  • Guests: 55
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Beefy ZVS
Adam Munich
Fri Oct 01 2010, 03:54AM Print
So I'm itching to play with those superflybacks I have, so I'm going to build 2 ZVS drivers that will take some heavy abuse.
Here's what I plan on ordering. Speak now if anything seems astray.
4x IRFP260
10x 2A 400V 75ns diodes
10x 1N4742A 12v zeners
Jameco didn't have any high power 470Ω resistors, so I'm going to get 4 20Ω 5watt ones, and 12 150Ω 5 watt ones. 150+150+150+20 = 470
I already have some ferrites, 10k resistors, heat sinks, and some vintage 600V rolled foil .68uf caps at home. Power source will be either some car batteries, my 2 100Ah gel cells, or a mix of the two.
Total cost including postage = $28.5 (not too bad for 2 beefy zvs's)
So, any comments? Please speak before I press place order.
Myke
Fri Oct 01 2010, 04:12AM
For higher input voltages, you would want a higher value gate resistor. Otherwise, you will probably run into parasitic oscillations which are no fun.
Adam Munich
Fri Oct 01 2010, 05:02AM
How much higher?
I just noticed those resistors were .15Ω ohms anyway. Since jameco doesn't seem to have a large choice of resistors I'm going to get everything from allied. I may just get a bunch of hundred ohm resistors and add them as I see fit.
Edit; this is what I bought. Link2
Adam Munich
Sun Oct 03 2010, 09:56PM
Alright allied fails hard; my order has been pending for 3 days. I'm going to get the silicon at jameco and the resistors somewhere else. (I used a gift card so allied can't charge it if jameco does first)
I was thinking of a dual potentiometer for the gate resistors, but it's hard to find 2W ones that I can afford. Do these resistors really need to be that hefty? They're only driving the mosfet's gate.
Sun Oct 03 2010, 10:03PM
With a pot, it is always easy to accidentally turn it and kill your MOSFETs. It might be an idea to put a resistor in series with the pot to prevent gate resistance from going too low. Also in this case a dual pot would be best
Adam Munich
Sun Oct 03 2010, 10:22PM
That's what I planned on doing. Putting a 500 ohm resistor in series with a 500 ohm pot. But does it really need to be 2 watts?
Mon Oct 04 2010, 12:00AM
Grenadier wrote ...
The gate resistor pulls the gate up to the voltage supply. When the mosfets are turned off, the supply is shorted to ground through the resistor. That is why they dissipate a fair bit of power.
The larger the resistance, the slower the turn on, which means more switching losses, but less current through the resistor. The smaller the resistance, the more current will flow, but a faster turn on. I once made one of these with 2 1kohm .25 watt resistors in parallel for each resistor, and they never got very hot.
Another thing you can do is use a separate 12v supply for the gate pull-up, thus meaning less voltage drop across the pull-up resistors. I have done it with no problems, and it only needs to be something like a 500ma supply.
Adam Munich
Mon Oct 04 2010, 12:42AM
Arcstarter wrote ...
I see now... In that case a theoretical 48V supply would burn out half watt pots nearly instantly. I suppose I'm stuck with the whitebox wirewounds. Maybe I could design a switch to select a resistance from 470 to 1K.
Adam Munich
Mon Oct 04 2010, 04:35AM
I came up with a solution that will both allow the resistance to be variable, and to allow me to buy everything from jameco without breaking the bank. DIP switches! I ordered 100 .5W 4.7k resistors and 4 8 pole DIP switches. Setting the switches changes the resistance. Let me explain with a picture.
1286166956 2893 FT97679 New Bitmap Image
Mon Oct 04 2010, 09:28AM
Careful =S
DIP switchs don't have a great power rating
