  • Guests: 54
Worst SGTC ever
Wed Sept 29 2010, 11:21AM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
I want to make the worst tesla coil ever! Let me explain:
You all know the basic wireless energy plan, 2 tesla coils, one transmitter, one reciver. Well this is my twist, what if we have a farday cage that's a tube and the tesla coil top loads are at both ends. But, if the tesla coil had streamers, they couls arc through the cage and destroy the experment. So if the coil produces only RF, EF, etc, the waves will be big enough to not escape the cage, they would bounce in the cage from the transmitter to the reciver and thus have more efficiency, perhaps enough to bet copper wires cost wise. (high power)
so to list them,
1. how to create a tesla coil perfactly tuned to make only rf
2. any helpful hints!
Paul amazed
HazzWold 1993
Wed Sept 29 2010, 11:46AM
Wireless energy? Check out JiffyCoils YouTube.. Link2 Theres definitely potential with the slayer exciter.
Wed Sept 29 2010, 08:32PM
Thank you labs..
Do you have a schematic for a slayer exciter for me?
Any other ideas?
Wed Sept 29 2010, 10:57PM
Make a normal SGTC with a large topload and don't open the spark gap too wide.
Thu Sept 30 2010, 11:25AM
So I should have a normaly tuned tesla coil with a large topload? Also, the spark gap should be as small as possible?
PAul
Thu Sept 30 2010, 12:27PM
Not neccessarily as small as possible, just close enough so that breakouts don't occur.
N.Tesla 'showed off' his system with arcs & sparks but his aim was to do just what you are considering on a smaller scale - wireless transmission of energy.
To this end he was trying to create enormous voltages with no breakout,
hence an enormous topload.
Roughly (experts may correct me here) the topload will breakout at a certain voltage dependant on the radius (I use an estimate of3kV/mm radius).
The topload voltage is (very) roughly Vcp x SQRT(Cp/Cs).
SO
Adjusting the spark gap (almost) directly adjusts the peak topload voltage.
Here's a large topload; Link2
Thu Sept 30 2010, 11:14PM
that's BIG!
by the way, do you have a schematic for a slayer exciter?
I'm sorry I forgot, what does Vcp stand for again? Also, cp and cs! I'm just memorizing the names for different electrical units, sorry!
HazzWold 1993
Fri Oct 01 2010, 01:52AM
I c could not find one posted, you may have to inquire to jiffycoil about it. though the SEC exciter is something that you should play around with a bit to fully understand it, so i doubt Dr Stifflers site will give a direct schematic.
Fri Oct 01 2010, 01:57AM
Thanks, will PM him.
Sat Oct 02 2010, 03:44AM
Sorry,
Cp Primary capacitance
Cs Secondary capacitance (coil+topload+corona+spark channel)
Vcp Voltage across Cp
