  • Guests: 59
ZVS flyback driver problem
ZakWolf
Sun Oct 10 2010, 07:32PM Print
I made a power supply for my ZVS driver that was rectified and then filtered my rectifier blew and about 14v at 9 amps AC went into it. I turned it back on and my mosfet got really hot i replaced both of them and they still heat up ? what could be wrong ?
p.s im testing it with a 12v 1 amp supply that i have used on it before
1286739120 3114 FT0 Img 1265
Duality
Sun Oct 10 2010, 09:08PM
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
you did replace the rectifier?
ZakWolf
Sun Oct 10 2010, 11:39PM
well i turned it on again before i new that it was blown. i replace one mosfet ran 12v 1 amp power supply *DC* and they just got hot i replaced the other and the same thing happened could it be my diodes ?
tritium
Mon Oct 11 2010, 04:27PM
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
I think the screws are to long cheesey
but is one fet heating up?
1 amp. is not enough to let it oscilate, I think your supply is making the problem. (shortcutmode)
there is a big peakcurrent when starting the circuit, so maybe that is the reasen that you blow up your rectifier in your first used supply.
repair your high current supply, and replace the fast diode's,they look fried to me,and it should work again.
take bigger wires would be a good idea also..
and what LDC (core and inductance) do you use?
bgsniper
Mon Oct 11 2010, 07:22PM
bgsniper Registered Member #3200 Joined: Wed Sept 15 2010, 06:57PM
hi
screw the mosfets on separate heatsinks and they would not heat and the driver will run. Other reason for the heating up of the transistors may be the small value of the inductor
Matt Edwards
Mon Oct 11 2010, 07:56PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
The resistor on the top right doesn't look too happy! What does it test?
As suggested, you will need larger heatsinks on those mosfets and probably atleast a 4A transformer at 12-15v. I have used a 2A 12-24v transformer for short runs but it got hot quickly.
ZakWolf
Tue Oct 12 2010, 05:13AM
this is a picture of when it worked. The 12v 1 amp is fine i can draw little arcs with it. i think it my just have been exposed to high current AC frying my fast diodes and a mosfet or 2 i will replace everything.
