  • Guests: 51
steve ultimate drsstc controller
Gregory
Sun Sept 26 2010, 05:40PM Print
i'm making a big drsstc, and i will use the steve controller, with some modifications.
i need to change the values of the "rc filter" that make a delay in the flip-flop? my secondary frequency is around 90khz and the primary i will run around 60-70khz.
Goodchild
Sun Sept 26 2010, 08:45PM
Why would you want to change the controller arrowed? It's already been optimized, if you change it chances are your making worse.
Gregory
Sun Sept 26 2010, 09:13PM
i read that the values need to be changed to make a delay of 1.5*(period of the resonance frequency of the primary).
