  • Guests: 56
Capacitors and Capacitance - Dumb basic question
Troy
Thu Sept 30 2010, 08:23PM Print
Troy Registered Member #3194 Joined: Tue Sept 14 2010, 04:16AM
I've tried to google/wiki/how-to.com this question:
in layman's terms, what really IS capacitance and why is it significant?
Here is how I think I understand it:
Capacitance is a measure of the amount of electrons (measured in Farads or fractions thereof) a capacitor can hold/release per the stated or designed voltage rating.
Am I just way off base with this or on right track? If so, another question: while there are an almost infinite number of circuits for inifinite purposes, basically - keeping it kindergarden level here - how is capacitance significant? Thinking it would affect current load, especially on sensitive circuits.
Again, thanks for the responses and furthering my understanding...
doctor electrons
Thu Sept 30 2010, 09:33PM
You can think of a capacitor as a little storage tank for voltage. Here is an analogy that may help you out.
"Voltage is like the water in a water tower. Current is like the amount of flow coming out of that water tower."
Voltage is pressure, current is flow. A capacitor is a reactive device so when you place it in a circuit it will have an effect.
Look up capacitive and inductive reactance on google. Inductive reactance will deal with inductors obviously. These are two
things that will be of great use to you if you are planning to get into electronics. Hope this gives you someplace to begin!
Mike...
Antonio
Fri Oct 01 2010, 12:39AM
A capacitor is a device that follows Volta's law, that says that electrical charge and voltage are proportional: Q = C*V, where C is the capacitance. An insulated conductor suspended above ground follows this law, considering its voltage to ground and the charge accumulated on it. A more useful device is a capacitor, that has two conductor plates at small distance insulated from each other. They store opposite charges in the plates, in an amount proportional to the voltage between the plates. In the hydraulic analog, a capacitor would be an elastic membrane closing the passage of water (charge) trough a pipe (wire). The amount of water that the membrane holds in the bulge that it forms when deformed is proportional to the pressure (voltage) applied. AC currents (water going back and forth) can pass through a capacitor, but DC currents are soon blocked when the capacitor is completely charged.
