  • Guests: 102
SCR clamping - Torque
Killa-X
Fri Sept 24 2010, 10:11PM Print
Hey all, just want to assure I do everything right with my first SCR pucks.
I have the C398 model, and the datasheet says MAX force 2000 pounds. No min. force is listed. So, Not sure how much force I should apply to this. The other issue, I have a torque wrench, 0-140 foot pounds. Is there any way to know a SAFE foot-pounds torque, without passing the 2000 pounds of force limit? My hardware store only sells 100 pound spring washers, So the only other thing that I can do, is fine some place online that sells around 1500 pound spring washers...
Also, I'm hoping this 1/4" steal beam is thick enough. It came from a 2x2" steal L beam...Was fun cutting it, hard stuff!
Any feedback will help, Thanks all!
Also...What might be a safe ft/pound to test a SCR at maybe 30V or so?
edit
My SCR that isnt pressed has 1mm of metal showing above the ceramic material. My one in the press, isnt shown. I tighten it down by guessing, and I didnt even hit a foot pound of torque, and my 1/4" thick iron beam metal, is already bending in a ( shape...so far, i did a 70V test, and it worked. But just because it works, doesn't mean it will at 450...
Sun Sept 26 2010, 04:37AM
Here are a few hints.
Many kinds of spring washers, such as Bellville washers and wave washers,
can be stacked in such a way that each one gets the full deflection,
so the forces add. With a bolt on each side of SCR, and three 100-lb spring washers
on each bolt, you are up to 600 lbs.
As for the torque to get a given bolt tension, it's easy to find tables and formulas on the Internet.
All approximate, because of variables such as friction between the mating threads. But as you know, most bolting instructions specify torque when what matters to the engineer is tension.
Find a smaller torque wrench. 1/4-20 bolts and torques less than 5 ft-lb can overstress your SCR.
If your steel beam is measurably bending into a ( shape, it can serve as a pretty accurate gauge of clamping force -- much better than the torque wrench. With a dimensioned drawing or picture, you (or anyone who has studied "strength of materials") can calcuate the amount of elastic bending when there is (say) 1500 lbs of force on the SCR puck.
Killa-X
Mon Sept 27 2010, 12:20AM
Ah...Well, Here is a picture of the SCR. Right now it has 1/4" Iron I beleive. My dad picked it up at work for welding practice. So I cant fully say what it is. I will try to hit the hardware store tomorrow, and see if they have any types of washers that are rated in pounds...So far, the torque meter gets to about 8. on each. I may consider though getting a new wrench before I redo this too...Because its my dads old one, and it still 'frictions' on the scale a little, so im questioning if that is going to effect it a lot.
1285546842 1643 FT97251 Scrfront
1285546842 1643 FT97251 Scrtop
I will try to get in tomorrow and see what they have. If the max is 2000, do I want to aim for 1000? 1500?
Mon Sept 27 2010, 02:51AM
Wow! If those flat steel bars are 1/4 inch thick and 2 inches wide,
either you are way over 2000 lbs, or the bars have yielded and are permanently bent.
My unreviewed calculation says that with a 2000 lb load midway between two bolts 4" apart (at 1000 lbs each), the elastic deflection would be only 0.035" and peak stress 96000 psi. That's too much for mild steel, especially hot-rolled stock, which would probably yield at a lower stress.
If the bolts were only 3" apart then deflection would be .015" and stress 72000 psi.
p.s. the deflection values are for just the section between the bolts.
Anyone else care to review these numbers?
Killa-X
Mon Sept 27 2010, 03:07AM
Well, I put the spacing where the SCR plastic things were. Clearly, if it was 2000 pounds, it would prob break because the max force, is 2000 pounds. I also have 1/4" acrylic isolating the clamp and the pic, with a washer to focus the force to the center. That hasnt snapped, and I dont think acrylic could handle over 2000 pounds of force, on top of a small washer.
Measurements!
bars are 1.5" deep. and 5" wide. 1/4" thick.
the 2 bolts, from the CENTER, are exactly 2 6/8" apart.
When putting a flat piece of wood along the steel, the 'bow' is about 1mm higher than the ends.
Again, unless my torque wrench is THAT bad, i didnt even get past 5-6 foot pounds of force.
My thought, was I need a thicker bar.
Mon Sept 27 2010, 03:29AM
Killa-X wrote ...
Measurements!
Thanks for the numbers. Unfortunately I'm just about out of time.
The datasheet says "max clamping force 2000 lbs". That's the maximum design load in the SCR application. Like saying a 1/2 ton pickup truck is rated to carry 1000 lbs -- we would not expect it to break at twice that load, but can't depend on the maker's warranty if it -does- break.
I bet your steel beams have yielded -- taken a permanent set -- so we can't use their elastic deflection to gauge the load. If the SCR and stuff stacked with it were incompressible, you would hit 2000 lbs with less than 1/2 turn of each nut. If the nut keeps turning without a proportional increase in torque, something is yielding.
The compressive strength of acrylic (PMMA) is given by a couple references as 10,000 to 18,000 psi.
I think your thicker bar idea is good. How 'bout some 1" square tubing? Could safely give you 2000 lbs of compression with up to 7" between the bolts,
[edit]
Read about spring washers at McMaster.
Part 9712K71 is 12 for about $4.
WIth two on each bolt, the load when flat would be 1600 lbs.
Killa-X
Mon Sept 27 2010, 03:49AM
Well I know a puck that is NOT pressed has 1mm of metal showing between the plate and the white ceramic. In my clamp, it has been pushed down to the ceramic, which we want. As to how hard, I can't say.
So my best bet may be to undo it all, get some 100+ rated washers, new steel, and aim for a number? I got more steel I can sawsall cut to have fresh unbent metal... My datasheet doesn't say a minimum force, so I have no idea what to aim for.
Seeing we don't know if it's overpressured, and that I did 70v tests, is it possible the scr could suffer damages? And should I only get washers for the bolts, or should I try to get some on the puck to go by center force?
Thanks for the help so far!
edit Thanks for the help too, My hardware store did not have ANY at all! Have to go online.
So basically just screw down until they are completely flat. Sounds good :)
Th
Yeah...I'm going to need to cut new pieces. Or in fact, Since this bent, I should probably get thicker metal...Right? The torque wrench was under 5 foot pounds, so there's no way it was even close...
If not... would 1" thick steel work? I'm not too knowlageful on metals and strengths. I know a 1" bar of aluminum would be cheaper, but is 1" x 1" of 6061 strong enough to apply that much force? or will it bend?
Ebay has a 1" x 1" x 12" 6061 aluminum for $8 after shipping.
Ebay also has a 1" x 1" x 24" Steel ALLOY 12-L-14 for $15 after shipping...
Guess I answer my own question...Given your calculator is right with 6061, it says 1" x 1" would bend 0.0365 with aluminum.
Wiki says, "6061-T6511" is rated tensile strength of 42,000 psi, yield strength of 35,000 psi
