  • Guests: 50
Mystery Old Tesla Coil Item
IntraWinding
Wed Sept 29 2010, 10:34PM Print
Can anyone reveal anything more about this mystery antique high voltage gear?
It's described as a 'Tesla Coil made by Harvey & Peak' by the owner:
1285799244 2261 FT0 Tesla
Wed Sept 29 2010, 11:32PM
From an antiquarian point of view, there is something not quite right about it, when you compare its build with other known Harvey & Peak instruments.
The whole fish tank appearance of what I suppose was an oil bath, the crudeness of the wooden blocks holding it in place, and the two (presumably) primary wires not being terminated through the wall of the tank, looks far too crude to be a Harvey & Peak instrument, though I would certainly believe it used H & P parts, such as the Leyden Jars.
H & P are best known for their influence machines - Wimshurt's Machines in particular - which sell for thousands of pounds when they are in very fine condition.
Tesla certainly did design horizontal high voltage transformers in the 1890s, when H & P were manufacturing in London, but I wouldn't advise anyone to buy this as an investment antique. It looks modified or interfered with by some bodger or experimentalist.
IntraWinding
Fri Oct 01 2010, 02:48PM
Thanks for that - I didn't realise you were so up on antiquarian stuff!
The person who asked about this is up for restoring things with a few missing parts (or improving on a previous restoration), but this sound a bit suspect.
Fri Oct 01 2010, 03:10PM
Harvey & Peak 6 rotor Wimshurst Machine
1285945459 543 FT0 H  P 1
1285945459 543 FT0 H  P 2
1285945520 543 FT0 H  P 3
1285945520 543 FT0 H  P 4
1285945589 543 FT0 H  P 5
1285945589 543 FT0 H  P 7
1285945589 543 FT0 H  P 8
Fri Oct 01 2010, 07:07PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
I think I know. It isn't a tesla coil in the sence that it is a air core transformer, it has a iron core. This is the set up. It's a regular tesla coil schematic as one spark gap is the saftey, the other is the real one, the lyden jars are the caps, and the thing in the bath is the tranformer. It was a model of a 19th century electrotherpy coil
My 2 bit
Paul
