  • Guests: 47
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
sstc output reduce's when object near streamers. (solved!!)
Duality
Mon Sept 27 2010, 02:30PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
hello i have build a sstc this design:
so i got it all working, put two mosfet's in the circuit the mosfet's die.
put new one's in and it worked got sparks.
now i want to put a metal object near it. but as soon as i put a screwdriver (grounded ofcourse) near the output, it's output begins to crackle, sounds like it's detuning it's self, but it's feedback driven so how can that happen?
Mon Sept 27 2010, 03:18PM
Because you are likely disturbing the feedback or altering it somehow.
Perhaps try moving the antenna to another location and retrying.
Duality
Mon Sept 27 2010, 04:21PM
quick note i forgot to tell, that i used a feedback transformer like in this circuit:
and i wound it on a ferrite radio core.
so i don't have a antenna witch i could disturb by putting something in between.
dingo27
Mon Sept 27 2010, 06:33PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
how many turns your feedback trafo has?
Duality
Mon Sept 27 2010, 07:00PM
primary 10 turns, secondary 60 turns.
Mon Sept 27 2010, 07:46PM
if you try to draw arcs from the secondary, you kill the resonant rise, the secondary current doesnt return to zero and the oscillation stops until the next interrupter pulse.
Duality
Mon Sept 27 2010, 08:50PM
ah, and is there a way to fix this?
Mon Sept 27 2010, 09:03PM
yes, its called a PLL wink
Matt Edwards
Tue Sept 28 2010, 06:15AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Remember that surrounding objects will affect the resonant frequency of the coil. This may be part of what you are experiencing.
Tue Sept 28 2010, 11:16AM
Oidium45: He is using feedback so the coil tunes to the resonant frequency.
