  • Guests: 49
topload idea
Sun Sept 26 2010, 01:15AM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Anyone tried using the screen of strainers?
Mon Sept 27 2010, 03:19PM
Those would work fine. I used to use salad bowls i welded together.
dingo27
Mon Sept 27 2010, 09:14PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
but it will have less capacity than normal toroid, no?
ScotchTapeLord
Tue Sept 28 2010, 12:45AM
It'll work, but how it acts depends on the surface area. Irregular/bumpy surfaces have more surface area and therefore more capacitance than something smooth of the same size like a toroid but will also be lossier- it could break out before the voltage gets as high as it would with a smooth topload. This may or may not cause a noticeable change in performance. If you have them on hand, they're worth a try. A first-hand experiment is much more conclusive than my or anyone else's conjecture.
Tue Sept 28 2010, 01:18AM
I'm making them tomorrow!
