getters till cadmium almost disappears, to get back to some 4000 hours of use originally specified
what I lack to restore them like I would want are high voltage BNC connectors and some powering means
they were mainly used in DVD wafer processing and 3-D resin printing techniques
with special optics they can emit ultraviolet light in the sub-300nm range
Adam Munich
Fri Jan 28 2011, 03:16AM
Here's an old part.
1296184590 2893 FT98422 Dsc09468
Inducktion
Fri Jan 28 2011, 03:39AM
Hrm...Reading all of this fills me with jealousy. The oldest thing i have is maybe a Variable capacitor, and it's not even that old to begin with I believe. I'll go get a picture of it just so i don't feel left out.
Sorry for poor quality.
first  5 6 7 8
