  • Guests: 36
11/27 Dax (43)
11/27 Mino (50)
11/29 Sonic (59)
Xfmr identification
HM_Murdock
Tue Oct 05 2010, 01:52AM Print
HM_Murdock Registered Member #3075 Joined: Fri Aug 06 2010, 02:44PM
Scavenged this Xfmr from a fairly big bug zapper...can't dig up any relevant info online, and am hoping someone here can tell me more based on experience...
Mainly:
1 - any idea about what V and mA this thing might be?
2 - would this type of xfmr be current limited like an NST, or not?
The arcs from it are high pitched in sound (like a flyback, but a lot louder), and VERY bright...like "lens flare/don't look at it" sort of bright. It's considerably louder than any of my big NST's when arcing.
No ratings info on it, only the following:
XFMR400-32NB
0850
B-10
made in Vietnam W
Here's a couple of pics and a short video of the arcs:
]bug_zapper_xfmr.wmv[/file]
1286243452 3075 FT0 Buf Zapper3
1286243452 3075 FT0 Buf Zapper2
1286243468 3075 FT0 Buf Zapper1
Tue Oct 05 2010, 02:20AM
In the last picture picture I can see what looks like a HV capacitor. This is probably what is causing such a big bang. It probably works by changing up this cap and when the unfortunate insect flys between the two grids, it completes the circuit and gets discharge of the capacitor, killing it. I think it isn't very powerful. Probably around the low KV, 1-3KV and not that much current since it would only need to charge the capacitor but it does looks reasonably sized so I might be wrong.
Adam Munich
Tue Oct 05 2010, 03:09AM
It is likely not more than 3kV, and not more than 10mA. A rough way to measure voltage is by spark (not arc) length. Using 2 marble sized steel balls as electrodes, bring them closer and closer together until it sparks over. Do this over a plastic ruler so you can measure the distance. On an average day it'll be about 10kV/cm.
I'm not sure if it's current limited, but judging by how far the primary is from the secondary it may be.
Also, old thread discussing the same transformer. Link2
Tue Oct 05 2010, 03:30AM
just on a related note... when you say marble size grenadier... doesnt the diameter of the ball relate to how uniform the e-field between the balls is?
ive always seen tables that seem to go no smaller than 1 inch and go up to like 2 inches
Adam Munich
Tue Oct 05 2010, 03:35AM
Smaller balls cause larger sparks, but I've always had good accuracy with marble sized balls.
Also HM Murdock, remember your peak voltage will be the rated voltage / .707. This means a 15,000V transformer will have a peak voltage of 21206 volts, which explains why the sparks tend to be longer on an AC source. I'm not sure what effect that unknown cap could have though.
It's still likely not over 3kV RMS though.
Wolfram
Tue Oct 05 2010, 08:46AM
Grenadier wrote ...
This doesn't sound right. 10kV/cm is the usual quoted figure between sharp points, for balls it would be much lower. According to the graph on the bottom of this Link2 page it's more like 30kV/cm between balls of larger diameter than the gap between them.
Tue Oct 05 2010, 09:42AM
Anders M. wrote ...
+1, it's nearer 30kV/cm for balls. But the value depends on the surface condition, if the balls aren't smooth, clean and shiny it could be less.
Tue Oct 05 2010, 10:46AM
Edit: Scrap this, You would need a decent DMM with RMS AC.
If you got a cheap DMM you don't mind lossing. You can put two resistors with known value across the output and measure the voltage drop. From this you will also me able to get the current output, depending on what resistors you decide to use.
ScotchTapeLord
Tue Oct 05 2010, 01:14PM
If you charged a capacitor through a HV diode, then you could use a resistive divider to measure the DC voltage, which should be equal to the peak voltage of the ac, then divide by 1.41 to find the VAC. Easily done with maybe a couple MO diodes and a MO cap. and a string of megohm resistors. Just remember to factor in your device's internal resistance.
Luca
Tue Oct 05 2010, 03:41PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
If I see correctly, there is a sort of magnetic shunt between the primary and sec. So, it should be current limited as standard NST.
Regards,
Luca
